Originally posted by HTK12
View Post
E39 kysymyksiä ja vastauksia XIII
Kerro lisää tästä. Mulla on jäähdytin melko pullistunu ja juuri Nissenssiä meinasin ostaa Behr-Hellan huonon laadun vuoksi. :thinkF10 530dA Saphirschwarz, G30 530e Saphirschwarz, E38 730iA Dunkelblau, E39 540iAT Biarritzblau Metallic
ex: E39 528iA Arktissilber, E39 528iAT Arktissilber, E34 525TDSA Diamantschwarz, E32 735 iAL Royalblau Metallic, E34 525i Diamantschwarz, E36 325 TDSA Arktissilber
Nakkaa privaa jos tarvetta.
Esim. JimLev meni 3 Nissensin syyläriä ja sitten totesivat, että ei mene enää takuuseen: " Dear Steen,Originally posted by peto2 View PostKerro lisää tästä. Mulla on jäähdytin melko pullistunu ja juuri Nissenssiä meinasin ostaa Behr-Hellan huonon laadun vuoksi. :think
Again I find it necessary to write to you about the 3rd Nissens radiator I received from Taylor Automotive as a warranty replacement for the second radiator that leaked, which was a replacement for the first one that leaked. (Invoice # 606032 Customer # 122967)
Yes, the 3rd one in a row has failed, this time it only took 2 minutes for it to start leaking from the very same place. The lower side by the bottom hose connection.
They all have leaked where the plastic side tank is crimped to the aluminum core.
The problem is not the car, the radiator cap has been replaced. The engine has never overheated, the coolant is changed every 2 years with BMW coolant and distilled water.
This third radiator was shipped to me on 1/24/07 and installed last Wednesday. (my car is stored for the winter).
I bought your radiator because I was told that the BMW Behr radiators had a history of the hose connections snapping off.
At the time my BMW/Behr radiator was 5 years old so I thought it would be wise to replace it, even though it had no problems.
On Thursday my old Behr radiator was put back in the car, I have been driving it all day today, not one drop has leaked from it.
At this point I would like my money refunded from Taylor Automotive ($118.01), as I can not trust the quality of another Nissens radiator.
Earlier today I ordered an all aluminum Zionsville radiator ($632) which has a lifetime warranty.
I would expect that you would want to have these defective radiators shipped back to you for examination....yes?
UPS can pick them up if you fill out a pick up ticket.
Attached are 2 pictures of your 3 radiators and the old Behr that is now in my car, and the leak from the last radiator.
The reference numbers on all 3 are 60648A.
The production numbers are 165361 E, 204567 LF, and 392677 C2 C4.
I look forward to you reply and also Taylor Automotive.
If you need more info, please let me know.
Eikä ole mitenkään ainut tapaus, googlella löytyy lisää. Kutoseen osalta en osaa kommentoida kun näissä on erilaiset syylärit, niissä ehkä Nissens saattaa olla toimiva.e39 540iA E85
Olisko vialliset sitten 9/98 jälkeisissä koska tuota vanhemmissa on ainakin samat jäähdyttimet 520i-750i ja niitä olen nyt kahteen autoon laittanut ilman ongelmia toinen noista on edelleen taloudessa n. 5v myöhemmin :thinkOriginally posted by HTK12 View PostEsim. JimLev meni 3 Nissensin syyläriä ja sitten totesivat, että ei mene enää takuuseen: " Dear Steen,
EDIT: Eikä muuten ole, etk näyttää mitä sattuu..Last edited by peto2; 25-06-2018, 13:14.F10 530dA Saphirschwarz, G30 530e Saphirschwarz, E38 730iA Dunkelblau, E39 540iAT Biarritzblau Metallic
Juu ei ole samat, paisarit, termarikotelot jne suunnilleen kaikki erilaiset kutonen vs kasi. Kenties se kutosessa saattaa toimia kasissa ei. Siksi ajattelin kysäistä onko Behr-Hellaa parempaa olemassa muuta kuin alkuperäinen.Originally posted by peto2 View PostOlisko vialliset sitten 9/98 jälkeisissä koska tuota vanhemmissa on ainakin samat jäähdyttimet 520i-750i ja niitä olen nyt kahteen autoon laittanut ilman ongelmia toinen noista on edelleen taloudessa n. 5v myöhemmin :think
EDIT: Eikä muuten ole, etk näyttää mitä sattuu..e39 540iA E85
Mut eikös orggis ole behr? Ainakin e36:ssa on. Behr tarvikkeet on mulla ainakin kestäny hajoamatta.Originally posted by HTK12 View PostJuu ei ole samat, paisarit, termarikotelot jne suunnilleen kaikki erilaiset kutonen vs kasi. Kenties se kutosessa saattaa toimia kasissa ei. Siksi ajattelin kysäistä onko Behr-Hellaa parempaa olemassa muuta kuin alkuperäinen.
Instagram, YouTube kanava
Mulla on kolme behriä alkanut vuotamaan n. vuodessa. :thinkOriginally posted by Pazi88 View PostMut eikös orggis ole behr? Ainakin e36:ssa on. Behr tarvikkeet on mulla ainakin kestäny hajoamatta.
Mulla on E38:ssa tuo Nissens paikallaan ja se on ainakin kestänyt jo pitkään, sama jäähdytin kun alkupään V8 E39:ssäOriginally posted by HTK12 View PostJuu ei ole samat, paisarit, termarikotelot jne suunnilleen kaikki erilaiset kutonen vs kasi. Kenties se kutosessa saattaa toimia kasissa ei. Siksi ajattelin kysäistä onko Behr-Hellaa parempaa olemassa muuta kuin alkuperäinen.Last edited by peto2; 25-06-2018, 15:47.F10 530dA Saphirschwarz, G30 530e Saphirschwarz, E38 730iA Dunkelblau, E39 540iAT Biarritzblau Metallic
Mulla vuotaa Behr nyt siitä nipasta siinä syylärin päällä, siitä menee se ohut letku paisariin. Ikää on jotain 3v ja on jo tovin haistellut jäähdytinnesteen hajua. Kävin tilaamassa uuden Harkitaiselta kun BMW ei enää myy tuota osaa.Originally posted by Pazi88 View PostMut eikös orggis ole behr? Ainakin e36:ssa on. Behr tarvikkeet on mulla ainakin kestäny hajoamatta.e39 540iA E85
Virtalukon pohja aiheuttaa ihmeellisiä ongelmia välillä. Kokeile meikkipeili testiä.e39 540iA E85
Kokeile liuttaa läppää ees taas...jos ilmenee outoja niin virtalukonpohjassa vikaa.Originally posted by tu22ha View PostMeikkipeilitesti?
Muistaakseni kumpaankaan meikkipeiliin ei tule valoja.F10 523iA 2010
Ex: E39 528iA 1997
Ex: E85 Z4 2.5iA LCI 2008
Ex: E65 745iA 2003
Ex: E46 318i 1998
Ex: E34 525iA 1989
Olisiko kenelläkään mahdollista linkittää kuvaa E39 minkä alla olisi 17" vanteet 225/45 renkailla :think
Koitin kovasti googlettaa mutta ei osunut kohdille oikeanlaista kuvaa.Originally posted by JubeEihän sen tyylikkäämpää ja parempaa autoa olekkaan kuin hienokuntoinen vanha kunnon w124
