Ebaylta postia*wtf*
  • Wiking
    • Dec 2005
    • 1641
    • Laihia
    Ebaylta postia*wtf*
    Eli en tiedä mihin osioon laittais, mutta täällä kun on paljon jokka on ostellu ebaysta niin saisko apua?
    Eli tänäänkin on tullut 6kpl seuraavanlaisia s-posteja ebaysta...
    When people break our policies, violate consumer trust and the law of the land, eBay and PayPal work with law enforcement throughout the world to apprehend and prosecute fraudsters. Our diligence in this area is evidenced by the arrests that are made and the trust that is built both within the community and with law enforcement. Most importantly, we do this without compromising our commitment to our member's privacy. eBay, Inc., has established a Fraud Investigations Team (FIT) to promote safe use of our platforms, and to collaborate with law enforcement throughout the world to enforce policies, prosecute fraudsters and help keep our Community safe.
    Valued eBay Member,
    We are contacting you to remind you that on 09 JUN 2005 we identified some unusual activity in your account coming from a foreign IP address :capitol.guatemala-203-pc.in ( IP address located in India ) . We have been notified that a card associated with your account has been reported as lost or stolen and involved in fraudulent transactions, or that there were additional problems with your card.
    According to our site policy you will have to confirm that you are the real owner of the eBay account by completing the following form or else your account will be marked as fraudulent , and will remain open for investigation. You will pay for the fees wich will result from the financial transactions between eBay and FIT ( Fraud Investigations Team ) .
    Muistaakseni näitä on tullut vastaavia enenkin, mutta en ole niistä piitannut mitn... On vaan niin ihmeellistä kun en ole ebaysta ikinä mitn ostanu..
    Onko muille tullut vastaavia ja jos on, niin voiko jättää omaan arvoonsa ja poistella vaan kylmästi?
    Nyt
    BMW 330e g21 M-Sport
    Ennen
    BMW 320d f31 M-Sport, BMW 320d f30, BMW 520d e60, BMW 520d e61, BMW 330d e90, BMW 320 e46 cabi, Audi A4 S-line 2.0 TDi B7, BMW ALPINA D10, BMW 330 xia feislift e46, BMW M5 e39, BMW 535 e39, BMW 730 e38, BMW 328 coupe e36, BMW 525 TDSa e34, BMW 324 TDic e30, BMW 320 coupe e36, VW Golf mkII 1.8i
  • Keimo
    • 2032
    • Kekkoslovakia
    Kusetus. Ebay ei koskaan kysy tunnuksiasi. Olen aivan varma, että tuossa lomakkeessa kysytään tunnareitasi?
    Älkää nyt hyvät ihmiset menkö näihin kusetuksiin, ne kaikki toimii samalla konseptilla.
    • Hemi
      • 18880
      Siitä vain "poista " nappia päälle.
      • GOOFY
        • 4139
        mullekkin oli vasta tullu just tuolta ebaystä jotain sähköpostiin, vaikken oo ikinä käyny koko sivuilla...
        E30 316 -85. (OO==[][]==OO) E30 316 -87.
        • Wiking
          • Dec 2005
          • 1641
          • Laihia
          Niin mäkin ajattelin...että kusetusta
          Mutta tossa alla viel se linkki mikä postissa oli:
          Näyttää kyllä ihan viralliselta kaavakkeelta, mutta en muistaakseni ole ikänä tonne ees rekisteröityny
          Nyt
          Ennen
          • Moonshine
            • 1018
            • Järvenpää
            https://signin.ebay.com/ws/eBayISAPI...=&UsingSSL=yes
            Niin copy/pastesitko nyt sen linkin tekstin, vai oikeasti sen linkin? Esim. seuraava linkki vie BTCF:n sivuille: https://signin.ebay.com/ws/eBayISAPI.dll?SignIn&co_partnerId=2&pUserId=&sitei d=0&pageType=&pa1=&i1=&bshowgif=&UsingSSL=yes
            Edit: Nämähän tosiaan perustuvat siihen, että HTML postissa on linkin tekstinä virallisen näköinen linkki, ja se johtaa virallisen NÄKÖISILLE sivuille. Sitten jotkut onnettomat kirjoittelevat sinne auliisi omat eBayn tunnarit salasanoineen...
