Vortech V-1 Supercharger kit for BMW E36 M52/M50 and S50/S52
  • Simas323
    • May 2015
    • 12
    • Lithuania
    For sale Vortech V-1 Supercharger kit for BMW E36 M52/M50 and S50/S52
    *Vortech V-1 supercharger (no shaft play or noise, can provide video proof if needed)
    *engine mounting kit
    *oil feed/return line
    *belts
    *84mm SC pulley and 149mm crank Pulley (good for 44,7k RPM)
    *tensioners
    *Full intercooler piping (IC not included)
    *Blow-off valve and other parts for fitting
    Vortech V-1 spec:
    Max Speed: 50000 RPM
    Max Boost: 20 PSI
    Max Flow: 1000 CFM
    Max Power: 680 HP
    Peak Efficiency: 72%
    Discharge OD: 69.85mm
    Inlet OD: 88.9mm
    Discharge ID: 60.45mm
    Inducer Diameter: 78.74mm
    Kit does not include injectors and intercooler.
    Pictures can be found here http://bit.ly/vortv1
    Asking price 3,300e. Kit located in Lithuania.
    Also greetings to all Tampere BMW community! I've been there for half a year during my exchange studies
    BMW E36/5 323Ti M52B30 N/A stroker. 280HP/310NM
  • Simas323
    • May 2015
    • 12
    • Lithuania
    Up. Shipping is possible.
    • Simas323
      • May 2015
      • 12
      • Lithuania
      You can also contact me [email protected]
