E28 535 Turbo?
  • E28
    • 1
    E28 535 Turbo?
    I dont speak finnish very much, so l dont understand everything that is written in some interesting threads. I would like to know if somebody has turbod a 3.5 160kw, 10.0 compression ratio engine in finland, with stock internals, if not then how much power would you make with E34 3.5 engine with 9.0 compression ratio with stock internals, and what turbo to use?
    Greetings, Edward
  • Jonsku
    • Sep 2002
    • 4651
    There are a few turboed M30 engines here. Nobody has turboed e28 3.5 with 10:1 CR but few M30s from E34 / E32 with 9:1 CR has been turboed and they make 400-600hp depending on boost. Stock internals can take that, but it gets hard on head gasket..
    No idea what turbo you should use but 3.5 litres with 1 bar of boost requires quite big turbo.
    Maybe you should read some US / UK forums like www.r3vlimited.com , www.bimmerforums.com , www.e30zone.net . There are quite a lot of turbo projects and especially swedes have turboed almost every engine (www.pure-pf.com , though those pages are in swedish :( )
    ex. Alpina D10 Touring #33/94
    ... and many more
    • full
      • 1211
      There's one e24 m30b34 10:1 that has stock internals.. same motor with e28..
      there's kompressor under the hood.. if i remember right there was 0.4bar 224bhp and 470nm
      BMW M535iA -86
      Volvo V90 -18
      • e24
        • 628
        actuali this m30b34 motor has 9,2:1 compression ratio and 0,42bar 320hp and 472nm and it has stock internals. with better brething exhaustpipe horsepowrs would be something more =)
        käyttis Honda CR-v
        .... MR2
        ex v40 t4; E38 740ia; 2l tbo s40; 406 hdi ; 635csi remmi (varkaiden tuhoama)
        • full
          • 1211
          oh.. my mistake.
          i meant 324hp but didn't know real compression
          BMW M535iA -86
          Volvo V90 -18
