M: Bosch 6kpl 1700cc suutimet (uudet)
  • Mardo
    • Oct 2007
    • 60
    Eli ihan uudet, avamattomat/paketissa suutimet, tilattu "matched batch of 6"
    H: 500€ + posti
    Urjala
    +358 404 808 630
    Specifications:
    Coil Resistance: 9.1 Ohms / High Impedance
    Dead Time: 0.45ms at 14 volts
    Static Flow Rate @ 43.5 PSI ( 300kPa ) w/Gas: 1700 cc/min = 160 lb/hr
    Static Flow Rate @ 50 PSI ( 350kPa ) w/Gas: 1875 cc/min = 180 lb/hr
    Static Flow Rate @ 58 PSI ( 400kPa ) w/Gas: 2000 cc/min = 195 lb/hr
    Connector: Bosch EV1
    Injector Length: O-Ring to O-Ring: 62 mm
    Injector Overall Length: 74 mm
    Injector Body Diameter: 16mm
    O-Ring: 14.5mm Viton
    Acceptable Fuels: Gas/Petrol, alcohol/methanol, E85, CNG
