- Pressure and temperature in tyre pressure monitor
Enable/disable the pressure and temperature in the tyre pressure monitor in the iDrive system. Please note that the car has to be equipped with the required sensors. This option affects the display only and it is not possible to completely deactivate the tire pressure monitoring in the car.
Values:- Active
- Not active
Requirements:
- “Headunit” HU_CIC control unit
Nyt joka käynnistyksellä pitää iDrivesta kuitata "ok" ettei painevalvonta toimi ja sitten jää vikavalo siitä mittaristoon, tuskin tuota kuitenkaan kun sittenhän tuo "not active" olisi ihan turha valinta.
