Mitä meinaa code tacho??
  • alppisiili99
    • Sep 2011
    • 1
    • suomi
    bmw e34 mittaristossa lukee code tacho mitä tarkoittaa?
  • Haju69
    Administrator
    • 16543
    • Leppävirta
    Googlella jostain ulkomailta vastaus tuohon:
    this type of issue only occurs when the battery gets discharged. The instrument cluster electronics get confused, and need to get reset. Make sure the battery is fully charged, or it may occur again.
    Try disconnecting the battery terminals over night, reconnect terminals, and see if the message goes away.
    Make sure you have the radio code available (if the original radio is installed), or your radio won't work after disconnecting the battery.
    Edit: Ja monenlaista tarinaa näkyy löytyvän kun kirjoitat googleen: code tacho bmw E34
    LMC 630 R Liberty 2,8tdi '99
    E32 Diamantschwarz 750iL '94
    E36 Hellrot 328i M-Sport ´96
    • Muppe
      • 1866
      • Östermyra
      E61 530dA M-Sport
      E39 520iA Touring
      ex. E34 525iA
      ex. E34 535iA
      ex. E34 520i
      ex. E34 520i
      ex. E36 320i
