BMW E34 jarrut & Tehorajat
  • .:miksu:.
    • Feb 2004
    • 352
    Yleissivistyksessä aukkoja, mitä tulee "?" kohtiin?
    malli, Sedan/Touring, moottori, valmistusvuodet, teho (hv/ps), Etujarrut, Takajarrut, ABS
    (V=jäähdytetty)
    518i, S&T, M40B18 4-syl, 1989 - 1993, 113hv, E 302x12, T 300 x 10, ei abs
    518i, S&T, M43B18 4-syl, 1993 - 1995, 115hv, E 302x12, T 300 x 10, ABS
    520i, S, M20B20 6-syl, 1988 - 1990, 129hv, E 302x12, T 300 x 10, ei abs
    520i, S, M50B20 6-syl, 1990 - 1995, 150hv, E 302x12, T 300 x 10, ei abs
    1993-> ABS
    524td, S, M21D24 6-syl, 1988-1992, 115hv, E 302x12, T 300 x 10, ei abs
    525td, S, M51D25 6-syl, 1993-1995, 115hv, E 302x12, T 300 x 10, ABS
    525tds, S, M51D25 6-syl, 1991-1995, 143hv, E 302x12, T 300 x 10, ei abs
    1993-> ABS
    525i, S&T, M20B25 6-syl,1988-1990, 170hv, E V 302 x 22, T 300 x 10, ABS
    525i, S&T, M50B25 6-syl, 1990-1995, 192hv, E V 302 x 22, T 300 x 10, ABS
    530i, S&T, M30B30 6-syl, 1988-1990, 188hv, E V 302 x 22, T 300 x 10, ABS
    530i, S&T, M60B30 8-syl, 1993-1995, 218hv, E V 302 x 22, T 300 x 10, ABS
    535i, S&T, M30B35 6-syl, 1988-1992, 211hv, E V 302 x 22, T 300 x 10, ABS
    520i, T, M20B20 6-syl, 1988 - 1990, 129hv, E 302x22, T 300 x 10, ei abs
    520i, T, M50B20 6-syl, 1990 - 1995, 150hv, E 302x22, T 300 x 10, ei abs
    1993-> ABS
    524td, T, M21D24 6-syl, 1988-1992, 115hv, E 302x22, T 300 x 10, ei abs
    525td, T, M51D25 6-syl, 1993-1995, 115hv, E 302x22, T 300 x 10, ABS
    525tds, T, M51D25 6-syl, 1991-1995, 143hv, E 302x22, T 300 x 10, ei abs
    1993-> ABS
    525iX,T, M50B25 6-syl, 1992-1995, 192hv, E V 296 x 28, T (Huom iX:n oma) 300 x 10, ABS
    525iX, S, M50B25 6-syl, 1992-1995, 192hv, E V 296 x 28, T (Huom iX:n oma) 300 x 10, ABS
    540i, S&T, M60B40 8-syl, 1992-1995, 286hv, E V 302 x 28, T V 300 x 20, ABS
    ?mallisarjan tehokkain?
    M5, S&T, S38B36 6-syl, 1988-1991, 315hv, E V 315 x 28, T V 300 x 20, ABS
    ?ei käy vertailumalliksi?
    M5, S&T, S38B38 6-syl, 1991-1995, 340hv, E V 345 x 32, T V 328 x 20, ABS
    Tehorajat (alustan/jarrujen mukaan):
    520i, M50B20 6-syl, 1990 - 1995, 150hv
    530i, M60B30 8-syl, 1993-1995, 218hv
    540i, M60B40 8-syl, 1992-1995, 286hv
    (+20%)=343,2hv
    Näin se menee
    -Jarru swapista ei mene muutos prosentteja, jos tehdään kanta-autotarkastus.
    -Vertailumalliksi käy mikä tahansa yllä mainittu, mutta ei M5, vuosimallista riippumatta.
    -Missään mallissa ei ole: E V 302 x 22, T 300 x 10, ei abs.
    -Jarrusatulat on Plug & Play asenteisia kaikkien E34 kesken, muuttuu levyn mukaan.
    -Jarrulevyt on Plug & Play asenteisia kaikkien E34 kesken, muuttuu satulan mukaan.
    -Vaikka laittaisi M5 jarrut tavalliseen E34 vertailumalli on 540i
    -Jarrupääsylinterit on tarkistettava ETK:sta! Periaatteessa jos jarruteho kasvaa sytlinteri vaihtuu levyjen mukana, mutta samoja sylintereitä/tehostajia käytetään sekaisin monissa malleissa/vuosimalleissa...
