Launch Control
  • suffeli
    • 559
    • JKL
    Launch Control
    Netistä ladatussa manuaalissa puhutaan launch controllista. Oman auton manuaalissa siitä ei ole puhetta. Vaatiiko se jonkun varusteen vai onko kaikissa?
    G31 530d
  • PNM2
    • Mar 2015
    • 1338
    Kiinnostaisi tietää kans mutta kai tuo kokeilemallakin selviää. Edelliseen ohjeeseen vielä lisäyksenä BimmerFestista:
    Originally posted by https://www.bimmerfest.com/threads/launch-control.1257980/
    Launch control is available when the engine is at operating temperature (uninterrupted journey of at least 10km)
    Press the Traction Control button to turn off DSC (confirm DSC OFF lamp ON)
    Engage lever to S
    Press brake firmly
    Press accelerator beyond the resistance at the full-throttle position and hold the kick-down. A flag symbol is shown in the instrument cluster
    The start engine speed is adjusted. Release the brake within 3 seconds
    After launch control has been used, the transmission will require approx. 5 minutes to cool down before LC can be used again.
    NA5 iX3 50 xDrive​
    ex: G26 i4 M50
    ex: G30 530e xDrive M-Sport
    ex: F11 525d xDrive
    ex: F11 520d
    ex: E91 318i
