BMW E46 316ti vm 2002 nokka-akselin tunnistin vikaa
  • Redain
    • 516
    Elikkäs:
    Ollu jo hetke aikaa vikana ja molemmat nokka-akselin tunnistimet vaihdettu.
    Tosin eriin aikoihin.
    INPA antaa tälläiset viat:
    Date: 08.04.2013 17:42:57
    ECU: ME9K_NG4
    JobStatus: OKAY
    Variant: ME9K_NG4
    RESULT: 5 error in error memory !
    2781 CDKPH - Camshaft sensor inlet
    Error counter: 3
    Logistic counter: 65
    1. Umweltsatz
    Mileage 2960 km
    Engine speed (nmot) 3240.00 /min
    Engine temperature (tmot) 141.75 degrees C
    Ambient temperature (tumg) -19.50 Grd C
    Supply voltage (ub) 5.75 V
    2. Umweltsatz
    Mileage 26770 km
    Engine speed (nmot) 10200.00 /min
    Engine temperature (tmot) 143.25 degrees C
    Ambient temperature (tumg) 143.25 Grd C
    Supply voltage (ub) 24.02 V
    Lage der Phasenflanken oder Einbaulage ausserhalb Toleranz
    Test conditions fulfilled
    Error present now and already stored
    Error would not cause a warning lamp to light up
    Error code: 06 27 81 64 05 03 41 01 28 51 FD 26 3D 0A 75 FF
    FF FF FF FF FF FF FF FF
    2731 CDKENWS - Camshaft control inlet - VANOS
    Error counter: 0
    Logistic counter: 17
    1. Umweltsatz
    Mileage 2950 km
    rel. air filling (rl) 21.00 %
    wnwi1_u 65.00 Grad KW
    2. Umweltsatz
    Mileage 115200 km
    rel. air filling (rl) 191.25 %
    wnwi1_u 255.00 Grad KW
    Anschlagadaption ausserhalb gueltigen Bereich
    Error code: 06 27 31 62 01 00 11 01 27 51 FD 1C 41 2D 00 FF
    27BB CDKANWS - Camshaft control outlet-VANOS
    Error counter: 0
    Logistic counter: 21
    1. Umweltsatz
    Mileage 2950 km
    Engine temperature (tmot) 142.50 degrees C
    rel. air filling (rl) 41.25 %
    Supply voltage (ub) 14.51 V
    2. Umweltsatz
    Mileage 78280 km
    Anschlagadaption außerhalb gültigem Bereich
    Error code: 06 27 BB 62 01 00 15 01 27 51 FE 37 9A 1E 94 FF
    2782 CDKPH2 - Camshaft sensor outlet
    Error counter: 0
    Logistic counter: 0
    1. Umweltsatz
    Mileage 2940 km
    Ambient temperature (tumg) -25.50 Grd C
    Supply voltage (ub) 14.88 V
    2. Umweltsatz
    Mileage 26800 km
    Error not occurred yet
    Error code: 06 27 82 04 01 00 00 01 26 51 FF 1E 9E 0A 78 FF
    27C1 CDKPHM - Master camshaft sensor
    Error counter: 0
    Logistic counter: 0
    1. Umweltsatz
    Mileage 2940 km
    2. Umweltsatz
    Mileage 26800 km
    keine Masternockenwelle vorhanden
    Error not present now, but already stored
    Error code: 06 27 C1 24 25 00 00 01 26 51 FF 1E 9E 0A 78 FF
    Mitä tehdä ja onko mitään suoraa apua?
    Yritin löytää söörtsin avulla näistä mutta en ihan löytänyt suurta apua.
    Tosiaan auto on E46 316ti N42 tekniikalla
    Voiko olla vaikutusta jos antureita ei vaihdeta samaan aikaan?
    Olis mukavaa jos sais apuu nopeesti kun auton katsastus on edessä.
    Verhoilutyöt, vikakoodin luenta, hiekkapuhallustyöt Turku, Rauma seudulla. Yhteydet yv tai Redain(at)gmail.com
  • MNi
    • Nov 2008
    • 3145
    Ei pitäisi olla merkitystä vaikka olisi anturit vaihdettu eri aikaan.
    Lämpötilat lienee fahrenheiteissä, ei kuullosta terveeltä tuommoinen +140 C.
    Pikahaun veikkaus: KLIK.
    Mites se käyntipuoli, vaikuttaako muuten normaalilta?
    • Redain
      • 516
      Taitaapi nuo olla faareteissa ku ohjelma näyttää kaike lämpöarvot siin muodossa.
      Auto käy ja kukkuu ihan nätisti.
      Ainut että välillä ei suostu lähtemään käyntiin ilman pient tappeluu
      • janituz
        • Jul 2008
        • 858
        • nummi-pusula
        Tämä kylmänä ja vain kylmänä? Onko ketju/kiristin/laahaimet vaihdettu?
        e46 330da -01
        E46 320d -00
        E30 323i -85 "pommikone"
        Projekti: E30 325i -86
        Projekti: E21 315 -83
        Ex: E30 318i mit m10i -89
        • Redain
          • 516
          Kylmänä pääsääntöisesti kyllä. Mutta ilmenee myös lämpimänä silloin tällöin.
          Ei ole vaihdettu ks palikoita. Et vika vois johtuu tälläsestä?
          Tarviik työ jotain erikois työkalui? Ja mistä mahtais palikkaa alkaa tilaa jos tälläst remonttii alkaa tekee?
          • Cell
            • 7035
            • Uusikaupunki
            Tarkistaaksesi jako-ongelman:
            Venttiilikoppa irti, pyöritä kone 1 syl YKK. Onko nokan takapään koneistetut pinnat pystysuorassa kanteen nähden?
            325i -08
            i3 REx -17
            M5 -98 Imolarot
            • janituz
              • Jul 2008
              • 858
              • nummi-pusula
              jos tekee kylmänä ni kannattaa koittaa vaihtaa öljynpaineen rajotinventtiili. Onko käynnistäessä kun on tilanne ettei käynnisty, moottori sen oloinen ettei olisi puristuksia lainkaan?
              e46 330da -01
              E46 320d -00
              • Redain
                • 516
                Ei niinkää puristukseton olo, tai ei ainakaan suuri.
                Mut usein ku auto lähtee kylmänä käyntii nii röpöttää pahasti ja ei ota kierroksia, tai kuulostaa että yläkerta olisi kuiva.
                Kuuluu välillä (ei usein) pien muotoinen "pamahdus" tai paremminkin koneesta kuuluu pieni "pöhähdys" jonka jälkeen käynti normalisoituu.
                En tiedä mistä johtuu ks tilanne mutta tämän tilanteen sattuessa sammutan heti auton ja käynnistän uudelleen jonka jälkeen kone käynnistyy suht normaalisti.
