Bmw 535gt
  • natemalone
    • Jan 2023
    • 1
    Bmw 535gt
    The Best Mop for Vinyl Floors: Short Buying Guide & Recommendation (2022)
    Despite having a reputation for being more durable than natural hardwood floors, vinyl floors are still considered as a type of sensitive flooring. Without the right technique or cleaning tool, there’s a risk of damaging the floorboard. And vinyl floor planks can’t be easily or cheaply repaired!
    So, in this guide, we’ll show you how to pick the best mop for Vinyl floors. And afterward, we’ll give you our top recommendation to give you a headstart in the search for your new floor mop!
    What to Look for in a Good Vinyl Floor Mop
    • The Design
    There are many kinds of floor mops out there, but not all of them will play well with vinyl floors.
    To start, you can’t go wrong with a basic flat mop. This type is the cheapest out of them all, but it’s also the most versatile and safe. The mop has a long handle, and a rectangular flat cleaning head. Attach a mopping pad to the bottom of the cleaning head, and you’re ready to go!
    It’s the best type for people who are shopping on a budget or just simply want a mop that does the job.
    The second type of mop worth considering are spray mops. If you don’t want to drag a heavy water bucket with you every time you have to mop the floor, this type is perfect.
    It comes with an integrated water tank. Fill the tank with plain or soapy water and when you need to dampen the floor, you can just squeeze the trigger on the handle and a sprayer near the cleaning head will spritz the floor for you.
    The last type on our list are electric mops. They cost a fortune, but if you have a large budget and want the best mop possible for the money, electric mops will no doubt be your best bet.
    This type comes with an electric motor that spins mopping pads at the bottom of the mop at high speed. You only need to guide the mop on top of the stain or dirt on the floor and it will do the bulk of the job for you. No need to scrub it back and forth!
    • Mopping Pad Material
    For vinyl floors, microfiber is best. It is soft and highly absorbent. Microfiber pads also has the advantage of being very common and cheap.
    But plain microfiber pads may not work very well against stubborn spots and stains. In that case, check out chenille pads. They come with long, stringy fiber that can scrub at the stains and take them out. Despite being more abrasive than your average microfiber mopping pad, chenille pads are safe for use on vinyl.
    Best Mop for Vinyl Floors: Bissell SpinWave Expert (20393)
    The Bissell SpinWave Expert 20393 is an electric mop. It costs a lot, sure, but if you have the budget, then you will quickly find out that it’s well worth the investment.
    In our test, the mop worked excellently on vinyl floors. It was able to scrub out all of the dirt and debris we laid on the floor, including difficult types of debris like pet hair and cereal bits.
    The SpinWave is rather heavy since it also comes with an electric motor. However, our testers reported that Bissell compensated for a heavy weight with a very ergonomic handle design. The vacuum is also very maneuverable despite its weight and size.
    All in all, if you’re looking for the best, we’re fairly certain that this is it.
    You Might Also Enjoy:
    Best Mops for Vinyl Floors: Top Rated and Reviewed
    A Comprehensive Guide to Getting the Best Mop for Vinyl plank Floors
    Conclusion
    We hope this short article on the Best Mop for Vinyl Plank Floors: Buying Guide and TOP Suggestions has been helpful to you! If you have any other questions you would like to ask, leave a comment or send TheKingLive’s editorial an email. We’ll get back to you as soon as we can.
