E92/e93 Lci
  • Convertible
    • 2638
    Originally posted by snoub View Post
    en 335is:tä tiedä mutta eihän tossa e46 330i zhp tainnut olla muuta eroa euro 330i M-Sport II kun punaiset nopeusmittarin neulat :think
    No, ehkä siinä oli jotakin muuta. Ei se niillä kiihdy 5.8sec 0-100.
    Performance package (ZHP)
    2005 BMW 330Ci ZHP
    The performance package was an option given to E46 sedans from 2003 to 2005 and coupes from 2004-2006.[13] It included various aesthetic changes over the regular 3 series, as well as functional and mechanical enhancements. It had M badges on each of its Style 135 wheels, with additional M badging on the multi-function steering wheel and atop the 6-speed short throw weighted shifter. In addition to the standard color options, the ZHP was available in the "Motorsport-only" colors Silverstone Grey, Mystic Blue and Imola Red. It received the "M-Tech II" bodykit standard, 18-inch staggered Style 135 wheels, high gloss anthracite window trim, and the coupe received clear turn signals (headlights, side-markers, and tail-lights) instead of the amber turn signals found on the standard 330Ci.[13] The interior had also been modified with half cloth-half alcantara sports seats (optional upgrade to leather), an alcantara-wrapped sports steering wheel (switched to perforated leather in mid-2005), a shorter M-badged shift knob, anthracite colored cloth headliner, and aluminum "cubed" faux-carbon fiber interior trim (available in silver or black). The instrument gauge cluster was also modified with red needles and polished metal trim rings.[14]
    In the performance department, the ZHP was equipped with the more aggressive BMW Performance camshafts and a DME tune to increase power from 225 hp (168 kW) to 235 hp (175 kW)[13]. The engine redline was also raised from 6,500RPM to 6,800RPM to further take advantage of the new power band and higher power output achieved by the new camshafts at higher RPMs..[14] As a result of the higher redline, the nut that fastens the oil pump's sprocket came with threadlocker pre-applied from the factory to keep the nut from falling off.[15]. The car also received a shorter final drive ratio which allows for faster acceleration; 3.07 vs. 2.93 for manuals and 3.64 vs. 3.38 for the automatic.[14] Car and Driver magazine track-tested the car, which returned a 0-60 mph time of 5.6 seconds and passed through the 1/4 mile in 14.3 seconds.[16] In 2003 the ZHP was the only non-M 3-series to feature a GETRAG 6-speed manual transmission (the Steptronic automatic transmission was not available the first model year (2003), but it was offered from 2004-2006.
    Suspension was modified over the standard suspension with firmer springs and dampers, larger anti-roll bars, stronger front control arm ball joints, a lower ride height, and slightly more negative camber.[14]. The Style 135 wheels also came equipped with the much stickier compound, Michelin Pilot Sport tires, in a staggered configuration with 225/40-18 tires in the front and 255/35-18 tires in the back. [14
    F25 X3 35d
    E87 118i
    E46 330ti
    E46 M3
    E30 M3
    E30 M3 Convertible
    Z3 Roadster
    • snoub
      • 220
      Offtopic..
      Juu on siinä näemmä tuo alcantra ratti vielä lisänä ja jotain muuta pientä. Olisko sitten välityksillä tehty tuo ero kiihtyvyyteen ja ilmeisesti vähän erilainen ohjelma koneessa kuin euro 231hp mallissa :think
      Jenkkien normiversioon eroa on varmasti paljonkin, mutta euro m-sportista suurin osa noista himmeleistä löytyy. Tuo mainittu 225hp tehoinen versiohan ei ole täällä ollut edes saatavana.
      BMW G20 330e M-Sport Dravit Grey metallic Individual
      BMW F15 X5 30d M-Sport Mineralweiss metallic Semivoll
      BMW E21 315 Alpinweiß Originell zustand
      Ex.
      BMW E90 335dA M-Sport 2011 Saphirschwarz Vollaustattung
      BMW E39 530dA M-Sport Topasblau Touring, BMW E39 530dA M-Sport Touring Estorilblau Individual , BMW E46 330d M-Sport II Topasblau, BMW E36 328iA M-Sport Daytonaviolet Individual, BMW E39 528i M fahrwerke Cosmosschwarz, BMW E36 328i M-Sport Cosmosschwarz
      • Convertible
        • 2638
        Offtopic..
        Niin, no me käytämme metric hevosvoimaa ja jenkit ja englantilaiset taas käyttävät omaa erikokoista hevosvoimaa. Lisäksi Jenkkimalleissa katti on jo pakosarjassa ja muuttaa siten tehoja, mutta käytännössa aika samanlaisia tehoja niistä tulee.
        F25 X3 35d
        E87 118i
        E46 330ti
        E46 M3
        E30 M3
        E30 M3 Convertible
        Z3 Roadster
        • snoub
          • 220
          http://en.wikipedia.org/wiki/Horsepower
          Aivan joo, jonkinverran vaikuttaa tuokin asiaan. Miksiköhän ko. erikoismalleja (vaikkapa tuota nykyistä) ei tuoda eurooppaan :think
          Tuollainen zhp olis kyllä maukas noilla suoritusarvoilla
          Ex.
