N57D30 vikakoodit
  • Aapeji
    • Aug 2024
    • 10
    N57D30 vikakoodit
    Saisko täältä apua vikakoodeihin?
    245700
    Particulate-filter system: particulate filter subject to high load (exhaust backpressure high)
    -004D03 ~
    DPF back pressure sensor (004D03)
    004D46 *
    Exhaust Gas Back Pressure Sensor (004D46)
    004D4A ~
    Soot particle filter efficiency too low (004D4A)
    00452A Y
    Diesel particulate filter Remaining run distance soon reached (00452A)
    241580 v
    Exhaust Gas Back Pressure Sensor Malfunction
    (241580)
    DTC_02837 *
    Injection valve/nozzle (DTC_02837)
    25FA00
    React immediately
    Description:
    Charge-air temperature sensor, signal: short circuit to ground
    253400
    Swirl-flap actuator, position control: swirl flaps closed too far/positive control deviation
    004DFF ~
    P2015 Function error switch suction tube
    004755 v
    Turbocharger/Supercharger Wastegate
    Actuator 'A' Range Malfunction (004755)
    255C00 *
    Exhaust gas recirculation position sensor, signal (255C00)
    P200A v
    Switching suction tube actuator (P200A)
    DTC_02748 ~
    P0638 Electronic throttle system
    27F000
    detected
    Charge air hose monitoring at idle speed: Leak
    290B00 *
    Mass air flow sensor function error (290B00)
    002AFB v
    Charge air temperature sensor plausibility (002AFB)
    P1101 v
    Manifold Absolute Pressure / Barometric
    Pressure Data inconsistent (P1101)
    P0097 *
    Intake air temperature sensor/Inlet air temperature sensor (P0097)
    DTC_05140 Y
    DME: secondary air valve control
  • Urpo_rotta
    • 5494
    • Pirkkala
    DPF osastolla ainakin vikaa mutta on niin monta koodia että poistappa kaikki ja aja muutama km ja katso koodit sitten uudelleen ja keskity niiden korjaamiseen.
    Hyvin todennäköisesti suurin osa noista on vanhoja koodeja ja eivät ole aktiivisia tällä hetkellä
    Kysy jos tarvetta
    • Aapeji
      • Aug 2024
      • 10
      Kiitos asillisesta vastauksesta!
      poistin kaikki vikakoodit ja ajoin 50km,
      Takasin tuli nämä
      -25FA00 Charge-air temperature sensor, signal: short circuit to ground
      -28CD00 LIN, message; radiator shutter: Missing
      -27AB00 DDE control unit internal (cyclic authentication): data-record check not OK
      • Aapeji
        • Aug 2024
        • 10
        DPF arvot näyttää tolta?
        • Rattiukko
          • Nov 2022
          • 866
          • Uusimaa
          Dpf on arvot on hyvät, ei ole tukossa ainakaan noiden lukujen mukaan. Imusarjan lämpöanturi taitaa olla rikki. Radiator shutter on varmaankin jäähdyttäjän kaihtimet.
          • Urpo_rotta
            • 5494
            • Pirkkala
            Joo vaihda tuo anturi ja ajele tovi, niin selviää kuinka pelaa
            Kysy jos tarvetta
            • juha_s
              Alueaktiivi
              • May 2008
              • 446
              • Lappeenranta
              Seuraa samalla noita dpf arvoja muuttuuko, tuo 27AB00 viittaa siihen että ohjelmoitu niin voi olla poistettuna.
              F11 535d xDrive M-Sport -13
