bootmod3 softa N20/N26 koneelle 300e (ovh 595$)
  • wimpeli
    • Sep 2024
    • 1
    • Uusimaa
    Tarjolla bootmod3 softa N20/N26 koneelliseen bemariin, itse käyttänyt F30 kanssa ja tämä teki autosta todella pirteän ja paremman ajaa. Linkin takaa enemmän tietoa softasta ja pientä osviittaa softan vaikutuksista tehomääriin. Softa on todella helppokäyttöinen ja nopea tapa saada lisätehoja irti koneesta.
    World's First, Most Advanced and Widely Adopted cloud-based flash tuning platform for the BMW F and G series vehicles! Cloud-based solution with a web-based interface and mobile apps for iOS and Android. Developed and tested in-house from the ground up over the course of almost 2 years prior to its November 2016 debut with new features and updates being added regularly makes the bootmod3 platform a custom BMW factory DME tuning solution like no other on the market today. Build the ultimate tune for your N20 / N26 powered vehicle and go from stock to full race calibration, and everywhere in between, with a map switch in the provided mobile app. bootmod3 calibrates the factory vehicle modules over the OBD port in a matter of minutes in the convenience of your driveway or anywhere internet access is available. bootmod3 app and cloud services offer many unique features not found in any other flash tune, including and currently available: Mobile app (iOS and Android) and Web (http://www.bootmod3.net), including Windows and macOS support One OTS map/tune included with the purchase and any other maps labeled as "FREE" Datalogging over 200 diagnostic channels, up to 40 channels concurrently Datalog sharing and charting without a need to upload to 3rd party websites or apps using the mobile app or web browser Cloud-based storage for map data and datalogs Reverting back to stock performance map and re-locking the DME to stock programming Live Dash - realtime vehicle parameter monitoring via in-app gauges Diagnostics Read and clear trouble codes in all vehicle modules Reset learned adaptations (octane, knock, Valvetronic, etc) ECU power reset (Optional) Off the shelf (OTS) tunes for 91/93/Race gas/E85 octane (SEE HERE) (Optional) Custom tuning available through tuners in the bootmod3 Tuner Directory. bootmod3 contains a full map editor so you can tune your car yourself or with your local tuner of choice as well. Some of the OTS and possible aftermarket turbo upgrade custom map features provided by the bootmod3 platform: Map Customization through Map Editor Exhaust Burble adjustments on any map (OTS & Custom) GTS Startup Roar Max Cooling Mode Cold start (cat heating on startup) removal for quieter cold start Cat efficiency check (CEL) removal for de-cat downpipes (for off-road use) Exhaust Flap Adjustments (Sport Mode) Top Speed Limiter Removal Boost By Gear % Reduction Re-calibrated Sport Gauges on iDrive Maps for upgraded turbos E85/blend, RaceGas, and Meth Injection Tuning Custom Throttle Mapping Backend Flash Maps for Piggyback Use N20 engine BMW Vehicles supported (if your N20 vehicle is not listed please inquire with us): 2012–2017 F20 125i 2014–2016 F22 220i/228i 2012–2015 F30 320i/328i 2013–2016 F34 320i GT/ 328i GT 2014–2016 F32 420i/428i 2011–2016 F10 520i/525Li/528i 2013-2017 F25 X3 sDrive18i/xDrive20i 2014–2017 F26 X4 xDrive20i Minimum Mobile and Desktop OS Requirements: iOS 13 or higher Android 5.0 or higher Windows 10 or higher macOS 10.15 (Catalina) or later For more info take a look at the FAQ here! *** bootmod3 WiFi Adapter or OBD ENET cable required, available separately VEHICLE MANUFACTURER WARRANTY AND EMISSIONS DISCLAIMER Some items used and/or installed by PRO TUNING FREAKS may void portions of your vehicle’s factory warranty. Some items may not be legal for “on highway use”. PRO TUNING FREAKS makes no guarantees to the legality of any parts used for “on highway vehicles” and accepts no responsibility for compliance with the vehicle’s factory warranty. bootmod3 software and hardware Terms and Conditions