    Voisiko joku vahvistaa tämän mutun:
    -Kaikissa 6-syl ei M5 on sama alusta: Jouset+iskarit, kallistuksenvakaajat
    -Kaikissa 8-syl on sama alusta: Jouset+iskarit, kallistuksenvakaajat
    -ei abs -> ABS muutos vaatii: 1. ABS jarrusatulat 2. Jarrutehostajan ja jarrupääsylinterit 3. ABS ohjain boxin 4. Anturit pyörän napoihin / ABS navat
    5. Johdotukset
    Jarru swapeista ja osien vaihdettavuudesta saa kertoa???
    Onko jarru tehostajat/jarrupääsylinterit samat???
    ei abs -> ABS mitä on vaihdettava???
    www.bmwclub.fi->mallit ja moottorit
    www.bmwe34.net->jarru kokoja
    www.e34.de->mallit ja moottorit
    autopower.se->"1988 ABS standard från 525i.", "1993 ABS och airbag på alla."
    [BTCF search]
    [tämän Threadin kommentit]
    edit: kommenttien perusteella korjailtu ja lisäilty ( 3.6.2005)
  • Kyytsis
    • Mar 2003
    • 3472
    518i, Edessä ei jäähdytettyjälevyjä 302x12, takana ei jäähdytettyjä 300x10, ei ABS:siä
    518i, 520i, 524td -> abs lisävarusteena, ei vakio
    Ja se +20% tulee vain MALLISARJAN TEHOKKAIMPAAN, eli tehoraja 525 jarruilla on =525 tehot.
    • Rossifumi
      • 1030
      • Hamina
      ixuksen kohtaan voipi lisätä ABS:t.
      Maailma on erilainen nelikko kuskin silmin.
      On todennäköistä, että epätodennäköinen toteutuu.
      • tokatamm
        • Nov 2003
        • 40
        520i, M50B20 6-syl, 1990 - 1995, 150hv, E 302 x 12, T 300 x 10, ei abs
        ja mielestäni 525td ja tds:ssä samat jarrut ilman abs:ja.
        • thuttu77
          • Mar 2005
          • 160
          Hmm. Mulla ainakin on VM88 520I jossa muutoskatsastettuna m20b25 2,5L kone ja jarrut on yksi sylinteriset jäähdyttämättömät ei ABS:it
          • Zoui
            • 6350
            Mallisarjan tehokkain on juuri tuo,
            (+20%)=343,2hv
            M5 ei kelpaa vertailuun. (toki M5 mallin osia voi käyttää, vaikka vertailu tapahtuu 540i malliin.)
            Elämä on pihakivestä.
            • HellFire
              • Apr 2003
              • 280
              Miten niin? Eikö se ole missä tahansa autossa +20% kyseessä olevalla alustalla, esim 525 M50 190hp koneesta saa repiä karvan alle 230hp ilman alustan muutoksia.
              Mallisarjan tehokkaimpaan verrataamalla ja lasekemalla se +20% saadaan selville kuinka paljon ko autossa voi tehoa lailliseseti olla (ilman erikoislupia) ja silloin alustan pitää myös vastata sitä tehokkainta mallia. Tämä tekee mahdolliseksi sen, että periaatteessa tekniikanvaihto 518-> M5 on (ainakin on ollut) mahdollinen vaikka M5 ei kuulukkaan mallisarjaan, mutta tehot mahtuvat 540 +20% rajan sisäpuolelle eli 540 tehot 286hp*1.2=343hp ja M5 3.8l 340hp
              I wanted a faster horse.
              • HellFire
                • Apr 2003
                • 280
                -Jarru swapista ei mene muutos prosentteja.
                -Jarrusatulat on Plug & Play asenteisia kaikkien E34 kesken.
                -Jarrulevyt on Plug & Play asenteisia kaikkien E34 kesken.
                -ei abs -> ABS muutos vaatii: 1.ABS jarrusatulat 2.jarrutehostajan ja jarrupääsylinterin 3.ABS ohjain boxin 4.Anturit pyörän napoihin
                edit: kommenttien perusteella korjailtu ja lisäilty...
                Vertailumalliksi käy korkeintaan tuo 540, en tiedä onko vuosimallilla merkitystä tässä tapauksessa eli verrataanko vanhempia 535. Huomion arvoista on myös se, että onko 540 ollut airbag vakiona, jos niin sekin voidaan käsittääkseni vaatia.
