memebuy23buy
Virallinen vikakoodi topick (vikakoodikyselyt tänne!)
  • expertti
    • 908
    • Kainuu
    Originally posted by myllari View Post
    E9x 320d:ssä palaa moottorin häiriövalo ja valittaa että pakokaasu päästöt kohonneet. Vikakoodit luettu inpalla, antaa kolmospytyn hehkulta vikakoodin ja sitte tälläisen:
    4501 abgasrueckfuehr -regelung, regelweichung
    P0401 abgasrückführung 1 -durchsatz zu gering
    Osaisko joku sanoa että mikä mahtaa olla aiheuttaa tuon jälkimmäisen koodin ja kummasta tuo häiriö valo syttyy?
    Generic OBD Error Code Details for P0401
    Exhaust Gas Recirculation Flow Insufficient Detected
    What does this mean?
    OBD Code P0401refers to
    EGR stands for Exhaust Gas Recirculation. It is part of the vehicle emmissions system, and is used to reduce combustion temperature and pressure to control Oxides of Nitrogen. There are generally three parts to the EGR system: the EGR valve, an actuator solenoid, and a differential pressure sensor EGR (DPFE). These things work together to deliver the correct amount of recirculation based on engine temperature, load, etc. The P0401 code means that OBD detected an insufficient amount of EGR.
    Symptoms
    Possible sumptoms of OBD code P0401
    You may notice drivability problems such as pinging (a.k.a. pre-ignition knock) when the engine is under load or the vehicle is at higher speeds. There may also be other symptoms.
    Causes
    Possible causes of OBD code P0401
    A code P0401 most likely means one or more of the following has happened: •The DPFE (differential pressure feedback EGR) sensor is faulty and needs to be replaced •There is a blockage in the EGR (tube), most likely carbon buildup •The EGR valve is faulty •The EGR valve may not be opening due to a lack of vaccuum
    Possible Solutions
    In fixing this code, it is quite common for people to just replace the EGR valve only to have the OBD code return. The EGR valve is not always the culprit. •Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's & DPFE voltage. There should be a noticable difference in RPM's with the EGR open •Clean out the EGR valve and/or tubing to remove deposits •Check the voltage at the DPFE, compare to specified values (refer to a repair manual for your specific model) •Replace the DPFE sensor (with a good quality / OEM one) •Replace the EGR valve
    Related Codes
    P0400 P0402 P0403
    Noilla ehkä pääsee alkuun vian jäljittämisessä...
    • expertti
      • 908
      • Kainuu
      Originally posted by Bemarityttö View Post
      Apuwa!
      Taustaa... Kyseessä 320da 11/2001 farmari. Virtalukko kiukutellut jonkin aikaa. Välillä käynnistyi välillä ei, kunnes ei enää käynnistynyt ollenkaan. Starttaa mutta ei käynnisty, pyörittää vain.
      Vikakoodit tänään:
      43F1 Elect extra heat (195000 245150 kilsat)
      4AB2 Not defined (195620)
      4242 Cylinder 4 activation interv (228110)
      4661 Power supply (228110)
      4A30 Signal multifunction steering wheel toggle (228110 236000)
      4A63 Not defined (240150)
      Että mitäs kaikkea tässä nyt on vialla? Toi viimeinenkö aiheuttaa sen ettei käynnisty?
      Millä luettu? Saatko esim INPA:n nokkaan, tai jonkun muun laitteen joka antaa P alkuisen vikakoodin....
      • Bemarityttö
        • Sep 2009
        • 36
        Minäpä tarkastan ohjelman... Naapurilla oli lainassa kone joltain et päästiin ylipäätään käsiks noihin koodeihin
        Voipi olla että tarttisin jonkun sit vielä koodaamaan veks ton viimeisen. Käsittääkseni muut saatiin nollattua...
        • expertti
          • 908
          • Kainuu
          Joo, tuo viimeinen koodi viittaa ajonestoon EWS. Eli jos se ei kuittaannu eikä auto lähde käyntiin(startti toimii) niin ajonesto lienee esteenä.
          Kannattanee kokeilla eri avaimella käynnistää, tiedä vaikka patteri/akku avaimessa olisi tyhjentymässä.
          Mikä auton/ongelman historia mahtaa olla....
          • janke
            • Nov 2010
            • 3665
            • seinäjoki
            Mitähän mahtaa tämä raportti kertoa? Eli autm.laatikosta tuli tällänen vikakoodi:
            Bmw 316 E30 -88
            • emmiz
              • Sep 2009
              • 103
              • Rajamäki
              Varmistetaan nyt vielä täältäkin, mitä mahtaa tämä vikakoodi tarkoittaa?
