N54 Automaattiin Alpina B3 Flash
  • Tommix
    • 5606
    • S:t Karins
    Törmäsin netissä mielenkiintoiseen modaukseen. N54 mosan perässä olevan automaatin saa nopeammaksi ym. softaamalla boxi Alpinen softalla. Tässä copy ohjesta:
    "Alpina B3 Flash DIY using WinKFP
    DIY Guide to Flash Alpina B3 Flash:
    WARNING...If you dont know what your doing, dont be brave and blindly go into this advanced flashing of software into the TCU module.. If you mess up you can easily brick your tranny module and you will find yourself towing the car to the dealer and looking like a fool. If your not too confident in doing this, either pay someone or just do without it.....WinKFP is a very dangerous tool but yet its awesome and in terms of coding its pretty advanced.. Proceed after reading this warning if you choose to do so...
    This flash will make the transmission run smoother, gear change will be more precise and crisp, rev match downshift is unbelievable, rev limiter is increased and overall driveability is increased. You will have a new indicator for gear selection in D mode which display D1, D2, D3 ,D4, D5 and in DS mode you will see S1, S2, S3, S4, S5 and the same for the M mode. This single flash will make the car change gears more refined and crisp. You will no longer feel the lurching when the tranny shifts and it goes through the gears without even the slightest hesitation. It is indeed a must have flash if you own a E9x with a N54 engine...
    This Alpina TCU flash works for model years 3/07 till present N54 engine only. If your production date is before 3/07, your out of luck and cant flash your car! Before you attempt this you should have some knowledge in coding and setting software. You need to confirm INPA software is working and communicating with car. If you dont have INPA communicating, dont move beyond this point and go back and do some more research on getting it to work.. There are plenty of DIY guides for setting up INPA, Ediabas, NCSexpert and WinKFP.
    You can purchase a proven cable that works..
    ONE NOTE::: Please no PMs on how to set it up. You have to do some work yourself..
    Once you have configured your laptop properly, you need to download Spdaten at least 50.3 the full version for E89 chassis . Dont download the lite versions as it doesnt have the necessary files needed for flashing modules. There are torrent links around...Look for them! The E89 Spdaten needs to be imported to WinKFP. There are PDFs showing how to get this done, do a search! Once it correctly imported, then you may start the flash using Winkpf.
    Here is spdaten 53.0 for this flash...Its not the complete spdaten but this link will have the neccessary data to do the alpina flash
    Here we go:
    -Make sure your battery is good if not get a battery charger
    -Open drivers door and turn ignition ON (cluster guage on)
    -connect cable to obd connector of car
    -Load Winkpf software
    -Press (F1) comfort mode
    -Press (F3) Update ZUSB
    -Choose ECU GKE215
    -Press (F2) Choose ZUSB
    -Choose ECU GKE215 and next to it there will be ZB-Numbers..Find 7615835
    -Click ok
    -If you have done it correctly so far you will see at the top Assembly Identification number 7615835 and it will automatically reference the magical Alpina B3 TCU flash software 7591971
    -Press (F4) Enter VIN ( make sure you double check you have entered the correct VIN numbers)
    -click ok
    -Press DONE (F8)
    -Press (F3) Program
    -Pop up window will say you can code the ECU 63 more times, click ok
    -Flashing begins and you will have to wait till it reaches 100%
    -once it reaches 100% it will pop up again saying you have 62 more times to program the ECU, click ok
    -Programming again starts, wait until this reaches 100%
    -If everything is done correctly, then you will get a pop up screen saying programming done, click ok
    -Shut off car by taking key out. Lock car with key, wait 5 minutes and start the car..If everything works correctly you will not
    have any warning signs or check engine lights...Enjoy your newly transformed AT Alpina B3 software
    *****Alpina B3 flash Part II: DIY for NOT-working paddles shifters after flash:
    The Alpina B3 flash has been a huge success so far for performance gains as well as fixing many issues that has plagued the N54 platform for years. It has undoubtedly given the performance gains in which everyone could enjoy. The only minor glitch during the flashing was on new model years in which once the car is flashed the paddle shifters now longer worked, unlike the earlier build model years which didn't exhibit this. This was quite bothersome to me so I had to find a fix as it seemed unthinkable it wouldn't work. Here is your solution!
