Nettiautosta bongailtua XXIX
  • TheRipper
    • 5449
    • Paimio
    #646
    Originally posted by Masander View Post
    Minkä BMW:n?
    4-sarjan Gran Coupen. (Tosin se oli M-Sport runflateilla niin tietäähän sen miten epämukava se on niin ei testimenestystä voi odottaakaan)
    F10 523iA 2010
    Ex: E39 528iA 1997
    Ex: E85 Z4 2.5iA LCI 2008
    Ex: E65 745iA 2003
    Ex: E46 318i 1998
    Ex: E34 525iA 1989
    • BeamR
      • 13363
      • Espoon takametsät
      #647
      Kyllä nyt taas pääsee kansanautoilijat paukuttelemaan henkseleitä essolla.
      F46 Gran Tourer -20
      Boxster 2.5 -97
      • mikae34
        • 5048
        • Forssa
        #648
        Samaisessa testissä Kia myös voitti bmw:n, jopa ajettavuudessa...
        Auto on liikkumaväline.
        • AnttiJuhani
          • Nov 2010
          • 2059
          • Kittilä
          #649
          Miksi bmw laittaa sellaiset paskat renkaat alle jos ne pilaa auton
          • Masander
            • Sep 2010
            • 1399
            • Dingolfing
            #650
            Suora lainaus: BMW aims to provide our customers with a premium product that provides ultimate safety with optimum performance and it is always a concern to receive feedback of this nature.
            We chose to include Run-flat technology on our vehicles for the following reasons:
            It is dangerous to stop on any road to change a tyre, especially on a motorway or at night.
            There is no need to have to wait for a breakdown service to arrive.
            Safety and security of the driver and passenger(s) is maintained.
            Alloy wheels are difficult to detach from steel hubs.
            On most cars the spare is under the contents of the boot, and uses boot space.
            It can be tricky to line up the wheel bolt holes with the hub screw holes and match the thread.
            The dirty punctured tyre needs to be removed and stored in the boot.
            Another puncture before the punctured tyre is mended means one is stranded.
            A driver can continue for 150 miles at 50mph with a punctured Run-flat tyre.
            All of our vehicles that use Run-flat technology have their suspension and braking components set up to accommodate Run-flat tyres. Should you decide to change to non Run-flats, it may alter the driving and handling characteristics of your vehicle. It is for this reason that this modification is not recommended by BMW as a manufacturer.
            However, it is possible to have standard tyres fitted. You will additionally need to purchase either a spare wheel with jack and brace set or a mobility kit which can be ordered from the Parts Department of your nearest BMW Approved Dealership.
            • asse21
              • Dec 2005
              • 1290
              Tykkäsin kyllä ajettavuudesta, vaikka dsg jne.. https://www.nettiauto.com/volkswagen/arteon/10089885
              E39 523i
              i3
              • protoni
                • Sep 2008
                • 1380
                Eikä hassumman näkönenkään. Pitäisköhän kirjottaa pukille ja testata kuinka kiltti olen ollut. Eipä ole liikenteessä liiemmin näkynyt.
                • AnttiJuhani
                  • Nov 2010
                  • 2059
                  • Kittilä
                  #653
                  Hyviä pointteja on bmwllä kyllä. Ei taida testiukkelikaan tietää että miksi niitä käytetään bemareissa saati sitä että ovat ylipäätään alla.
                  • mikae34
                    • 5048
                    • Forssa
                    #654
                    Mun mielestä noissa taas ei ole mitään niin ihmeellistä, että ajettavuus pitää sen takia pilata.
                    • Masander
                      • Sep 2010
                      • 1399
                      • Dingolfing
                      #655
                      Kysymys kuuluu, onko vika runflat-renkaissa vai Suomen tieverkon kunnossa (urat, kuopat)?
                      Individual-530e: https://m.nettiauto.com/bmw/530/10129255
                      • Laku
                        • 17676
                        Originally posted by 33d View Post
                        Olisivat voineet vaikka tekstarin laittaa ettei kelpaa ja miksi.
                        Jep, samaa mieltä. Yhdestä paikasta tuli, ettei kiinnosta kilometrien vuoksi.
                        • TheRipper
                          • 5449
                          • Paimio
                          #657
                          On se renkaissa. Ovat ne niin kovat että ei se tiestä parane...ja toki myös rengasmelu on niissä paljon kovempi. Saatanan keksintö tuo runflat on ei siitä mihinkään pääse.
                          Toki jossain Saksan baanoilla voihan tuo henkiäkin pelastaa...tiedä häntä.
                          https://www.nettiauto.com/bmw/520/9949165
                          Haiskahtaa kyllä näppäilyvirheeltä ja pahasti.
                          F10 523iA 2010
                          Ex: E39 528iA 1997
                          Ex: E65 745iA 2003
                          Ex: E46 318i 1998
                          Ex: E34 525iA 1989
                          • AnttiJuhani
                            • Nov 2010
                            • 2059
                            • Kittilä
                            #658
                            No kaikki valmistajat tyylillään kuten myös autoilijat. Mulla ei ole kokemusta uudesta autosta runflateilla vs normaaleilla niin ei voi tietää kumpi parempi. Mut ihmeen iso ero normaali vs runflat renkailla kuulostaa olevan.
                            • EPDM
                              • 4625
                              • Lahti.
                              #659
                              e91 335ix kymppitonilla?
                              Onko
                              https://www.nettiauto.com/bmw/335/10096503
                              ollut jo keskustelua?
                              Onko kuulema ollut taksina???:think
                              Omistajalalta tiedot...
                              "Moi
                              Kyseessä vaimon auto ja pitäisi pitkien työmatkojen takia vaihtaa. Hyvin pidetty. Toinen omistaja, auto ollut meillä 6/2011 274tkm -> . Sitä ennen auto oli taksina. Ei kolaroitu (etu- ja takapuskuri vaihdettu parkkipaikka kolhun johdosta). Perushuollot tehty säntillisesti.
                              Jotain tehtyjä remontteja mitä tuli mieleen.
                              - Öljyt juuri vaihdettu (huuhtelemalla) + Öljynsuodattimen kotelon tiiviste
                              - Eteen puslia v/o 6/18 + takapyörän laakeri
                              - Turbot vaihdettu 3/17 + 2 kpl solenoidi
                              - Startti 2016v lopussa
                              - Tukivarsia 4 kpl 6/15
                              - Kytkin 9/13 300tkm
                              Onko joku Kouvulan suunassa kuka voisi tarkistaa autoa...?
                              Viviendo en Lahiti
                              Vw Corrado vr6
                              • Kanerv4
                                • Feb 2009
                                • 1009
                                Mitäs veikkaatte onko tossa Arteonissa myös Runflatit? Ainakin kaverilla oli kun tilasi uuden R-line passatin isoilla kiekoilla. Toki bemariin ilmeisesti laitetaan aina ne huonoimmat Mutt pakko välillä sanoo että kyllä osa Runflateistä on menny ihan suoraan, vaikka ovat olleetkin Bemarin alla. Monissa X5 autoissa se ei vetele läheskään ellei jopa ollenkaan verrattuna esim f3x