              • Hastra
                • Nov 2011
                • 545
                p122f ?
                Moottorin vikavalo syttyi ja puhelimella torgue antoi vikakoodiksi p122f.
                Mikäköhän tuo on, kun google antoi aika monenlaisia vikoja?
                Audi A3 GTRON
                EX: BMW 325D Coupe -07
                EX: BMW 320ia -08
                • ripatsu
                  • Jul 2012
                  • 144
                  • Suomi Finland
                  pressure control
                  • Nepo
                    • Dec 2011
                    • 92
                    • oulu
                    Ilmastoinnin paineanturi
                    jep eli 530da faceliftissä meinaa tulla kuuma... talvella tullu semmone vikakoodi kuin a/c pressure sensor, meinaakohan se että se ite anturi paskana vai että liian vähän mehuja?.. pikaisia vastauksia toivotaan ennen lämpöhalvausta..
                    730da, 99
                    Ex 530da, 99
                    530da, 01
                    • randy_
                      • Feb 2013
                      • 53
                      • PK-seutu
                      Vikamuistista löytyi tämmöinen.
                      27A4 - CDKDWA - EWS3.3 Schnittstelle EWS-DME
                      Vian ajankohta viime sunnuntai. Ykkösavaimella ei suostu starttaamaan, huoltoavain ja vara-avain toimivat normaalisti.
                      Ykkösavainkin pelaa kunhan ensimmäisen startin tekee jollain toisella. Ovien lukitseminen pistää ykkösavaimen taas pimeäksi :think
                        • 10946
                        Vika on avaimessa. Kun käytät toimivaa avainta II-asennossa niin sen jälkeen pystyy käynnistämään ilman toimivaa EWS sirua.
                        • randy_
                          • Feb 2013
                          • 53
                          • PK-seutu
                          Pitääkö ostaa uusi avain vai voiko tuolle tehdä jotain?
                            • 10946
                            Eipä tuota taida saada korjattua. Sieltä on luultavasti EWS chippi hajonnut tai sitten joku juotos. Toki voihan sen avaimen avata ja katsoa, jos jotain näkyvää vikaa löytyy (juotos tms). Melko hakala avata tuo avain kun sen joutuu leikkaamaan auki. Suosittelisin marmorilta tilaamaan uuden avaimen.
                            • teemu.k
                              • Jan 2010
                              • 506
                              • raahe
                              bmw e46 328ic vm 1999
                              Tämmöisiä vikakoodeja löyty scannerilla bmw e46 328ic vm1999. Mitähän nuo kaikki mahtaa tarkoittaa? Vai onko nuo edes vikoja tällähetkellä kun on varjomuistissa?:think
                              Sen ainakin tiedän, että autosta poistettu se ilmapumppuhärdelli koska autossa on rosteri pakosarja kiinni.
                              shadow- memory
                              34/02 - activation, solenoid valve, exhaust flap
                              23/12 - activation, relay, secondary-air pump
                              3E/12 - activation, solenoid valve, secondary air
                              7E/12 - activation, solenoid valve, tank-leak dioagnosis pump
                              7F/02 - activation, solenoid valve, suction-jet pump
                              32/14 - activation, solenoid valve, fuel-circuit changeover
                              • Olapade
                                • Nov 2007
                                • 262
                                • Häslinki
                                -96 523iA Automaattiropleemaa
                                Elikä kaverin autossa on alkanut automaatti hieman pygimään. Ketjuja on luettu, mutta vastaavaa ongelmaa ei ole kävellyt vastaan. Oireet on perus, arpoo vaihtamista silloin ja tällöin. Oli myös sytyttänyt aut. trans. fail mode valon, vikakoodit luettu ja huuteli vikakoodia turbiinista?
                                16 Web/Turbine Speed.
                                Error frequency : 2
                                Label Byte 21 21.00 -
                                Gearbox Oil Temperature 67.00 degrees
                                Output speed 928.00 rpm
                                Gearbox Oil Temperature 70.00 degrees
                                Output speed 640.00 rpm
                                Sporadic error.
                                Vuosi sitten laatikon ölpät vaihdettu huuhtelemalla, ei oireita ennen tätä kevättä. Öljyt myös tarkistettu vian ilmettyä, ylärajassa. Akun kenkää pidetty parikin yötä irti, ei vaikutusta.
                                Turbiinissa jonkinmoista vikaa siis?
                                M20B20/E34 osaa myynnissä-->http://www.btcf.fi/forum/showthread....36#post3147936
