E46 ajotietokoneen koodeista
  • Juspe77
    • Mar 2004
    • 25
    Kokeilin saada esiin ajotietokoneen piilotettuja koodeja seuraavasti:
    - Matkamittarin resetointi/nollausnappi pohjaan ja avaimen kääntö ON asentoon => näyttöön tulee "test" teksti
    - matkamittarin resetointinappia painamalla pystyy selaamaan läpi alla olevan listan koodeja 1.0-1.7, mutta ei muita (2-21)
    Mitäköhän pitäisi tehdä, että saisi loputkin koodit näkyviin?? Autona on E46 318 Touring vm. 2000.
    E46 OBC koodit:
    BMW E46 On-Board Computer (OBC) Hidden Codes
    nr example description
    1 Car Engine and cluster data
    1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
    1.1 4nnn K-number
    1.2 690236 Cluster Part #
    1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
    1.4 1200 Week (12)/year of manufacture (2000)
    1.5 09_160 Hardware (09) and software # (16.0) of cluster
    1.6 Not used
    1.7 04__44 CAN-version (04) KI-revision index (44)
    2 (test) Cluster System Test - Activates the gauge drivers,
    indicators and LEDs to confirm function
    3 SI Data
    3.0 1098 Used fuel in liters since last SI (Service Inspection)
    3.1 0231 Periodic inspection days; elapsed days (since last SI)
    4 Momentary Consumption
    4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
    4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
    5 Distance Gone Consumption
    5.0 082 Average mileage; 082=8.2 liters/100km
    5.1 0536 Calc. km to refuel (momentary distance to go)
    6 Fuel Level sensor inputs in liters
    6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
    6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
    6.2 0442+ Indicated value (44.2) and tank phase
    7 Temperature and Speed
    7.0 021+ Coolant/Engine temperature (2.1C)
    7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
    7.2 + Engine speed / Current RPMs 1/min
    7.3 + Vehicle speed / Current Speed in km/hour
    8 Input value in HEX form
    8.0 1d0+ System voltage ADC-Value Hex code
    8.1 26C33C+ ADC Values HG left/HG right
    8.2 0000 ADC Value brake degradation sensor (000=o.k.)
    8.3 18C ADC Value outside temperature
    9 Battery
    9.0 140 Battery Voltage - 140 = UB 14.0v
    9.1 242013+?
    9.2 074_78+?
    9.3 0011+?
    10 Not used
    11 Not used
    12 Not used
    13 GonG Gong Test
    14 Not used
    15 Status cluster I/O-ports (bit codes) 0=low; 1=high
    1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
    Status Digital Outputs (bits) 0=inactive, 1=active
    1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
    16 Not used
    17 Not used
    18 Not used
    19 Lock Status; unlocks functions in range 3-18
    19.0 L-On/L-Off Unlock: press button when "L-Off"
    20 Not used
    21 Software Reset; reset OBC settings
    00 End of test
  • Juspe77
    • Mar 2004
    • 25
    Onko kukaan ylipäätään saanut noita ekstrakoodeja 2:sta eteenpäin näkyviin vai oletteko jääneet 1.0-1.7 välille.
    Kertokaahan vähän kokemuksianne.
    • Nito
      • 27
      • Vaasa
      Katsoppa tuolta: http://www.btcf.fi/forum/showthread.php?t=19545
      Itse sain näkyviin kaikki nuo ekstrakoodit noilla ohjeilla. Kohdasta 19 saat avattua lukituksen.
      • Juspe77
        • Mar 2004
        • 25
        Kiitos vinkistä Nito. Tuolla toisessa threadissa näyttäisi olevan sama ominaisuuslista kun mulla, mutta noilla ohjeilla se vaan pompsahtaa 1.7 kohdasta takaisin 1.0. Nimimerkillä "petri--" näyttäisi olevan sama ongelma kuin mulla (myös 00-vuoden auto).
        Minkä vuoden E46 sulla on alla, kun kerran saat kaikki koodit näkyviin?
        • Nito
          • 27
          • Vaasa
          Mulla on 01-vuoden auto.
          Paina heti ton "test"-tekstin tultua näyttöön sitä matkamittarin resetointinappia. Listan pitäisi mennä järjestyksessä 1 -> 2 -> 3 -> jne. Ei siis 1.0 -> 1.1 -> 1.2 -> jne. Vasta kun pysähdyt hetkeksi esim. kohtaan 7 pystyt selaamaan sen alivalikkoja 7.0 -> 7.1 -> 7.2 -> jne. Vaikuttaa siltä, että jäät selaamaan kohdan 1 alivalikkoja.
          Toivottavasti nämä ohjeet auttaa.
          • Juspe77
            • Mar 2004
            • 25
            Joo... oikeassa olit. Olin liian hidas reset napin kanssa. Antamillasi ohjeilla homma lähti toimimaan. Oikein paljon kiitoksia! Kerro, kun olet tulossa Tampereelle, niin tarjoon bisset.
            • Nito
              • 27
              • Vaasa
              Eipä kestä. Ittelläki meni hetken aikaa oppia se logiikka. Hyvä, että sait homman toimimaan!
