E91 perus- vs. hifikaiuttimet
  • kiloWatti
    • Aug 2008
    • 88
    Onkos jollakulla faktaa / teknisiä tietoja hifikaiutinjärjestelmästä, verrattuna perussettiin. Olen ostamassa E91/2009 ja mietin tuon hifin tarpeellisuutta/tarpeettomuutta autooni.
    Mutulla varmaan hifi ois kiva, mutta speksejä?
  • kiloWatti
    • Aug 2008
    • 88
    Ja tuosta:
    676 HiFi loudspeaker system
    E81/E82/E87, E90/E91/E92/E93, E60/E61, E63/E64, E65/E66, E83, E70, E85/E86
    Overview
    Product description
    Accelerate into the future of exclusive sound with innovative technologies: with the HiFi loudspeaker system, you can enjoy quality
    with a transparency and brilliance never heard, before.
    Optimum, vehicle-specific adaptation of loudspeaker
    components with separate amplifier/equaliser.
    Your benefits
    Full-bodied, transparent sound quality featuring powerful basses and brilliant trebles.
    Perfect stereo effect at all seats.
    Full-bodied depth of sound even at low volumes.
    Sound effect independent of driving speed.
    Technical information
    The details
    BMW's novel audio concept involves loudspeakers
    in HiFi versions 10 and stands out for its neutral,
    unobtrusive sound. The loudspeakers permit a
    homogeneous playback as well as a higher and
    undistorted maximum level due to their enhanced
    power output.
    Special vehicle-specific features:
    E90/91/92/93, E60/61, E63/64, E65/66
    2 central woofers are positioned under the front
    seats. The necessary enclosure volume for the
    central woofers is obtained by connecting the
    loudspeakers to the side thresholds.
    E81/82/87, E90/91, E60/61, E63/64, E65/66
    amplifier,
    6-channel power amplifier with active crossover
    network and vehicle-specific equalising
    E85/86 amplifiers
    10-channel power amplifier with active crossover
    E60/61, E63/64, E65/66 power ouput
    (at 10% distortion)
    Midrange/treble range 4 x 25 watt
    Bass range 2 x 40 watt
    E85/86 power output
    (at 10% distortion)
    Treble range 2 x 25 watt
    Midrange 4 x 25 watt
    Bass range 4 x 40 watt
    E81/82/87, E90/91/92/93 power output
    (at 10% distortion)
    Treble range 4 x 25 watt
    Oma apu, paras apu. :think
    • viri
      • Jun 2008
      • 35
      Voin omasta kokemuksesta sanoa ettæ kannattaa!!! Soundi on kyllæ aivan toinen verrattuna vakio kaiuttimiin. Tosin saa sillæ rahalla monennækøistæ erillissarjaa sun muuta mutta orginal on aina orginal ja sææstyy paljolta vaivalta ja soundi on kyllæ væhintæænkin mainio!!
      Pahoittelen Norjalaisen næppiksen tarjoamaa jælkeæ...
      F01 740dx LCI 2013 M-Sport
      ex X5 3.0sd - 08
      ex E92 335iA -07
      • kiloWatti
        • Aug 2008
        • 88
        Kiitœs! ;-)
        Panen aamulla tilaukseen.
        • Vanquish
          • Sep 2004
          • 1960
          • Hki
          krhm. Miksi originaalin on originaali? Kun kyseiset ei edes oo bemarin vaan Nokia ym. tekee noita kajareita niin eiköhän se ole sama minkä merkkiset siellä on?`Alkuperäisissä hintaero on veroineen niin järkyttävä että ottaisin laadukkaat erillissarjat ja jäis rahaa levyihinkin.
          • viri
            • Jun 2008
            • 35
            Tarkoitin orginaalilla sitä ettei tarvi ruveta repimään uutta autoa heti auki... mutta jos riittää kiinnostusta, taitoa ja uskallusta ni siitä vaan. Oli elementit sitten kenen tahansa valmistamat, hyvää soundia ne ainakin tarjoavat, hakkaavat mennen tullen entisessä E46:ssa olleet Focalin erillissarjat...mutta makunsa ja toiveneensa kullakin.
            ex X5 3.0sd - 08
            ex E92 335iA -07
            • kiloWatti
              • Aug 2008
              • 88
              Ei prkl, Nokian kaiuttimet? Sit menee uuteen harkintaan..
