Enem Z58
  • S4Driver
    • Aug 2006
    • 571
    • Kaukana
    Enem Z58
    Voisko joku ns aukilukea ton: 296/112/12.25/3.2
    Nokkakepin merkintöjä. Asteet 296, nostoa 12.25, muista numeroista ei hajua.
  • O-Peksi
    • Sep 2007
    • 2775
    Googlailin tässä joutessani hakusanalla "296/112/12.25/3.2" ja Enemin sivuilta löytyi heti:
    • 296/105/13.0/4.4 ins
      296 = Duration in crank shaft degrees. Specified where the acceleration of the Valve starts, normally 0,20 mm higher than the Tappet clearence.
    • 105 = Angle between lobe centers.
    • 13,0 = Valve lift at 0-clearence.
    • Value for valve opening at TDC (mm). For 2-valve single Cam engines always for the inlet valve. Tappet clearence shall be adjusted when measuring. If there are two Cams a second value must be used, normally for the Exhaust Cam and the value specify how much the Valve still have to close at TDC.
      A general rule is, if the value is missing, it shall be 0,5 - 0.7 lower than the value for Inlet valve.
    • ins or avg indicates if it is an Inlet or Exhaust Cam. The same profile is common on both types of Cams.
    • ÖD = Piston in top.
    ReWoN Motors - BMW-huollot ja korjaukset, alumiinivanteiden korjaushitsaukset, pakosarjat, ahtoputket, alumiini- ja rst-hitsaukset ja sorvaukset
