osien nimiä suomeksi?
  • bember
    • Dec 2005
    • 479
    • Kirkkonummi
    eli pitäisi hankkia E32:seen osat 3-4 ja 9, mutta mitkä on nimikkeet suomeksi?
    E32 730i STEERING LINKAGE/TIE RODS
    RealOEM.com Home => Select another car => Steering => steering system connectors
    No. Description Supplement Qty From Up To Part Number Price Notes Photo
    01 LEFT TIE ROD LEVER 1 01/1988 31131133557 $139.31
    01 RIGHT TIE ROD ARM 1 01/1988 31131133558 $139.31
    02 Hex bolt M12X1,5X25 6 07119911694 $0.82
    03 Tie rod 2 32211135666 $114.12
    04 BALL JOINT LEFT-HANDED THREAD 1 32211135819 $40.14
    04 BALL JOINT RIGHT-HANDED THREAD 1 32211135820 $40.14
    05 Hex bolt M8X1X30 4 07119911611 $0.71
    06 SPRING WASHER B8 4 07119933096 $0.18
    07 SELF-LOCKING HEX NUT M8X1 4 07129922770 $0.24
    08 SELF-LOCKING HEX NUT M10X1 6 07129922436 $0.54
    09 TIE ROD,CENTER 1 32211138850 $160.39
    10 Pitman arm D=30MM 1 09/1989 32211137467 $110.65 Cat=Yes
    11 Hex bolt M10X57 1 09/1989 32211137483 $3.33 Cat=Yes
    12 SELF-LOCKING HEX NUT M10 1 07129964672 $0.36
    13 Spacer 1 32211130947 $1.50
    14 Steering arm D=27MM 1 32211136450 $100.43
    15 Rubber Mounting D=27MM 1 32211136452 $26.77
    16 Hex bolt M10X75 1 07119912677 $1.18
    17 Hex nut with plate M10 1 32101133077 $2.50
    Ads by RealOEM
    Cat = Catalyst.
    Sponsored links
    Copyright © RealOEM.com Sponsored links
    http://realoem.com/bmw/showparts.do?...35&hg=32&fg=25
  • peto2
    • 8294
    • Järvikylä (Nakkila)
    raidetangot
    Nakkaa privaa jos tarvetta.
