K: e30 318i -> m50b25 swap /problem
  • RagnarM
    • Oct 2014
    • 58
    • Raisio
    I have 86 year e30 preface.
    I have m50b25 under hood, connected wires by m50swap "howto" requires... But heres a "little" problem.. I dont have spark at all... But it gets power on ignition..
    Could some1 help ??
  • Make H.
    • 1278
    • Kokkola
    Pls post your wiring diagram...could also check the crank position sensor? Does the fuel pump work?
    • RagnarM
      • Oct 2014
      • 58
      • Raisio
      I found the prob. I may have wrong ecu.. I need 413 bosh ecu with red sticker.. Am going to check the crank sensor anyways..
      M50b25 fuel pump doesnt work until i get spark..
      All wiring is done 100% correctly
      • Make H.
        • 1278
        • Kokkola
        If you have vanos ecu in non-vanos car it doesn't run even though it starts, but yet the fuel pump should run for 1-2 sec when you turn ign. switch on....
        • RagnarM
          • Oct 2014
          • 58
          • Raisio
          Heres the BIGGEST problem, i found out today.. Its not an m50b25 its m50b20.
          Guy sold me wrong motor...
          And the problem why it dosnt start is the CRANK SENSOR witch doesnt work, and thats why ecu doesnt give the spark..
          If any1-s interesting then the motor pkt. Is for sell... Whole package incl gearbox,ecu,wiring, allthe stuff u need.
