BMW e60/63 550i/650i 2006-2009 Vapaavirtaussuodatin
  • bmw650ci
    • Aug 2016
    • 8
    • espoo
    Myydään 3kk vanha vapaavirtaussuodatin.
    auto nyt myyty vakiona ja tuo jäi ylimääräisenä.
    Tarjotkaa hintaa!
    AFE POWER 51-11142 STAGE 2 PRO DRY S INTAKE FOR 2006-2009 BMW 550I/650I 4.8L
    In recent testing this air intake system produces 12 max horsepower, 11 lbs. x ft. torque and out-flows the factory intake by 45%. This air intake system offers a washable/reusable "oil-free" synthetic conical air filter that directly mounts to a 3-angle filter adaptor that helps smooth the air transition into the intake tract for better performance.
    This intake system also features a heat-insulating molded plastic tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. A one-piece black powder-coated heat shield and brushed aluminum cover requires little to no assembly for a hassle free installation. The filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
    5-1/2” Conical Pro Dry S Air Filter: This intake utilizes a huge, 5-1/2" conical Pro Dry S performance air filter for increased performance. This 3-layer progressive, synthetic material air filter requires no oils and cleans with soap and water for maximum convenience.
    One-Piece Filter Housing: The air filter is housed in a one-piece, black powdercoated 16-gauge heat shield that keeps warm engine air out for maximum performance. This one-piece heat shield uses factory mounting locations and comes with all hardware for a hassle-free installation.
    Brushed Aluminum Cover: An attractive brushed aluminum cover is included to keep temperatures down while providing ready access to the filter for servicing.
    3-Angle Adaptor: A 3-angle adaptor is used to speed up the air flow for improved performance and throttle response.
