Hi,
I just moved here and I have a 1991 BMW 325. Recently, whenever I turn on the air ventilation I smell a lot of gas fumes in the car.
Found this web link on the internet about the problem:
NHTSA Campaign ID Number: 94V066000
Recall Data: 04/11/1994
Components: FUEL SYSTEM, GASOLINE
ELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Units Affected: 116300
1991 BMW 325 FUEL SYSTEM, GASOLINE
Recall Date: 04/11/1994
Summary:
FEED FUEL HOSES CAN HARDEN AND "SET" OVER TIME, ALLOWING A SEEPAGE OF FUEL AT THE CONNECTION BETWEEN THE HOSE AND THE ENGINE FITTING. THE CLAMP USED TO HOLD THE HOSE TO THE FITTING IS UNABLE TO COMPENSATE FOR THE HARDENING OF THE FEED FUEL HOSE.
Consequence:
FUEL SEEPAGE BETWEEN THE FEED FUEL HOSE AND THE ENGINE FITTING CAN RESULT IN FREE FUEL IN THE ENGINE COMPARTMENT, WHICH COULD RESULT IN A FIRE WHEN EXPOSED TO A SOURCE OF IGNITION.
Remedy:
A REDESIGNED FEED FUEL HOSE AND HOSE CLAMP WILL BE INSTALLED TO ALLEVIATE THE FUEL SEEPAGE.
Potential Units Affected: 116300
Notes: BMW 325
The above information is for the US cars.
Does any one here have the same problem? how can I bring my old 1991 car to the bmw dealer to fix the problem?
Many thanks for your advice
Bimmer_freak
Summary:
Consequence:
Remedy:
Notes: BMW 325
Bimmer_freak