    You guys need to use NCSexpert and at least 49.3 spdaten loaded up to both NCSexpert and Ediabas. There are tons of literature on this so do a search on it. If you not comfortable doing this or the actual coding, you can find a local coder and pay to have this coded....
    Warning: If you dont have at least Spdaten 49.3 updated correctly after doing this coding the car will be Dead and show a gear warning on cluster when you try to get the paddle shifter to work..
    Here is what you do:
    0-Start ignition with cluster lights on
    1-Load NCSexpert
    2-File Use EXPERTMODE click ok
    3-(F1) Vin/ZCS/FA
    4-(F3) SG ausw
    5-Choose E89 chassis click ok
    6-Choose CAS click ok
    7-(F6) Back
    8-(F4) Read ECU and pick EGS module click ok
    9-wait till nettodat file pops up and then close it out
    10-Press F3 (execute JOB)
    11-After it says coding ended your done!
    12-Close out NCSexpert
    At this point 3 things can happen:
    **A)There are no errors and the car starts fine and the paddle shifters are working and your happy!
    **B)The car starts but then when you drive off, the shifting of gears are all screwy and changing correctly.
    **C)The car starts but you get the dreaded GEAR error and it wont even go into drive at all..
    If you have either B or C then you issue is the update of the Spdaten was incorrectly done...Go back and check installation and start again"
    Juttua tästä:
    Imutin jo tuon softankin mutta tuolla tekstissä mainitaan:
    " If your production date is before 3/07, your out of luck and cant flash your car!"
    Voi pas...
    Onko rauta eri vai mikähän lienee syynä?
    Edittiä:
    "3/07 production date is the cutoff anything earlier and your on the outside looking in. The mechatronics supposedly is different in the tranny"
    Ja tässä laatikoiden numerot
    part. no. type
    Up to 03/2007 24007564242 GA6HP19Z
    from 03/2007 24007572071 GA6HP19Z
    Käyttis: G26 i4 M60
  • brainsurgery
    • Aug 2011
    • 1355
    Mulle kelpais. Pistäkäähän kommenttia kun saatte flashattyä
    • BFI18
      • Aug 2012
      • 1459
      Kiinnostavaa...Tubessa noita pätkiä onkin, joissa tuo modi tehty automaatti N54:een. Nopeammalta näyttää, vaikka ei tuo vaihteisto nykyiselläänkään hidas ole.
      G26 i4 M50 Black Sapphire
      • Kissvesala
        • Jun 2010
        • 3110
        • Liminka
        Tehtiin tuo vasta kaverin (samppa...) autoon ja viikon jälkeen palautettiin takasin. Laatikko menee normikäyttöön järjettömäksi. Vaihtaa kyllä nopeaa, mutta latoo vaihteet sillain että 40kmh vauhissa kylmänä jo kutonen pesässä. Helppohan tuo on tehä ja ratakäytössä varmasti hyväkin.
        Kissvesala.fi
        Priva tai o443424479
        • brainsurgery
          • Aug 2011
          • 1355
          No tuo ei kuulosta kyllä hirveän hyvältä Kierroksiahan kutosella 40km/h vauhdissa on noin 750
          • tnurmine
            • Aug 2012
            • 98
            Mulla ollut tuo käytössä varmaan vuoden. Nyt kun tuossa on pääosin vältelty automaattimoodilla ajoa, niin hyvin se ainakin motivoi ajemaan manuaalilla... ja manuaalilla tuskin tuo B3 huonompikaan on, mutta enpä juurikaan mitään eroa huomannut vakkariin.
            ... ai niin, kuulostaahan se tietysti hyvältä, että tuollaisen on autoonsa flashänny
            Edit: vielä tuli mieleen, että B3 fläshissä on kehuttu tuota alasvaihtamisen välikaasu/'rev-matching' toimintoa ja se kyllä toimiikin ihan mainiosti.
            • samppa...
