N62b44 vs N62b48
  • jori
    • 1014
    N62b44 vs N62b48
    Kovasti olen mieltynyt tuohon E63 kuutoseen ja tarkoitus olisi moinen hommata heti CLS pihasta lähtee uudelle omistajalle.
    Aika paljon olen lukenut huonoa tuosta N62b44 moottorista. Onko tuo b48 yhtään parempi miltään osin eli onko merkittäviä parannuksia kestävyyden suhteen tuossa?
    Ilmeisesti sama jäähdytysneste putki voi vuotaa lohkon välissä jne.
    Mietin vaan onko järkeä laittaa enempi rahaa 650 ostoon jos samat viat seuraa?
    Ajossa: iX xDrive50 Fully Charged
    Exät: Tesla Model S LRR, G05 e45 M-Sport, F15 M50d, F15 30d, F11 535d, F30 Active Hybrid, E60 M5, E63 645CiA, W219 MB 350 CLS, E31 850iA, E90 320dA, E39 523iA, E39 540iA ACS, E36 328i Cab, Porsche 968, E36 M3, E39 540iA, E31 850iA, E36 M3, E34 525i, E30 325i M-Tech II, E30 325i kv, E30 318i, E30 316.
  • Rale
    • Jul 2005
    • 1483
    • Porvoo
    BMW N62 Engine
    Available from 2001, the BMW N62 was a V8 petrol engine that replaced the M62 engine. A completely new engine, the N62 had a 90-degree ‘V’ angle and was initially available in 3.6- and 4.4-litre capacities (the N62B36 and N62B44, respectively). The N62 was updated for the N62B48 engine that was developed for the 2004 BMW E53 X53 4.8is, while the N62 Technical Update (N62TU) was introduced in April 2005.
    The N62 won the overall International Engine of the Year award in 2002, as well as the ‘Best New Engine’ and ‘Above 4-litre’ categories.
    N62 crankcase
    The N62 engine had a one-piece, ‘open deck’ aluminium-silicon alloy crankcase with cylinder bores that were hardened through exposure honing – a ‘soft stripping’ process that removed the aluminium from the cylinder surface such that hard silicon particles remained. Furthermore, the N62 engine had a cast-iron crankshaft with five main bearings, fracture-split forged connecting rods and cast aluminium alloy pistons.
    For the N62 engine, crankcase vapors were carried from the crankcase and into the cylinder head covers through labyrinth separators (one per cylinder head). The oil which accumulated on the walls of the labyrinth separators then flowed into the cylinder head via a siphon and then back to the sump. The remaining vapors were passed to the engine for combustion via the pressure control valve in the intake manifold.
    N62 cylinder head
    The N62 had die-cast aluminium cylinder heads with double overhead camshafts per cylinder bank that were made from chilled cast iron. The intake and exhaust camshafts had variable vane-type VANOS (variable valve timing) and were driven by a maintenance-free toothed chain (one for each cylinder bank).
    The N62 engine also featured BMW’s ‘Valvetronic’ system which varied intake valve lift between 0.3 mm and 9.85 mm, according to engine speed and load. With partial lift, the slower cylinder filling resulted in more turbulence in the combustion chamber for better mixing and more efficient combustion.
    The N62 engine featured a variable intake manifold (BMW’s Differentiated Intake System, or DISA) which enabled intake pipe length to be adjusted according to engine speed for more efficient cylinder filling and scavenging. The intake manifold was located in the engine’s ‘V’ and mounted on the cylinder head intake ports. Adjustment from the long to short intake path would commence at 3500 rpm and be progressively reduced up to 6200 rpm.
    The N62 engine had a secondary air system in which additional air would be blown into the cylinder head exhaust ducts during the warm-up phase – this would cause thermal secondary combustion which reduced non-combusted hydrocarbons (HC) and carbon monoxide (CO) in the exhaust gas.
    Each cylinder bank was fitted with a 4-2-1 exhaust manifold which, with the catalytic converter housing, formed a single component. Furthermore, a ceramic-bed pre-catalytic converter and a ceramic-bed main catalytic converter were arranged in series within the catalytic converter housing.
    Ignition
    The N62 engine had sequential fuel injection which was controlled by the DME 9.2 system. The cylinder firing order was 1-5-4-8-6-3-7-2.
    N62B48 Update
    The N62 was updated for the N62B48 engine that was developed for the 2004 BMW E53 4.8is. Based on the N62B44, bore was increased to 93.0 mm (from 92.0 mm) and stroke to 88.3 mm (from 82.7 mm) for the 4799 cc N62B48 engine. Compared to the N62B44, changes for the N62B48 engine included:
    The crankshaft bearing caps featured apertures to improve ventilation lengthways in the crankcase and reduce pump and splashing losses;
    The introduction of a steel crankshaft for greater strength;
    Symmetrically-formed and narrower connecting rods;
    A stronger aluminium-silicon alloy cylinder head;
    Revised exhaust manifolds which prevented residual gases from entering the combustion chamber to improve cylinder charge and torque progression at lower engine speeds;
    Omission of the secondary air system;
    A modified oil pan that was made from sheet steel (previously cast aluminium) and had a 16 mm lower bottom section; and,
    An increased capacity oil cooler.
    The N62 Technical Update (N62TU) engine was introduced in April 2005 and, compared to the N62, changes included:
    A stronger steel crankshaft (previously cast iron);
    A larger, two-channel air intake duct (developed due to lower bonnet of the E65.II and E66.II 7-Series);
    The fully variable Differentiated Intake System (DISA) was replaced by a two-stage intake system. Whereas the previous intake manifold was made from magnesium, the N62TU intake was manufactured from glass fibre reinforced plastic;
    For the inlet and exhaust valves, stem diameter was reduced from 6 mm to 5 mm and the reduced moving masses provided higher rpm capability;
    New long-life (160,000 kms) platinum spark plugs which were repositioned forward and had a hook electrode;
    Update DME 9.2.2 which had a new 56 MHz processor, LSU 4.9 lambda oxygen sensor, HFM 6 hot-film air-mass meter and oil level measurement software; and,
    Omission of the secondary air system.
    Engine CC Power