                Jarrulevyt ja satulat käyvät mielestäni hyvin ristiin, joskus olen verrannut/vaihtanut E32/E34 jarruja. Osien sopivuus kannattaa ehdottomasti tarkistaa esim BMW ETKsta tai Autodatasta.
                Periaatteessa ABS ei vaadi mitään erityistä satuloilta tai tehostimelta/syltyltä eli jos voit todistaa, että ne ovat vastaavat ilman ABS, ei niitä tarvitse vaihtaa. Käytännössä satulat ja tehostimen joutunet kuitenkin vaihtamaan, yritin vain sanoa, että teknisesti ABS on mahdollista liittää vanhoihin jarruihin.
                Varsinaisen ABS yksikön tarvitset tietysti, sekä ohjainboksin ja vastaavan kaapeloinnin (johdotus ei ole mitään herkkua).
                Anturit pitää tietysti myös saada napoihin, todennäköisesti joudut vaihtamaan myös navat sellaisiin, joissa on ABS kehät ja mahdollisesti myös ripustukset sellaisiin joissa on paikka antureille (näin on ainakin E30). En usko että tämän laajuinen jarruswap menisi läpi ilman prosentteja, en ainakaan tiedä yhtään tällaista tapausta, mutta joku voi korjata jos on varmaa ja mielellään tarkkaa tietoa mitä on vaihdettu, missä ja milloin
                • .:miksu:.
                  • Feb 2004
                  • 352
                  Ei pitäisi mennä prosentteja, kun turvalaitteiden/jarrujen vaihdosta parempaan ei enää mene prosentteja.
                  • Zoui
                    • 6350
                    Soitin akeen joku kuukausi sitten ja mainitsin oman autoni tiedot, 525i m20 vm90, vastaukseksi sain että vertailumallina käytetään 540i mallia (92->).
                    Joten itse olen nyt siinä uskossa, ettei e34:sen vuosimallilla ole vaikutusta vertailumallia valittaessa. Onko tämä faktaa, sitä tuskin tietää edes AKE/bmw-suomi/katsastaja-reiska. Tuntuu olevan melkein sama mitä akestakin kysyy, vastaus tulee kuin apteekin hyllyltä, vaikka vastaus saattaa olla vain mutua. (hurraa ake:n tekniseen neuvontaan)
                    • Zoui
                      • 6350
                      -Jarrupääsylinterit on samat kaikissa E 302x12, T 300 x 10, ei abs
                      -Jarrupääsylinterit on samat kaikissa E V 302 x 22, T 300 x 10, ABS
                      hmmm... ei noin.
                      Pääsylinterit voisi kai jakaa kolmeen ryhmään, vaikkei niissä juurikaan mitään eroa ole keskenään.
                      Esim. 1: M5 3.8 sama sylinteri kuin joissakin 518 M40 malleissa, kun taas joissakin ei.
                      Esim. 2: 540i 9/93 sylinteriä löytyy mm. ->
                      518i M40
                      518i M43
                      520i M20
                      520i M50
                      525i M20
                      525i M50
                      525ix
                      525td
                      525tds
                      530i M30
                      530i M60 malleista.
                      Eli haluttu yhteensopivuus on lähes pakko tarkistaa valmistusnumeron mukaan etk:lta, mutta jarrukokoa kasvatettaessa taitaa pääsääntönä olla kuitenkin se, ettei pääsyliteriä tarvitse vaihtaa.
                      • kartsan
                        • 187
                        • Kiukainen
                        Tulipa vaan mieleen huomioida että tässä puhutaan sitten vain sedan-malleista. Touringeissa taitaa olla yleisesti jäähdytetyt levyt edessä. Ainakin mun 525tds touringissa on. Mahtaako kaikissa touringeissa olla?
                        Yamaha XJ750 ja XJ900
                        E32 730iA
                        ex E32 750iAL
                        ex E34 525tdsA Touring
                        • .:miksu:.
                          • Feb 2004
                          • 352
                          ?? löytyykö siis kaikista Touringeista (paitsi M5 ja 540):
                          entä ABS:sät?
                          Löytyykö touringgeja joka vuosimallista ja jokaisella kone vaihtoehdolla?
                          • Zoui
                            • 6350
                            entä ABS:sät?
                            Levykokoa äkkiä etk:lta katottuna kyllä, 518 touringia lukuun ottamatta. (302x12)
                            • kuti
                              • Sep 2004
                              • 117
                              525ix edessä 296x28
                              BMW E34 525IX Touring-96
