M: UUSIA OEM-osia
  • Laku
    • 17676
    M: UUSIA OEM-osia
    Tallintyhjennystä omien projektien osalta ylijääneistä kamoista.
    HUOM! Kaikki osat ovat alkuperäisiä BMW-osia!!!
    07119932132 korvaava 07119932130 prikkoja taivutettu 700,1502-2002tii,1500-2000CS,2.5-3.0CSL,2500-3.3Li,E12,E21,E23,E24,E26,E28,E30,E34,R45-R65LS HP. 0,40€/kpl
    07119905911 torx-ruuvi 4,2x19mm E31,E53,E61,E61N,E83,E91,E91N,F31,RR2,RR2N,RR3,RR3 N HP. 0,25€/kpl
    07129904681 torxpultteja 10x65mm E30,E31,E32,E34,E36,E38,E39,E46,E53,E60,E63,E64,E7 0,E70N,E71,E83,E85,E86,E90,E90N,E92,E92N,E93,E93N, F01,F02,Z3 HP. 2€/kpl
    07146949380 korimutteri 30mm E-srj,F-srj,G-srj,Minit HP. 1€/kpl
    07147177492 Pohjapanssarinruuvi E46,E70,E70N,E71,E72,R50,R52,R53,R56,R56N HP. 1€/kpl
    11111743118 hylsyjä 14,5mm E12,E21,E23,E24,E28,E30,E31,E32,E34,E36,E38,E39,E4 6,F-srj,G-srj jne. HP. 3€/kpl
    21511202659 pallotappeja 2.5CS-3.0CSL,2500-3.3Li,E12,E21,E23,E28,E30,E32,E34,E36 Z3 roadster,Z1 ilmeisesti sama on 21511223281 E31,E38,E39 HP. 3€/kpl
    23121222208 vaihdelaatikon etustefa E31 HP. 15€
    23001222888 torxpultteja 8x60mm E31,E32,E34,E36,E38,E39,E46,E52,E53,E60,E61N,E63,E 63N,E64,E64N,E65,E66,E67,E68,E70,E70N,E71,E72,E90, E90N,E92,E92N,E93,E93N,F01,F01N,F02,F02N,F03,F03N, F04,F06,F07,F10,F11,F12,F13,R56,RR1,RR1N,RR2,RR2N, RR3,RR3N,RR4 HP. 2€/kpl
    23411466134 vaihdekepin ohjaustappeja 114,E12,E21,E23,E24,E28,E3,E30,E31,E32,E34,E36,E38 ,E39,E46,E52,E53,E60,E60N,E61,E61N,E63,E63N,E64,E6 4N,E81,E82,E83,E83N,E85,E86,E87,E87N,E88,E89,E9,E9 0,E90N,E91,E91N,E92,E92N,E93,E93N,F10,F11,F12,F13, F20,F25,F30,NK,Z1,Z3 HP. 1€/kpl
    33111206166 perän nopeusanturin tiiviste, uusi nro 33111210739 E23,E24,E28,E30,E31,E32,E36,Z1,Z3 HP. 1,50€/kpl
    33211227944 vetarin pultteja E31,E32,E38,E39,E60,E61N,E63,E64,E82,E90,E90N,E92. E92N,E93,E93N HP. 2€/kpl
    33306760349 Lukkomutteri E38,E39,E46,E52,E53,E60,E60N,E61,E61N,E63,E63N,E64 ,E64N,E65,E66,E67,E70,E70N,E71,E72,E81,E82,E82E,E8 3,E83N,E84,E85,E86,E87,E87N,E88,E89,E90,E90N,E91,E 91N,E92,E92N,E93,E93N,F01,F01N,F02,F02N,F04,F06,F0 7,F07N,F10,F10N,F11,F11N,F12,F13,F15F20,F21,F22,F2 5,F26,F30,F31,F32,F33,F34,F36,I12,RR4,RR5 HP. 1€/kpl
    33306786187 Epäkeskoprikka
    E39,E53,E60,E60N,E61,E61N,E63,E63N,E64,E64N,E65,E6 6,E67,E81,E82,E82E,E84,E87,E87N,E88,E90,E90N,E91,E 91N,E92,E92N,E93,E93N,F01,F01N,F02,F02N,F04,F06,F0 7,F07N,F10,F10N,F11,F11N,F12,F13,F20,F21,F22,F25,F 26,F30,F31,F32,F33,F34,F36,F80,F82,I01,I12,RR1,RR1 N,RR2,RR2N,RR3,RR3N,RR4,RR5 HP. 2€/kpl
    33326768900 Kuusiokantamutteri E60,E60N,E61,E61N,E63,E63N,E64,E64N,E65,E66,E67,RR 1,RR1N,RR2,RR2N,RR3,RR3N
    HP. 1€/kpl
    33306760591 Epäkeskopultti E38,E39,E52,E60,E60N,E61,E61N,E63,E63N,E64,E64N,E6 5,E66,E67,RR1,RR1N,RR2,RR2N,RR3,RR3N
    HP. 4€/kpl
    33306760592 Epäkeskoprikka E38,E39,E52,E60,E60N,E61,E61N,E63,E63N,E64,E64N,E6 5,E66,E67,RR1,RR1N,RR2,RR2N,RR3,RR3N
    HP. 2,50€/kpl
