Q: How much?
  • Mardo
    • Oct 2007
    • 60
    Q: How much?
    How much boost/HP can M5 stock s38b36 engine take?
    Question should not be hard to answer i think
    Engine is repaired fully!!! and stock.
    Cheers!!
  • Mumtsi
    • Nov 2008
    • 282
    • Kotka
    315HP @ 6900rpm and 360Nm @ 4750rpm
    - Isi mikä toi on?
    - Jonkinmoinen auto jolla pääsee helvetin kovaa..
    • Pekkiz
      • 342
      Hän kysyi myös siis ahtoja
      F36 ///M-Sport
      • unitron
        • 265
        • Naantali
        Niin kysymys oli että kuinka paljon ahtoja s38b36 kestää vakiona.
        -Turku Connection-
        E39 525ia
        Ex: E39 523i
        Ex: E34 530i M-Sport
        Ex: E34 525i Touring
        Ex: E60 530i
        Ex: E39 523i
        Ex: E30 316
        Ex: E28 520i
        • Mardo
          • Oct 2007
          • 60
          Yes, im building one turbo s38b36 engine and need to know where is
          this critical point where this engine can't handle the boost.
          has anyone links of 600-800hp stock turbo s38b36 engine threads.
          • Carbonfiber
            • 5224
            • Hki 43
            I think no one has.
            Z3 Roadster 2.8 '98
            • Jonsku
              • Sep 2002
              • 4651
              It has quite a high CR as stock so it cant' take "any" boost stock.
              You need to lower the CR, and when you're at it you should change pistons at the same time to get all out of it.
              Check www.pure-pf.com / forum / projekt. Lots of turboed S38's there
              ex. Alpina D10 Touring #33/94
              ... and many more
              • Mardo
                • Oct 2007
                • 60
                stock CR is 10, this should not be problem, there is only no room for making mistakes! with lowered CR is it only safer to owerload.
                some timeago here was a 650hv project tahat used stock parts.
                and then it was sold.....no-one knows where
