Kukaan tehnyt E39 Lampun pleksien/lasin putsausta, tai ylipäätään.
  • Maxon
    • 162
    • Lahti
    Omat pleksit alkaa olemaan sen verran harmaat että niille on pakko alkaa pikkuhiljaa jotain tekemään ja Löysin netistä alla olevan ohjeen pleksin/lasin putsaukseen, mutta onko kukaan tehnyt sitä joko samalla tavalla tai sinnepäin? apuva kaivattas, ei viittis hankata niitä piloille kysymättä muilta ensin
    Ohje:
    following information on how to refinish your E39 headlight covers to get rid of scratches and "sandblast":
    Materials needed:
    600-grit wet/dry sandpaper
    1000-grit wet/dry sandpaper
    automotive paint cleaner
    Meguiars #17 plastic polish
    Meguiars #10 plastic cleaner
    First open the hood and tape off the corners of the fenders that protrude towards the headlamp covers.
    Next, having a steady stream of water flowing over the headlamps, knock off the major pits and crap off the assemblies with the 600-grit paper using very light pressure. You don't want to create any major scratches - just remove the junk off the face.
    Next - still with a steady stream of water over the headlamps, follow-up with the 1000-grit paper - using very light pressure, smooth the surface out as much as possible. This may take a little while, but is crucial in getting a smooth surface. After you are done with this and the water dries, you will have a very smooth but a very hazy surface - good.
    ** NOTE: The following can either be performed with some elbow grease or a small random orbital buffer. **
    Next - with a dry surface and a clean terry cloth towel, rub the automotive paint cleaner into the lenses. This will take the majority of the haze out of the lenses.
    Follow-up with the Meguiares #17 Plastic Polish and #10 Plastic Cleaner with separate, clean towels.
    When you are done, your lenses will be crystal clear. Cleaning the interior glass lenses is another story.
    ~Two Beer Or Not Two Beer, That's The Problem~
    ~ShakesBeer~
  • Fabsu
    • 1754
    Sit jos joku päällikkö, millä on ollu aina 10 englannissa, viitsis vielä kääntää ton tekstin Suomeksi, niin vois yrittääkin tota. Eiköhän ton luulis tepsivän E36 myös. Omat lampun lasit on tosi nuutuneen näköset.
    e30 318i -88
    • Maxon
      • 162
      • Lahti
      Todella karkeesti käännetty
      Materiaalit:
      600:sta vesihiomapaperia
      1000:sta vesihiomapaperia
      automotiven? maalin puhdistajaa...ko? ( http://www.autogeek.net/megmedprempa.html )
      Meguiars #17 kiillote ja #10 putsaaja -> http://www.superiorcarcare.net/megplascar.html
      Ekaks avaa konepeitto ja teippaa/suojaa lamppujen ympäriltä löytyvät pelti ja muovi osat.
      tokaks valuta vettä lasille/pleksille kokoajan (hangattavalle pinnalle) ja hankaa todella pientä painamista käyttäen 600:lla vesihiomapaperilla että suurimmat ja isoimmat paskat lähtee irti, elä paina kovaa ettet naarmuta pintaa.
      kolmanneks valuta vettä edelleen hangattavalle pinnalle 1000:lla vesihiomapaperilla ja tässäkään älä paina kovaa. Kun vesi on kuivunut ja kun olet tämän tehnyt niin sinulla pitäisi olla tasainen mutta sumea pinta, hyvä.
      neljänneks kun pinta on kuiva ja sinulla on puhdas liina, hankaa linsseihin Automotiven "maalin puhdistajaa" , tämä poistaa suurimman sumuisuuden.
      Sen jälkeen tee sama #17:sta ja #10:llä käyttäen eri liinoja (kaksi erillistä, ei samalla)
      Koko hommelin jälkeen sinulla pitäisi olla kristallinkirkkaat lasit.
      Mitähän korvaavia tuotteita mahtaisi olla suomessa vai tietääkö kukaan saako noita Meguiars tuotteita suomesta?
      ~ShakesBeer~
      • ahiltune
        • May 2003
        • 747
        • Åbo
        Onkos kukaan kokeillut käyttää tuohon sitä Cabrion takalasin puhdistustahnaa!
        No one can be told what "rm -rf /" does - you have to see it for yourself.
        • Fabsu
          • 1754
          Joo kertokaahan jos olisi jotain muitakin keinoja saada kirkkaaksi ne lasit. Uudet suojalasit on aika kalliit.
          e30 318i -88
          • fraatti
            • 4666
            ostakaa multa halvalla melkein uuden veroiset lasit lamppuihin..
            F11 535dX LCI
            • Fabsu
              • 1754
              Varmaan kannattais laittaa tonne myydään osioon, jos haluat niistä päästä eroon. Mihin malliin ja paljon hintaa?
              e30 318i -88
              • Dilletuning
                lowrider
                • Jul 2005
                • 1148
                • Nivala
                Iteltä lähti ainakin kirkkaaksi ku myllytin ne koneella samalla ku auto myllyttelin. Tuo mulle ne nivalaan niin saadaan kiiltoa autoon ja lamppuihinki-->Pätee myös takavaloihin. niissä sitä himmentymää yleensä vasta onkin.
                ///M3 cab. 3,0 supercharger
                Mercedes Sprinter 2004 316CDI kuorma-auto
                E39 530d M-sport -00 -RIB-
                VW Carawelle 2,5TDI 128kW T5 -07-RIB-
                Dodge Ram 2500 400hv/1300Nm "vetojuhta"-RIB-
                VW Multivan 2,5 TDI T5 -RIB-
                • juhape
                  • 321
                  • Pieksämäki
                  Lähteekös ne kirkkaaksi ihan tavallisella hioma/kiillotus vahalla eli sillä aineella millä tommosen himmentyneen maalipinnan saa kiiltäväksi? Esim. Farecla
                  Kun ei oikein uskalla kokeilla ennekuin olis varmempaa tietoa.
                  -BMW 530d Touring -14 LCI
                  -Ford Mondeo 2.0 TDCi -19 150hp Titanium Wagon
                  -Zetor 6245-89
                  -David Brown 996 -76
                  -MF 35 -58
                  -Tunturi Super Sport -85
                  -Tunturi Super Sport -77
                  • KFZ-Koenig
                    • 2900
                    Tästä oli toinen topic vähän aikaa sitten. Muistaakseni Loyal kirjoitteli asiasta ainakin.
