Originally posted by pt.
The cruise control (tempomat) is switched on by pressing the "accelerate" button on the steering wheel. When the button is pressed continuously, the speed is additionally increased with a comfortable acceleration progression.
The cruise control (tempomat) is only switched on, however, when all switch-on conditions have been fulfilled.The switch-on conditions are:
- Tempomat prepared with main switch (if installed).
- Rest position of "accelerate" button before switching on the cruise control (tempomat).
- Minimum speed of 30 km/h must be exceeded.
- The brake pedal must be in rest position.
- On vehicles with manual transmission, the clutch pedal must be in rest position.
- On vehicles with automatic transmission, drive stage "2" to "D" must be engaged.
- No switch-off conditions must be effective. Switch-off conditions are possible either by operating control elements (e.g. pressing the "OFF" button on the operating unit), or they can arise due to detected defect statuses (e.g. short-circuit at actuator motor).The defects are stored in the form of defect codes in the defect code memory.
