OBD adaptereita (MHD ja Bimmergeeks)
  • Venom
    • 623
    Auto lähti adapterit jäi:
    MHD black wifi obd2 adapteri
    Official MHD WiFi adapter for BMW E, F and G series with fast ENET on F/G cars and sleep mode. Also works with xHP, xDelete, BimmerCode and ProTool.
    H: 50 €
    Bimmergeeks obd2 usb kaapeli + USBA - USBC sovitin (saa obd adapterin kännykkään ja toimimaan protool sovelluksen kanssa)
    Inspired by our Pro+ Anniversary Cable, The BimmerGeeks Expert Edition K+DCAN cable is the cable for all true enthusiasts. Built for durability, efficiency & productivity, this is the single-most elite of cables available on the market. When put to the test, it is proven to come second to none even compared to our Pro K+DCAN cable. Here is the gist: • Flashes twice as fast as a standard K+DCAN, 10% faster than the Pro-Cable.• Compatible with Coding Fxx/Gxx/Ixx chassis via ProTool.• Compatible with all programs that support K+DCAN.• Specifically built for stability for long programming/flashing sessions.• Compatibility for all E chassis diagnostics, coding, and flashing.• Compatibility for Fxx diagnostics, MHD Fxx flashing, etc.• Built with highest quality components including gold 16 pin connectors and USB connectors.• Includes 1-year warranty. - Proven to flash modules other K+DCAN's can't such as: M3/M5/M6 DME (MSS6X) E6x M5/M6 SMG (GDSMG3) E9x GM Auto (GM1912) **Please note, this cable does not include a switch for Double K-Line vehicles such as E39, E46, E38, E53, etc, for use with those models you will need to add the Double K-Line adapter option at checkout.**
    H: 40 €
    Vantaalta löytyy ja YV:llä tavoittaa
  • Martom
    • Jun 2024
    • 1
    • Raisio
    Kiinnostunut! Black mielummin jos löytyy!
    • Katujekuningas69
      • Dec 2022
      • 10
      • Lohja
      mahtaako mhd palikkaa viel löytyy? D
