320d e90 laturin vapaakytkin.
  • MaIh
    • Jul 2017
    • 2
    Olisiko kenelläkään tietoa millainen laturin vapaakytkin tuohon 2005 vuoden 320d 120kW moottoriin todella käy. Kun olen tilannut varaoskirjonen mukaisen vapaakytkimen, niin hihnalinja heitää laturista ulospäin n. yhden uran varran ( verrattuna alkuperäiseen kiinteään moniurahihnapyörään ). No tämähän tekee sitten sen että moniurahihna menee yhden hihnauran verran ilmastointikompressorin pyörästä sivuun ja ennenpitkään tuo moniurahihna menee poikki.
    G
    M
    T
    Detect languageAfrikaansAlbanianArabicArmenianAzerbaijani BasqueBelarusianBengaliBosnianBulgarianCatalanCebu anoChichewaChinese (Simplified)Chinese (Traditional)CroatianCzechDanishDutchEnglishEspera ntoEstonianFilipinoFinnishFrenchGalicianGeorgianGe rmanGreekGujaratiHaitian CreoleHausaHebrewHindiHmongHungarianIcelandicIgboI ndonesianIrishItalianJapaneseJavaneseKannadaKazakh KhmerKoreanLaoLatinLatvianLithuanianMacedonianMala gasyMalayMalayalamMalteseMaoriMarathiMongolianMyan mar (Burmese)NepaliNorwegianPersianPolishPortuguesePun jabiRomanianRussianSerbianSesothoSinhalaSlovakSlov enianSomaliSpanishSundaneseSwahiliSwedishTajikTami lTeluguThaiTurkishUkrainianUrduUzbekVietnameseWels hYiddishYorubaZulu
    AfrikaansAlbanianArabicArmenianAzerbaijaniBasqueBe larusianBengaliBosnianBulgarianCatalanCebuanoChich ewaChinese (Simplified)Chinese (Traditional)CroatianCzechDanishDutchEnglishEspera ntoEstonianFilipinoFinnishFrenchGalicianGeorgianGe rmanGreekGujaratiHaitian CreoleHausaHebrewHindiHmongHungarianIcelandicIgboI ndonesianIrishItalianJapaneseJavaneseKannadaKazakh KhmerKoreanLaoLatinLatvianLithuanianMacedonianMala gasyMalayMalayalamMalteseMaoriMarathiMongolianMyan mar (Burmese)NepaliNorwegianPersianPolishPortuguesePun jabiRomanianRussianSerbianSesothoSinhalaSlovakSlov enianSomaliSpanishSundaneseSwahiliSwedishTajikTami lTeluguThaiTurkishUkrainianUrduUzbekVietnameseWels hYiddishYorubaZulu
    Text-to-speech function is limited to 200 characters
    Options : History : Feedback : DonateClose
  • MaIh
    • Jul 2017
    • 2
    No niin tulipa sitten tuo laturin vapaakytkin ongelma ratkaistua näin. Lähdin kokeilemaan BMW 320i N46 moottorin laturin vapaakytkintä (12317560483), ja siinähän nuo kuusi hihnauraa on aivan laturin rungon puoleisessa reunassa. Mutta kytkimestä puuttu tällainen D25xd17xS3.5 lieriömäinen uloke. No siihen löytyi Lahden ETRA:sta soviterenkaita (D24xd17 DIN 988) n.4mm verran. Mitkä sitten tuonne vapaakytkimen ja laturin akselin olkapäätä vasten laitoin, jotta tuo vapaakytkin ei purisi kiinni laturin runkoon. Ja sitten vapaakytkin 75Nm momenttiin kun tuo laturi on mallia VALEO. Ja hyvin ainakin vielä on toiminut ja hihna on linjassaan eikä hihnan kiristäjä enään niin kiivaasti pompi ja hihna lopetti huutamisensa kylmäkäynnistyksen yhteydessä ja sen jälkeen.
