e34 ajotietokoneen keskikulutuksen kalibrointi
  • segru
    • Dec 2003
    • 133
    • HKI
    mites kyseinen toimenpide tehdään kun 525tds tieturi näytti 6.5l/100km ja todellinen oli 8.1l/100km ?
    Yritin searcilla mut ei osunut mun silmiin !!
    kantapään kautta!
    1200gs adventure -08
    318is class II -94
    323i -84
    320i/323i -85
    320i/6 -81
    325i coupe -92
    A4 1.8tq -01 ???
    ex.16 x BMW + paljon muita
  • bemu-freak
    • 277
    • Kerava
    Oli tästä aiemmin juttua, mutta sivulta
    Löytyy ohje
    The fuel consumption correction factor is a locked function of the OBC so before you can access it, you must first unlock the OBC - Access the OBC test menu by simultaneously pressing the 1000 and 10 keys so that the display changes to "TEST". With the 10 & 1 keys enter 19 on the display and then press the S/R button. Add the current day and month (as it is known to the OBC) and enter this value and then press the S/R button, the OBC should now be unlocked. To access the fuel consumption calibration factor you once more need to simultaneously press the 1000 and 10 keys so that the display changes to "TEST". With the 10 & 1 keys enter 20 (Be careful not to enter 21 as this will reset the OBC) on the display and then press the S/R button - you should now see something like 1000 CORR, this is your current correction factor. To calculate your new correction factor use the following:
    new_correction_factor = old_correction_factor * actual_mpg / obc_mpg
    Enter your new correction factor into the OBC using the 1000/100/10/1 keys and then press the S/R button. If you want to relock the OBC - enter function 19 again then press the C/F button to lock.
    BMW E61 525iA -05, E38 740ia -97
    ex E53 3.0DA 04, E90 320DA -05, E36 325CiA -94, E34 525iAT -95, E87 120DA -05, E60 530DA -03, E39 523iA -96, E30 318i -90, E39 530DAT -99, E34 525i 24V -89, E36 316i -95, E28 520i -87, E21 318i -82, 2002 -69
    • Leka
      • 7701
      • Vilppula
      Originally posted by segru View Post
      ...Yritin searcilla mut ei osunut mun silmiin !!
      Eikö :think
