Alpine MRP-F240 vahvistin
  • Snike
    • Jan 2012
    • 84
    Myynnissä Alpine MRP-F240 4-kanavainen vahvistin.
    Tekniset tiedot:
    40 watts RMS x 4 at 4 ohms
    50 watts RMS x 4 at 2 ohms
    100 watts RMS x 2 bridged output at 4 ohms
    2-, 3-, or 4-channel output
    4-ohm stable in bridged mode
    Tri-way capable (Tri-Way crossover required)
    requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
    selectable high-pass/low-pass crossover at 80 Hz, 18 dB/octave (2 separate crossovers, one for channels 1 & 2, another for channels 3 & 4)
    subsonic filter at 15 Hz for channels 3 & 4
    tuned Bass EQ (0-12 dB bass boost at 50 Hz) for channels 3 & 4
    preamp outputs
    MOSFET power supply
    STAR Topology (minimizes internal noise and prevents ground interference)
    speaker- and preamp-level inputs
    gold-plated screw terminals
    10-1/2"W x 2-7/16"H x 9-9/16"D
    1-year warranty
    HP: 50€ / tarjous
    Sijainti: Espoo
    Mieluiten nouto, mutta poistituskin käy. Ostaja maksaa postikulut.
    E92 335i CiA M-Sport '08 Sparkling Graphite
    | JB4 G5 ISO + BT | Trebila Performance custom tune | 65% RE85 | BMS dual cone intake | VRSF 3" downpipes | VRSF 7" intercooler | VRSF upper charge pipe | VRSF lower charge pipe | Turbosmart Race Port | Stage 2 LPFP "Pluto" | xHP Stage 3 | N20 3.5bar TMAP | RB PCV valve | OCC | BMS cowl delete filters | BMS TB BOV vacuum adapter | NGK Iridium | H&R Monotube coilovers |
