E30 with swapped m54 registration
  • Berny
    • Jun 2014
    • 13
    • Pietarsaari
    Hello beemer fans.
    Just before summer cruising season starts, I'm planning to import to Finland e30 cabrio, factory 318i, with swapped m54. Engine swap has been registered on title, and it comes with EU legal certificate, done in Latvia.
    Question- is there going to be any difficulty to do registration here in Finland? Is the previous engine swap certification will be accepted or I will need to make a new certification here?
  • makkis
    • 5152
    • Kouvola, Savisto
    What M54 engine there is?
    What brakes there is?
    Virallinen Xhp jälleenmyyjä
    • Berny
      • Jun 2014
      • 13
      • Pietarsaari
      Sorry, not m54 but m52b28
      Brakes stock e30 from 325i
      • makkis
        • 5152
        • Kouvola, Savisto
        Are the Abs?
        I think all should be ok then.
        Go and try, they tell you what to fix if needed
        • Berny
          • Jun 2014
          • 13
          • Pietarsaari
          It never had ABS from factory.
          How does normally that registration of a engine swap going Finland?
          • makkis
            • 5152
            • Kouvola, Savisto
            Ok, if it is newer than -86 (i dont remember exact time) it has to have abs, because it needs to be like 325i
            Normally it goes like, you have to have lots of papers so you can testify that brakes and everything under the car are like 325i
            Then from engine you have to have what car it is originally from and in the worst case, dynotest paper.
            But this can be very easy too, because all are registered already in the car in eu country:think
            • Berny
              • Jun 2014
              • 13
              • Pietarsaari
              Thank you for information. Currently look's like I'm not going to move it over in this summer. So all the hopes for next year. I also think that it should be easy to do because that engine swap is already registered in EU country.
              For this summer got my self an awesome entrance car in cabrio world.
              Proud owner of LaguneGruen 318i cabrio