    35311103849 polkimen kumistoppari E-srj,F-srj,Minit 1,50€/kpl
    51131970866 maskinkiinnikkeitä E31 HP. 0,50€/kpl
    51161954117 sisäpeilin peitekumeja E30,E31,E32,E34,E36,E38,E39,E46,E52,E53,E53,E64,E6 5,E66,E67,E83,E89,E89,E90,E91,E92,E93,F03,Z1,Z3 HP. 4€/kpl
    51441938868 sisäkatonkiinnikkeitä E31,E32,E34 HP. 0,50€/kpl
    51478126285 verhoilukiinnikeitä E31,E34,E36,E39,Z3 HP. 2€/kpl
    51711932996 sivuhelmakiinnikkeitä naaras 9,1mm E24,E28,E30,E31,E32,E36,E46,E60,E61,E63,E64,E65,E6 6,E67,E83,E87,E90,E91,E92,E93,F01,F02,F04,RR4 HP. 0,50€/kpl
    51718108130 sivuhelmankiinnikeitä E31 HP. 2€/kpl
    [/B]54128113222 kattoluukun liukuleuat E31 HP. 3€/kpl
    51471954694 verhoilukiinnikkeitä E31,E32,E34 HP. 6€/kpl
    51491946195 verhoilukiinnikkeitä E30,E31,E32,E34 HP. 1,50€/kpl
    51497061429 peitetulppa musta E61,E61N,F07N HP. 1€/kpl
    52207115704 verhoilukiinnike E30,E46,E60,E60N,E61N,E70,E70N,E71,E81,E82,E82e,E9 0,E90N,E91,E91N,E92,E92N,E93,E93N,F25,F30,F31,R60, R61 HP. 1€/kpl
    61138355134 kaapelikiinnike E31,E34,E53,E60,E61,E63,E64 HP. 2€/kpl
    61211377835 kulmaliittimiä E-srj,F-srj,G05,Minit HP. 2,50€/kpl
    61311392192 mikrokytkin ikkunanlasku E31 45€/kpl
    61617248410 korvaava 61611497070 etupyyhkijän varren suojamuovi R50,R52R53,R55,R56,R57 HP. 7€/kpl
    63211389706 takalampun kulmapalantiivisteitä E31 HP. 25€/kpl
    61311383335 peilin kytkin E31, E36 HP. 7€
    Tavara on Turussa. Yhteydenotot privaan.
    Tarjouksia ja omia näkemyksiä saa esittää, tosin tuotteet on hinnoiteltu dynaamisesti.
  • Laku
    • 17676
    Ylöspäin.
    • Laku
      • 17676
      Nostellaanpas tätä.
      • Laku
        • 17676
        Sekalaista pikkuosaa tarjolla.
        • Marine Engineer
          • Apr 2012
          • 3
          Osat Torx pultteja
          Tervehdys Vantaalta, Laku
          Ostaisin sinulta noita pultteja ja useampia koko muutama/koko.
          Soita 0400 400889
          Terveisin, Veikko Haapanen
          • Laku
            • 17676
            Koitan lisäillä osia jossakin vaiheessa, näitä yhä on tarjolla aloituspostauksessa.
            • Laku
              • 17676
              Ylöspäin!
              • Laku
                • 17676
                Ylös taas.
                • Laku
                  • 17676
                  Uppista.
                  • Laku
                    • 17676
                    Ylöspäin!
                    • Laku
                      • 17676
                      Tällaisia tarjolla.
                      • Laku
                        • 17676
                        Ostelepa omasi pois.
                        • Laku
                          • 17676
                          • Laku
                            • 17676
                            Nostellaanpas, jos kiinnostusta löytyisi.
                            • Laku
                              • 17676
                              Uppista.
