Diagnostiikka-kaapeli Carsoftille
  • Axum
    • 4416
    Myydään diagnostiikka-kaapeli 20 pinnisellä ja OBD2-liittimellä, mukaan CD jossa Carsoft ohjelmisto.
    - Manufacturer's product descriptions:
    - MCU controlled Interface for Carsoft 6.5 which is compatible with the original interface.
    - Fully digital line switchings and MCU controlled service reset timing.
    - Main Functions
    - Digital total test: It gives you a complete idea of the overall condition of the car.
    - Digital single test: It gives you detailed information about the appropriate control unit.
    - Stored errors will be shown in a written report. This report has a short info-text which help you to eliminate the error.
    - Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, and coding.
    - Applications list
    - E30 - 3 Series
    - DME ALL
    - DDE ALL
    - AB From 1998
    - BC/MID ALL
    - DWA ALL
    - E36 C 3 Series
    - KOMBI Except kompakt
    - AB ALL
    - ABS ALL
    - ASC ALL
    - ZKE From 1994
    - ZVM Till 1994
    - HKL ALL
    - EGS ALL
    - EWS ALL
    - E46 C 3 Series
    - KOMBI ALL
    - DSC ALL
    - ZKE ALL
    - LCM ALL
    - CCM ALL
    - PDC ALL
    - CVM ALL
    - Z3
    - E34 C 5 Series
    - KOMBI From 02/98
    - ABS From 1992
    - ASC From 1992
    - E39 C 5 Series
    - ZVM ALL
    - E53 C X5
    - E32 C 7 Series ... E38, E31, E52
    Hp.25 e/tarjous
    Löytyy Kuopiosta, nouto, rahat tilille ja posti/MH kuljettaa ostajan piikkiin.
    PM, akheikki(ät)dnainternet.net, nolla neljä neljä 567 4793
    - E30 325i M52B28TU Cabriolet
    - E39 528ia
    - KUOPION PUTKIMIEHET -team
    Puretaan 520ia -97
