M: 380cc suuttimet 8kpl
  • Elementti
    • Nov 2010
    • 222
    Myydään ylimääräiseksi jääneet hieman isommat suuttimet.
    Uudet ja käyttämättömät.
    Any BMW E36, E46 or other 6 cylinder engine with Bosch EV1 or EV6 style injectors.
    Features
    Design: EV1 Style Fuel Injector
    O-Rings Included: Yes, preinstalled
    Injector Design: Metal & composite plastic
    Orifice Type: 4 holes Disc
    Connector Type: EV1
    Filter Design: Basket filter design at inlet
    Spray Pattern: 15 Degree Spray Cone
    Technical Data
    Coil Resistance: 14 Ohms / High Impedance
    Static Flow Rate: 36 lb/hr = 380 cc/min @ 43.5PSI ( 300kPa )
    Gain: 0.12ms/MG
    Offset: 0.055ms
    Turn on time @ 14VDC: 1.14ms
    Turn off time: 0.85ms @ 300KPa
    Amperage: 1.0 Amps
    Pressure: Min 30PSIG/ Max 100PSIG
    Mechanical Spec
    Length: 3" (74mm)
    O-Ring Diameter: 14.5mm
    Helsinki 100€
    o5o4397835
    e38 740d '99 Sahara-beige
    e65 730d ’07 Black-sapphire
    f01 730d '09 sophisto-grau
