e83 x3 BMW CD Soitin
  • toNmbbA
    • Apr 2009
    • 2329
    Modet poistakoon jos aiheelliseksi näkee.
    Eli siis. Auto x3 vm 2005 jossa BMW cd soitin. Onko tähän soittimeen mahdollista jollain keinolla saada rakenneltua Usb väylä vai joutuuko koko soittimen vaihtamaan? Tietoa soittimista / johtosarjoista joilla saa ratin painikkeet vielä toimimaan?
    -Tomi
  • chevy55
    • Sep 2013
    • 275
    • Vesilahti
    Kaivelin Ebayta ja esimerkiksi tällaisia löytyi:
    Oli noita muitakin.
    Ainakin väittävät rattikontrollien toimivan:
    Specifications(suora googlekäännös saksasta):
    - By direct transfer without loss of quality music
    - Reset button for easy restarting example with a defective file
    - Dimensions 105x60x20mm ( cigarette )
    - Brushed metal top
    - Supports MP3 and WMA files
    - USB sticks to 16Gb
    - Up to 16Gb SD card and SDHC
    - AUX input for 3.5 mm jack plug ( no control available )
    - Search within the title possible ( Vor-/Rücklauf )
    - Stop the use of the original kit, or when you select another source to the radio ( eg FM )
    - Remember when you turn the last position played there on (even with ignition off)
    operation:
    - As usual, the buttons on the radio and steering wheel
    - Disc buttons to jump between the different folders
    - With the track buttons between tracks
    - The maximum number of folders depends on the radio
    - Track numbers appear until 99 , then starts again at 01
    installation:
    - The adapter is used on the back of the radio
    - When the system with on-board monitor in the trunk to the radio module
    - The radio does not have to be mp3 compatible and can for example also have a tape drive
    - No activation or programming required in the workshop
    Scope of delivery:
    - USB adapter box
    - Cable BMW Flachpin about 1.2 m
    - 3.5mm Auxiliary cable
    - Operating instructions in German
    Delivery is only possible within Germany. Cash on delivery only inside of germany .
    • Surina
      • Mar 2005
      • 222
      • Lohja
      x53
      • toNmbbA
        • Apr 2009
        • 2329
        Olikos näihin saatavilla jotain bolt on soitinta jolla toimisi vielä nuo ratin napit? :think
        Siis kuten esim e39 on saatavilla dynavinin tekelettä?
        Eli siis parempaa soitinta etsimässä jossa samalla olisi usb.
        • buksin-1
          • Dec 2003
          • 4592
          • Keski-Pohjanmaa
          -Tomi
          Helpoin on vaihtaa uudempi x3:n soitin, jossa on mp3 tuki.
          SISUSTAT modaukset
          • ockelbo4500
            • Mar 2007
            • 923
            • Sotkamo--Oulu
            Iän vanha keskustelu, mutta jatketaan tästä.
            Minkä ikäinen soitin tukee noita MP3 tiedostoja.
            Oma auto 2005 mallinen, mutta rekisteröity 2004 puolella. Soittimena ihan perus cd soitin ja tuo ei ainakaan näyttäisi soittavan MP3 tiedostoja.
            Voiko tuon tilalle vaihtaa business CD:n ja mistä vuosimalleista käy tuo soitin ?
            Omassa soittimessa ilmeni nyt myös sellaista vikaa, että kun soitin ollut pitempään päällä niin soittaa cd:tä vain muutaman minuutin ja sanoo sitten että cd error. Jos laitat uudestaan soimaan niin tekee saman vain entistä nopeammin eli saattaa soittaa enää esim. minuutin ja sitten katkeaa.
            Miten näissä menee tuo vahvistinasia. Onko tuossa mankan perässä muuta kuin esivahvistin, koska ainakin omassa on pikkuvahvistin tavaratilassa ? Vai onko tuo tavaratilan vahvistin vain lattiabassoille.
            BMW E84 X1 18dXdrive -14
            Ex BMW E83 X3 2.0d - 04
            Ex, Suzuki SX4 S-Cross -13
            Ex, E46 320 d Touring -01
            Ex , E34 TDS Touring -95 AVK special
            • ockelbo4500
              • Mar 2007
              • 923
              • Sotkamo--Oulu
              Oisko kellään vastauksia edellisen postaukseni kysymyksiin ?
              • ockelbo4500
                • Mar 2007
                • 923
                • Sotkamo--Oulu
                Itse itselleni vastaten tässä asiasta lisätietoa, jonka löysin saksan bmw foorumilta tms. kun aikansa etsi.
                2005 vuosimalliset ja uudemmat X3 business cd- soittimet soittaa MP3 tiedostoja. Tavallinen cd ei soita niitä. sitten faceliftissa tuo business cd nimi oli ehkä poistunut ja sitten tavallinenkin mankka soittaa mp3 tiedostot.
                Itsellä siis ihan perusaudioilla oleva X3. Siinän on etu- ja takaovissa kajarit ilman diskantteja ja subbarit penkin alla. Niiden koosta en ole ihan varma, mutta erään tiedon mukaan kaikissa x3 malleissa ne olis 8" kooltaan. Vahvistin tavaratilassa ajaa vain etupäätä eli etuovia ja bassoja. Mankka ajaa takaovia eli ne on vähän niinkuin avustavat kajarit.
                Kysymys edelleen, että voiko tuon perus cd:n tilalle vaihtaa business cd soittimen suoraan plug and play ?
                • Ceet
                  • Jul 2009
                  • 27
                  En osaa sanoa meneekö uudempi soitin suoraan vanhan tilalle (todennäköisesti ei), mutta oma äksä ei soittanut MP3:sia vaikka varusteina ei ollu perus radio/CD-soitin (6 CD boksi + pro navi). Omasta mielestä helpointa oli ostaa foorumin kautta AUX liitin valmiiksi asennettuna ja koodattuna:
                  Nyt voi soittaa musaa kännykästä/mistä tahansa missä on 3.5mm output. Hyvin toimii!
                  2022 G21 330e LCI
                  • ockelbo4500
                    • Mar 2007
                    • 923
                    • Sotkamo--Oulu
                    Juu siis auxin laittaisin, mutta kun nimenomaan sitä ei saa muuhun kuin business cd:n tai Professional Navin yhteyteen. Ei siis onnistu ainakaan netin mukaan laittaa sitä auxia tuohon perussoittimeen.
                    Soittimen ei tarvitse olla sen uudemmasta mallista kuin nykyinenkään, mutta 05 tai 06 mallinen business cd soitin mielessä.... Kävisikö se siis vain vaihtamalla paikalleen ?
