E32 750 iL käyntihäikkää sitkeästi - selvisi -> tulpat !!
  • bigmasa
    • Jun 2006
    • 132
    jaa, sen verran mystinen tuo sun ongelma että yritin etsiä muilta foorumeilta vastaavaa, ja lähin mitä löytyi on tämä:
    "Fuel pumps and ignition coils can cause limp mode without an EML signal. I've had both and neither time did I get an EML light. The only time I got an EML signal with limp mode was a bad connection to one of my O2 sensors. Honestly I don't quite understand this one as the O2's are connected to the EML indirectly via the DME's, so I would have expected a check engine light, but I didn't get what I ordered so to speak. hehehe
    Oh yeah one other thing can happen. If your battery is low and during cranking if you fall too far below the minimum voltage threshold, you can get a Trans Program message on the instrument display readout. You'll be in Limp Mode 6 cyl operation, with no EML or Check engine but you won't have an E,M, or S symbol denoting transmission mode on the dash. You won't be able to rev over 1500rpm in this case.
    If the EML doesn't illuminate and no trans program message comes on, then you can drive the car most normally with a noted loss of smoothness and power. But it will run. BMW advertised at the onset of the M70B50 in 1986 as its 108mph limp mode was one of it's neatest party tricks."
    ja lisäksi:
    "The #6/#12 plug wires also have a "secondary ignition monitor" pickup coil. If there is a problem with the #6/#12 spark (coil, wire, plug, etc) and this signal doesn't make it to the ECU (aka ECU)then it will shut down that bank."
    ja vielä, liittyen vaihdettuihin sytytystulppiin (olitko sinä vaihtanut ne vai joku aikaisempi omistaja?):
    "Don't use any platinum plugs unless your ignition coils are aftemarket high-output."
    "NGK ZFR5F-11 doesn't seem to work on M70. I changed those spark plugs for one 750iL and same problem.
    Good and working spark plug is NGK BKR6EK. I have them on my 750iL.
    Muistellaan vähän vielä vanhoja ja otampa opiksi, että perusasiat pitää ensin zekata
    Ratkaisu oli siis käsillä jo v.2013 ( toi "ja lisäksi" BeamR:n postauksen lopussa), meni vaan multa ohi kun muutakin tutkittavaa tuntui silloin vielä riittävän.
    Suoraan vastaavaa ongelmaa tai ratkaisua ei kyllä tullut näkyville muiltakaan foorumeilta. Mut hyvä kun selkis
    • Cleaf
      • 26
      #77
      itsellä on kanssa ongelmia tyhjäkäynnin kanssa, tulpat vaihdoin juuri NGK BKR6EK merkkisiin niinkuin muillakin foorumeilla suositellaan mutta vieläkin kuulostaa ettei kaikki sylinterit olisi mukana, mistähän seuraavaksi katsellaan vikaa? 750 -90
      • Laku
        • 17603
        Imusarjan tiivistys, pyörijät ja virranjakajankansi nyt aluksi. Sen jälkeen alkaa vasta rahaa mennä ....
        • jaskap
          • Aug 2010
          • 537
          • Finland Rovaniemi
          #79
          Kuuntele stetoskoopilla, että kaikki suuttimet naksuttaa käydessä. Ei ole tavatonta,että jokin jumii.
          e39 540i Sport Wagon manuaali -98. Pitää olla veekasi.
          e32 750 iA -88 DoubleSex.
          Kyllähän näillä ajamaan pystyvät kaikki. Mutta korjaapa romusta helmeksi ja ylläpidä.
          e32 735 1/18
          e34 M5 1/18
          e24 635 Csi 1/18
          e9 3.0 CSi 1/18
          e31 850 Csi
          • Cleaf
            • 26
            #80
            nyt on virranjakajat ja pyörijät vaihdettu muttei vieläkään asetu käynti, ettei vaan kansi tai pahvi olisi mennyt kun putkesta tulee vesihöyryä?? ei haise kyllä millekkään enkä ole huomannut vielä ainakaan että nestettä häviäisi....
            • Muurahainen
              • 9194
              Höyryää aika komeasti ennen kuin on ihan täysin lämmin. Tuosta ei siis voi päätellä mitään.
              • holmes
                • 351
                • Porvoo Connection
                #82
                Ihan normaalia et höyryää toi m70 "höyryveturi".
                Vettä kondensoituu pönttöihin ja höyryää aikansa.
                Sir! I have a plan.
                • peeämwee
                  • 1824
                  • I sink hell
                  #83
                  Tekeekö m30b34 samaa? Joskus katsonut putkea savet housussa fiiliksellä että nytkö se meni särki. Autolla ei vähään aikaan ajettu, käynnistelty tasaisin väliajoin.
                  http://velkakello.fi/
                  • OEM
                    • Jan 2014
                    • 142
                    • Pk
                    #84
                    Tekee. Ihan normaalia aika monellekin Bmw:lle, ei syytä huoleen.
                    www.bmwharrastaja.com
                    • peeämwee
                      • 1824
                      • I sink hell
                      #85
                      Ok, kiitoksia.
