Apuva!!!! Tahtoo nurkkajumalaa kattoo ajossa!!!!!!
  • roitsi
    • 35
    • Klaukkala
    Olisi v.99 E39 jossa navi ja nurkkajumala :shock: , ohjeet on miten eston saisi pois ,no testattu on noin 100 kertaa :oops: ja esto on ja pysyy , kysymys: jos joku viisas tietäisi onko toista ohjetta, koska ei tolla tunnu lähtevän. :?:
    Kiitos jo etukäteen jos joku kertoo ratkasun.
    :roll:
  • larmatin
    • 1118
    • Perttula
    Re: Apuva!!!! Tahtoo nurkkajumalaa kattoo ajossa!!!!!!
    :roll:
    Kai mä vähän pönttö olen vaikka klaukkalasta olen ittekin niin mikä tuo nurkkajumala on :?: :?: Narinenko pilluniemessä :roll: :?: :juo
    • hannuk
      • 2136
      • Capital
      Jos nuo kysymykset kirjoittaisi ihan selkokielellä, niin voisi saada nopeammin vastauksia.. :wink:
      Täältä löytyy:
      Sulla on ilmeisesti mk II Navi:
      Watch TV / Videotext during driving
      This works on all 5/7 Series with the Mk. I Navigation System (the one with the male voice). On Mk II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work. I know that the trick works on latest 99 7series models as well. But I heard also that some cars sold into the US do not have any TV equipment on board. You will notice this as they do not have any TV option in the main menu. Also latest BMWs sold in Europe (2000 onward, 3/5/7 series) have the trick disabled! The only chance to get the TV running is somewhere hidden in the menu of the BMW Sevice Tester DIS. But up to now I can't thell you where. If I ever find it out, I'll post it here!
      As far as I know the software update for latest navigation CD Roms does not affect or disable this trick.
      • Set ignition to pos. II
        enter TV mode
        enter "settings"
        enter "contrast"
        when the green contrast bar is visible, push the knob and keep it pressed
        turn ignition off (keep button pressed!)
        wait 8-10 seconds (timing must be accurate!)
        release the knob
        turn on ignition again
        Now you can watch TV during driving (but always keep at least one eye on the road - that said)
      - BMW x5 f15 m50d "navetta"
      - Porsche Cayenne S
      - Range Rover Sport 3.6TDV8 HSE
      - plus pari muuta
      • roitsi
        • 35
        • Klaukkala
        jep taisin kirjottaa että on noi ohjeet ,mutta kun ei suostu nurkkajumala näkyy!!!! Perkeeeee........
        Mä lähen himaan :juo