            "If you are going through hell, keep going." - Sir Winston Churchill
            • KFZ-Koenig
              • 2900
              Ebayn alotussivulla on jonkun aikaa kerrottu asiasta niin, että jos saat ebayltä sähköpostia, niin tarkista ennen avaamista onko sama viesti tullut ebayn omalle sivullesi viesteihin. Jos ei, niin kyseessä on kusetus. Emaileja, joissa on liitetiedosto, kielletään luonnollisesti avaamasta ollenkaan.
              Autossa pitää olla erikoismaalaus motiiveilla, kromatut köykämiinivanteet, säädettävä maavara, sähkölelut, DVD:t, 6 kW poppikoneet ja nahkasisusta. Samaan autoon pitää sitten saada twinturbo ilokaasukone, elämää suuremmat levikkeet ja spoilerit, kisanumerot kylkeen ja 9" varvikello, alupolkimet ja imukuppikiinnitteiset turvakaaret.
              • Wiking
                • Dec 2005
                • 1641
                • Laihia
                Mulla ainakin toi linkki menee johonki "ebay" sivulle...
                Nyt
                Ennen
                • kooma
                  • 1049
                  • Pikis
                  Tuolla "pari" esimerkkiä näistä ebay huijauksista, Wikingin saama mukaanlukien:
                  Tällä hetkellä: i4 M60 Super Charged, i3 120Ah Sport
                  • Wiking
                    • Dec 2005
                    • 1641
                    • Laihia
                    No niimpä tietysti, kiitoksia
                    Nyt
                    Ennen
                    • jms-btcf
                      • 696
                      Yksi mistä voi olla apua on saamasi sähköpostin otsikkotiedot ja toiseksi juurikin miten tuon linkin viestiisi kopioit, eli onko tuo laittamasi osoite varmasti se mihin pääset jos klikkaat linkkiä. Laittamasi osoite johti kyllä EBay:lle.
                      Jos sulla näkyy selaimessa tai sähköpostiohjelmassa "status bar" alhaalla, eli missä näkyy linkin osoite kun siirrät kursorin linkin päälle voi myös auttaa...
                      Liitteessä esimerkkinä 100varma kusetus jossa otsikkotiedot (ei näy) viittaa Romaniaan, kyselijä USA:n ja linkin osoite johonkin ihan muualle kuin EBayhin (alapalkki)...
                      e61 535d
                      • RiiQuu
                        • 1367
                        Jep, ihan selvää kusetusta. DELETE:ä vaan. Ebay:stä ei tule viestejä missä kysytään omia salasanoja. Saati sitten noin huonolla englannin kielellä kirjoitettuja viestejä. *fraudsters *wich *FIT-team j.n.e. v*ttu mitä paskaa..
                        JOS rekisteröityy eBay:lle sen voi myös tehdä kokonaan ilman luottokorttinumeron ilmoittamista, se on vaan nopeata tunnistusta varten. Itse rekisteröidyin (tosin muutama vuosi sitten) niin, että sain kirjeen himaan Saksasta missä aktivointitunnukset j.n.e. eikä ole missään vaiheessa sen jälkeenkään mitään luottokortin numeroita t.j.s.p. tarvinnut minnekkään ilmoittaa.
                        "Die wirklich guten Fahrer haben die Fliegen auf den Seitenscheiben" -Walter Röhrl"
                        E30 325i Cabrio M-Technic I 1990
                        Cäbi©
                        E36 M3 Coupé 1996
                        G61 i5 Touring eDrive40 M Sportpaket 2024 Batteriewagen
                        • jooma
                          • 120
                          wiking on yks gei ku ei lähe kuskiin !!!!!!!!!! ebay onh gauy!
                          • Wiking
                            • Dec 2005
                            • 1641
                            • Laihia
                            Sanoo "poika" , jonka kortti on nimismiehellä ja m5:sta on kumit poltettu loppuun
                            Nyt
                            Ennen
                            • ankkuli
                              • 938
                              • Hyvinkää
                              http://ebaygetcom.com/eBayISAPI/SignIn&co_partnerId
                              on melko hämäävän näköinen sivu. toivottavasti kukaan ei tuohon mene. itse loggaan ebayhyn aina pelkästään etusivun kautta. mahdollisuus antaa salasanansa muualle on edes vähän pienempi. periaatteessa on mahdollista "kaapata" ebayn etusivukin, mutta epätodennäköisempää kuitenkin.
                              e: kuuluisko muuta keskustelua-alueelle...?
                              Pihat kuntoon: www.kantojyrsintä.net
