530d -01 satunnaisesti epätasainen käynti
  • th2376
    • 154
    #46
    Löytyihän sitä jotain, kun pääsin apuvälineisiin käsiksi. Toivottavasti tuolla ratkeaa.
    Matching injector characteristic DDE 4.0
    In order to compensate for tolerances in the fuel injection system, particularly those of the injectors, a characteristic map with specific values for each engine is stored in the DDE control unit at the end of the assembly line. The injection volume calculated by the DDE control unit during engine operation is varied slightly by these values thus improving the exhaust emission characteristics.
    The harmonization values must be set to neutral if more than two injectors are replaced on the M57 or more than three injectors on the M67.
    TIS:
    The first 6/7 numbers (suuttimen kannassa) must be read off in each case when new injectors are installed.
    (DIS/GT1)
    • "DDE"
    • "Adjustment, injector quantity adjustment
    • "Test schedule"
    • "Carry out adjustment" The adjustment values are thus set to neutral.
    LOISTAVAA työtä, kiitoksia!!! Ei muuta kun pajalle huomenna, palaan asiaan!
    Ex BMW:
    E12 520/528i -78/80, E24 633Csi 3.5 -77, E21 323i -79, E28 528i -84, E28 524tdA -84, E34 524td -91, E34 524td -90, E32 735iA -87, E39 535i -97, K100 -83, E39 530dA -99, E39 530d -02, E60 530d -04, E60 530dA -06, E60 530d -08, F10 530dA X-drive -11, F10 525dA X-drive, G30 530e X-drive -20, G30 530e -17.