              • Sep 2008
              • 117
              Joo viikko vissiin tuli tuon kans tuskailtua.Ite en tuosta tykännyt,tulee yleensä ajeltua keppi d-asennossa ja tämä ominaisuus oli kyllä aika vittumainen.Heti kun lähti liikenteeseen,niin aski rupesi latomaan pykälää silmään,muistaakseni jossain 5kympissä jo 6 pesässä,ja tosi nihkeästi puotteli pienemmälle.Jos vähän rivakammin tarvi mennä niin melkeen kickdaunille piti polkea että liikkuis johonki.Ja kyllähän se sitten liikkuuOrkkis softa toimii omaan makuun mukavammin.S-puolella ajellessa vaihtaa pirun nopeasti verrattuna orkkikseen.Oikein junttaa pykälän päälle että perseessä tuntee.Aikoinaan tuli koe ajettua 335i:Tä dkg laatikolla ja ei tuo nyt kauhean paljoa hitaammin vaihtanu vaihdetta siihen verrattuna.Manuaali puolella kans vaihtaa nopeampaan kun orkkis softa.Ainoa hyvä juttu tossaoli niin näki koko ajan mikä vaihde on päällä.D:llä S:llä.Maku asioitahan nämä on toinen tykkää toinen ei,testaamalllahan se selviää.Eipä tuo nyt ole kuin sen 10 minuutin homma laittaa autoon tai pois.
              • Veeksi
                • 2179
                Kuulostaa siltä että joku pro sais puukottaa softan sellaseks että D:llä on vakio ja S:llä ja manuaalilla Alpina...
                BMW E85 3.0i '05
                • yarski
                  • Sep 2013
                  • 314
                  • Rauma
                  Hmm...
                  Mielenkiintoisia kommentteja ja siis täysin päinvastaisia kuin ulkomaan foorumeilla
                  Itsekin tuon haluaisin kokeilla/testata/asentaa muttakun läppärillä ei ole toimivaa softaa - laiskuutta sen puute lienee ? - niin ei vaan onnistu kokeilla.
                  Eniwei, lähestulkoon "kaikki" muut kehuvat alpinaa... ???
                  G26 i4 M50 supercharged
                  ex: F36 440i xdrive msport
                  ex: E91 335 lci xdrive msport
                  • Kissvesala
                    • Jun 2010
                    • 3110
                    • Liminka
                    Originally posted by yarski View Post
                    Hmm...
                    Joo intopinkeenä se sampalle laitettiin helevetinmoisia kehuja lukeneena. Voihan se olla että jotku tykkää ku nakkaa vaihteet niinku kaksoiskytkentä loova, mutta näihän se on että toinen tykkää tytöstä ja toinen äitistä.
                    Tässä tapauksessa ei looda miellyttänyt.
                    Kissvesala.fi
                    • tnurmine
                      • Aug 2012
                      • 98
                      Hmm...
                      Jaa, minun mielestäni täällä on täysin samat kommentit, kuin muuallakin, eli Manual ja Sport moodit tuolla fläshillä good, mutta D-moodia harvempi kehunut.
                      • brainsurgery
                        • Aug 2011
                        • 1355
                        Vahingossa tuli vastaan videopätkä, jossa jollain JB4 ja tuo Alpinan flashi laatikossa. Eipä tuo nyt ihan hirvittävän paljon nopeammalta vaikuta kuin vakio.
                        Sorry, we couldn’t find that page
                        • BFI18
                          • Aug 2012
                          • 1459
                          Onko lisää käyttäjien kokemuksia tästä B3 flashistä N54:ssä?
                          • BFI18
                            • Aug 2012
                            • 1459
                            Koodaisko joku Turun seudulla tän B3 automaatti flashin edullisesti?
                            Privaa tulemaan.
                            • miyli
                              • Dec 2008
                              • 2114
                              • Naantali
                              Privaa tulemaan.
                              Kysy supparilta
                              Käyttis: BMW i4 M60 Black Sapphire / Oyster
                              Nurkka käyttis: Mini Cooper SE Maximise
                              Talviharraste: BMWe36 vompatti (jäärata vehje)
                              Ex: BMW e92 335iA 600hv/719nm
                              1/4 maili 11.8 / 205 km/h
                              0-200km/h 11.40s
                              100-200km/h 6,00s
                              Exät: 21 kpl BMW, 17 kpl muita mielenhäiriöitä ja 7 kpl prätkää
