e39 penkin lämmitin
  • Will_E39
    • 920
    e39 penkin lämmitin
    mistähän vikaa etsimään kun penkinlämmittimen pistää päälle niin pysyy muutaman sekunnin päällä ja sammuu autona 520ia-97 ja penkkeinä ihan normit kangaspenkit
    e39 520ia-96
  • Will_E39
    • 920
    ja siis ongelma ainoastaan kuskin penkissä:think
    e39 520ia-96
    • kosmik
      • 167
      WDS:n kuvauksen mukaan katkos lämpötilasensorin piirissä kytkee lämmityksen pois päältä. Tuossa on myös ohjeet vikadiagnoosin tekoon.
      Mulla oli tota vikaa keväällä, mutta penkin alla olevan liittimen kopelointi auttoi silloin. Istuinosa ei tosin lämpiä vieläkään, vain selkänoja.
      Seat heating
      The cushion surfaces and backrests are heated with the seat heating system.
      Function
      The seat heating can be switched on as of terminal 15 by pressing the button. The LED integrated in the switch lights to act as a function indicator.
      The seat heating is switched off by pressing the button once again or switching off the ignition.
      The seats are heated by means of four heating elements incorporated in the upholstery.
      Cushion surface
      Seat moulding and thigh support
      Centre section of backrest
      Backrest moulding
      The electronic circuitry integrated in the switch controls and monitors the seat heating function.
      The heating temperature can be adjusted by means of a potentiometer within the range from 20 o C to 42 o C. The temperature is measured by a temperature sensor in the seat upholstery and passed on to the electronics integrated in the switch.
      The electronic circuitry controls the heating function such that the set temperature is reached in the fastest possible time. The heating capacity is then reduced.
      Note
      Current supply to the heat conductor of the seat heating electronics is interrupted if the vehicle battery voltage drops below 11.8 volts. The function LED installed in the switch however remains on. Current supply to the heat conductor is resumed when the battery voltage again reaches 11.8 volts.
      Fault monitoring
      The seat heating electronics monitors the temperature sensor and the heating elements for faults.
      If a break or short occurs at the temperature sensor, the seat heating is switched off in order to prevent overheating.
      Fault indicator
      If a fault is recognized, the function LED installed in the switch flashes for 12 seconds when the fault occurs, or, if the fault is already present, when the seat heating is switched on.
      Flash code
      A flash code shows what faults the electronic circuitry has currently detected.
      Flash code output is started by following procedure:
      Switch off ignition
      Press and hold the button for seat heating
      Switch on ignition (terminal 15) with button depressed
      Release the button and press it again briefly
      The following faults can be indicated:
      Flashing / Defect
      Once / Switch faulty (potentiometer or electronics) or switch overheating due to a short-circuit
      Twice / Temperature sensor has break or short
      3 times / All 4 heating elements broken or have a short (probably break or short in wiring harness)
      e39 528iA
      ex: e36 325TDS
      • Jesper
        • 1447
        Mahtaiskohan se jotenkin luulla että ylikuumenee...?
        Kuvittelis oikosulussa ainakin polttavan sulaketta.:think
        EDIT: kosmik oli nopeampi ja antoi hyvät ohjeet.
        • Will_E39
          • 920
          näin mäkin sen kuvittelisin mut joskus se toimii vähän pidempään mut aina se itellään sammuu:think
          e39 520ia-96