              Joo, en vaihda itse edes renkaita, on aika paljon muuta tekemistä kuin auton laittelu. Levyt kannattaa muuten ostaa iTunesista 9.99€ hintaan niin jää rahaa vaikka kunnon stereoihinkin.
              • Petri.Kekkonen
                • 7468
                Vieläkö Nokia tekee noita? Sen tiedän että E39:n DSP-subbariloota oli Nokian, mutta että uusissakin olis?
                • Dualfun
                  • 17866
                  • PKS
                  Jos se Nokia arveluttaa (en tiedä onko siellä moisia tosin) niin löytyyhän sieltä listalta vielä se seuraavakin vaihtoehto
                  E28 ///M535i '87 zinnoberrot
                  • Juhis
                    BTCF Honorary Member
                    • 19181
                    Nokia tai ITT merkkisiä kaiuttimiahan Bemareissa on ollut ainakin viimeiset 25 vuotta. Eikä ne Harman/Kardon paketin kaiuttimetkaan tekniseltä toteutukseltaan ole mitään kovin juhlavaa tasoa. Lähinnä johonkin halpatuontantoelementtiin on painettu H/K:n logot. Itsekään en tiedä, onko nuo E90/E91/E92 mallien kaiuttimet Nokian tuotantoa.
                    Mutta mielestäni tuo E91:n hifikaiutinpaketti soi jopa yllättävän hyvin ollakseen tehtaan tekemä hifilaitteisto! Tietysti systeemin toimivuus riippuu siitä, millaisesta soundista tykkää ja millaista musiikkia kuuntelee. Mutta itse olin positiivisesti yllättynyt.
                    Ja E39:ssa kaikki muutkin kaiutinelementit oli Nokian tuotantoa, ei pelkkä subbariloota. Individual High Audio sarjassa saattoi olla jo jonkun muun valmistajan elementit.
                    Sound Factory Bar & Nightclub
                    • Vanquish
                      • Sep 2004
                      • 1960
                      • Hki
                      Tarkennetaan, eli en tiedä mitkä ovat juuri e91ssä mutta aiemmin noita Nokioita nähty eri malleissa.
                      Olisin melkoisesti yllättynyt että jos 1000e hifipaketti vetäis vertoja 300-500e erillispaketille. Ehkä nyt voi olla niin mutta perinteisesti ei ole ollut. Kannattaa ehkä kysellä lisää kokemuksia. Hieno homma jos menty tällä osa-alueella näin paljon eteenpäin.
                      • b mutteri kasa
                        • 1462
                        • Area 03
                        Jos satsaa kaiutin pakettiin niin kannattaa myös ottaa USB ja I-pod liitäntä...äänen laatu on huomattavasti parempaa kuin rallattaa CD:tä
                        BMW F11 530 dA VOLL
                        Carbon-schwarz Metallic
                        BMW E30 325i Sport
                        • kiloWatti
                          • Aug 2008
                          • 88
                          Otin hifipaketin (600e) ja usbiliitännän iPhonelle/podeille. Tilaus lähti vetämään tänään, kajarit+auto pitäis olla miehellä lokakuun lopussa.
                          • Vanquish
                            • Sep 2004
                            • 1960
                            • Hki
                            eI oo mahottoman hintainen! Mitäs muita varusteita ruksit?
                            • kiloWatti
                              • Aug 2008
                              • 88
                              Tinkasin 770:sta 600:aan.
                              Tuossahan se karvalakki, ihan pakollisilla perusvarusteilla otin;
                              - Space Gray metalliväri
                              - musta sensatec
                              - Dynamic-paketti (sporttiratti, -penkit, ja M-alusta+xenonit ym)
                              - Comfort-paketti (sadetunnistin, vakkari, ilmastointiautomatiikka, parkkitutka taakse ym.)
                              - Climate comfort tuulilasi
                              - velourimatot
                              - HiFi-kaiutinjärjestelmä
                              - säilytystilapaketti
                              - kaukovaloassistentti
                              - USB-audioliitäntä
