Ajotietokoneen näyttämän keskikulutuksen korjaus
  • surface
    • Sep 2008
    • 257
    Eli pystyykö tuota mitenkään korjaamaan. Auto on E46 isolla ajotietokoneella. Suuttimen vaihdon jälkeen näyttää noin 0.8 l / 100 km väärin. Todettu monella tankillisella ja ennen vaihtoa näytti juuri oikein.
    E46 -03 330d * 160 kw * 500 Nm
  • Dunky
    • 4927
    • Kotka
    Tuolta jotakin
    As some of you may know, the BMW On-Board Computer (OBC) holds more functions than is documented, including a very nice instrument panel test. I managed to get a lot of this information from the web, but it was far from complete. Subsequently I asked my dealer for the missing info, but they could not provide the complete list either. Following is a list for the items I could find, they work in my car (E46 323i). I gather most of them also work in the E36 models. Who can tell what the missing entries represent (especially functions
    9.1, 9.2 and 9.3 which are very mysterious) ?
    Instructions to access the hidden OBC functions:
    1. Hold Trip Reset while turning ignition key to On position
    2. OBC should show "Test"
    3. Use Trip Reset to select function 19.0 that unlocks all the features
    3. Wait for display to show "Off"
    4. Depress Trip Reset for 1/4 second and release it
    5. With no delay press Trip Reset several times to select one of the following function s
    BMW E46 On-Board Computer (OBC) Hidden Codes
    nr example description
    1 Car Engine and cluster data
    1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
    1.1 4nnn K-number
    1.2 690236 Cluster Part #
    1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
    1.4 1200 Week (12)/year of manufacture (2000)
    1.5 09_160 Hardware (09) and software # (16.0) of cluster
    1.6 Not used
    1.7 04__44 CAN-version (04) KI-revision index (44)
    2 (test) Cluster System Test - Acticates the gauge drivers,
    indicators and LEDs to confirm function
    3 SI Data
    3.0 1098 Used fuel in litres since last SI (Service Inspection)
    3.1 0231 Periodic inspection days; elapsed days (since last SI)
    4 Momentary Consumption
    4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
    4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
    5 Distance Gone Consumption
    5.0 082 Average mileage; 082=8.2 liters/100km
    5.1 0536 Calc. km to refuel (momentary distance to go)
    6 Fuel Level sensor inputs in liters
    6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
    6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
    6.2 0442+ Indicated value (44.2) and tank phase
    7 Temperature and Speed
    7.0 021+ Coolent/Engine temperature (2.1C)
    7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
    7.2 + Engine speed / Current RPMs 1/min
    7.3 + Vehicle speed / Current Speed in km/hour
    8 Input value in HEX form
    8.0 1d0+ System voltage ADC-Value Hex code
    8.1 26C33C+ ADC Values HG left/HG right
    8.2 0000 ADC Value brake degradation sensor (000=o.k.)
    8.3 18C ADC Value outside temperature
    9 Battery
    9.0 140 Battery Voltage - 140 = UB 14.0v
    9.1 242013+ ?
    9.2 074_78+ ?
    9.3 0011+ ?
    10 Not used
    11 Not used
    12 Not used
    13 GonG Gong Test
    14 Not used
    15 Status cluster I/O-ports (bit codes) 0=low; 1=high
    1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
    Status Digital Outputs (bits) 0=inactive, 1=active
    1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
    16 Not used
    17 Not used
    18 Not used
    19 Lock Status; unlocks functions in range 3-18
    19.0 L-On/L-Off Unlock: press button when "L-Off"
    20 Not used
    21 Software Reset; reset OBC settings
    00 End of test
    • Rahu
      • 6465
      Tuo YO lista ei kyllä auta tuohon hätään juurikaan sen enempää kuin radion käyttöohjekaan.. Tosin E39 mallisissa mittaristoissa sen pystyy kyllä kalibroimaan tuon salavalikon kautta mutta E46:ssa se tarvii tehdä testerillä.
      BMW Service
      P.o4oo925441
      [email protected]
      • Luntti
        2Wheel Driver
        • 5021
        • Yka
        Mites e39/e38 mittari kalibroidaan salavalikon kautta?
        • Rahu
          • 6465
          Nro 20 siellä on korjauskerroin minkä vakioasetus on 1000 jota pystyy säätämään +/-250
          BMW Service
          P.o4oo925441
          [email protected]
          • Luntti
            2Wheel Driver
            • 5021
            • Yka
            Selvä.
            • otrim
              • Apr 2009
              • 25
              • ruokolahti
              Mites löytyykö E60 LCI malliin salavalikosta korjauspaikka?
              • Dunky
                • 4927
                • Kotka
                Hyvin sanottu
                • MajorDrake
                  • 7596
                  • Jyväshyvä
                  Löytynee, ainakin pre-lci mallista, sama kohta eli 20.
                  Kerrointa voi vaihtaa muistaakseni 700-1399 (tai 1299)
                  oletus siis tonni eli promillen tarkkuudella voi säätää...
                  i4 M60 & 991 Turbo S Cab
                  • Konda112
                    • Oct 2008
                    • 92
                    • Pudasjärvi/Oulu
                    Miten toi kerroin pelittää eli jos ajo tietokone näyttää esim 7.5L keskikulutuksen ja tankkaamalla se vie 7.9L niin miten tuota säädetään?
                    • peto2
                      • 8294
                      • Järvikylä (Nakkila)
                      Originally posted by konda112 View Post
                      miten toi kerroin pelittää eli jos ajo tietokone näyttää esim 7.5l keskikulutuksen ja tankkaamalla se vie 7.9l niin miten tuota säädetään?
                      1000/7,5*7,9=1053,333
                      Nakkaa privaa jos tarvetta.
                      • Konda112
                        • Oct 2008
                        • 92
                        • Pudasjärvi/Oulu
                        Ourait Kiitoksia.. pitääpä alkaa laskeen tuota kulutusta ku muistaakseni se jonkin verran heittää..
