E39 ilmastointi panelin erot???
  • jsr85
    • 1372
    • Oulainen
    mitä tuo aurinkotunnistin käytännöss tekee, omani (-3/99) lisävarustelistassa oli joku aurinkotunnistin.
      • 9234
      Functional description solar sensor for IHKA
      As part of climate control, the solar sensor takes into consideration external light and heat sources that influence the climate in the vehicle interior. The solar sensor consists of one photoresistor that measures the varying intensity of solar radiation. At high levels of solar radiation, the setting of the air conditioning system is correspondingly adapted to requirements.
      The following settings are varied:
      • Blower - The blower curve is changed
      • Stratification - The stratification air temperature is changed
      • Ventilation flaps - The angles of the ventilation flaps are changed
      The signal of the solar sensor is generated in the solar sensor module. The sensor signal is output in a voltage range of 0....5V. A value outside the limits indicates a malfunction and the influence of the sensor is completely suppressed.
      Restrictions:
      • E46/R50 Only one solar sensor is fitted. Stratification is not affected.
      • E38/E39 Two sensors are fitted in the solar sensor housing, aligned to the left and right.
      • TJJ
        • 7591
        Eikös tuo tullut vasta faceliftissä? Mikä tuon sinun varusteen nimi ja varustenumero on?
        E39 528iA
        • jsr85
          • 1372
          • Oulainen
          Restrictions:
          kiitoksia, mut tuo englanti ei taivu sit yhtään...
