Hallitus uudistaa autoverotusta
  • nullzwei
    • 11076
    #301
    PS 2.
    Se vajaan seiskan ferkku mondial oli tarkoitettu vitsiksi ja meni täydestä kuin väärä raha. BTW. Eipä olisi vajaa 18kEUR paha hinta ferkusta.
    PS 3.
    Petri.Kekkonen:
    Mitä tuo nyt sitten käytännössä tarkoittaa asiaa ymmärtävien mielestä? Eikö vanhalla verotasolla ei olekaan väliä syrjivyyden suhteen, jos myös uusien autojen verotusta muutetaan?
    Kielitaitoiset voivat tutustua Euroopan Yhteisöjen Tuomioistuimen oheiseen tulevaan caseen ja tehdä siitä oman analyysinsä versus viime viikolla esitelty autoverotuksen muutos.
    Shortcut:
    In order to benefit of the reduction based on the C02 emissions, owners have to provide a certificate of conformity that is hardly possible to be obtained for second-hand vehicles. The Commission has considered that a requirement which contributes to determine the amount of tax but which, for the application of the more favourable tax treatment, cannot be met in most of the cases by goods coming from other Member States, is incompatible with Article 90 of the EC Treaty, since it would result in a higher taxation to the detriment of mainly foreign second-hand cars.
    Secondly, the standard way of calculating the amount of the tax according to the age of the vehicle does not allow taking into consideration the real loss of value of the vehicle at the moment of the registration. The consequence is that the tax applied on second hand vehicles coming from another Member State will not reflect, in the majority of the cases, the amount of tax incorporated in similar second hand vehicles already registered in Cyprus.
    Finally, the Commission has also found that Cyprus lacks a system which allows the taxpayer to challenge the correctness of the tax due before a national court, contrary to what the ECJ has held in case Gomes Valente, C-393/98
    Tästä taasen voi lueskella perusteluita joitten linjauksien mukaisesti mm EY-T varsin mukavasti toimii
    • Sampza
      • Nov 2006
      • 1398
      • Rovaniemi
      #302
      Originally posted by zet4 View Post
      Onko ketään törmännyt vielä uusiin BMW-hintoihin?Volvo oli ensimmäinen ja päivitti jo hinnat
      No jotain tälläistä löytyi:
      Jotain aivan älytöntä katsoa noiden laskelmien mukaan BMW:n M:sarjan hinnanmuutosta.
      Muutoin aika positiiviset vaikutukset olisi luvassa?
      320d touring M-sport -09
      320d -02
      1250 Bandit S
      • _artsi_
        • 579
        • Pori
        #303
        Top 100....
        Tällä listalla BMW ainakin pärjää hyvin.
        BMW 330dA e92 M-SPORT
        • Convertible
          • 2638
          http://www.iltasanomat.fi/autot/auto...s.asp?sort=asc
          Tai pikemmin pyyhkii persettään muilla ..
          F25 X3 35d
          E87 118i
          E46 330ti
          E46 M3
          E30 M3
          E30 M3 Convertible
          Z3 Roadster
          • NokiLeka
            • 2341
            • Eurajoki
            #305
            Perkules mikä moka. Luin tuon kohdan ja lainasin sitä kuin se olisi ollut oikein. Mutta sehän oli KYSYMYS ja sisältää karmaisevan virheen, joka muuttaa merkityksen täysin vääräksi.
            loppuosa kuuluu näin; sen LISÄKSI pitäisi maksaa UUDEN auton auto- ja arvonlisävero auton YLEISESTÄ JÄLLEENMYYNTIHINNASTA KÄYTTÖMAASSA eli meidän tapauksessa SUOMESSA.
            googlettakaa HE 110/2007 (arvonlisäverosta) ja lukekaa sen viimeinen kappale
            Tätä vähän pelkäsinkin, mutta nyt kysymys: Laskeeko ne tuon alvin suoraan uuden auton hinnasta, vai lasketaanko se uuden auton verottomasta hinnasta? Tuohan on todellinen tavaran liikkuvuuseste jos uuden auton alvi räpsäistään Suomessa jo myynnissä olevasta autosta ja autoveron lisäksi.
            Auton hinta saksassa 100.000€
            100.000 x 0,2 = 20.000 x 1,22 = 24.400€
            Auton hinta Suomessa 150.000€
            150.000 x 0,1803 = 27.045€
            Verollinen hinta: 100.000€ + 24.400€ + 27.045€ = 151.445€
            Joko laskukaava näyttää oikealta? Hinnat on revitty hatusta, mutta ideaa tässä nyt haetaankin, voidaan myöhemmin laskea todellisilla luvuilla.
            • Juhis
              BTCF Honorary Member
              • 19182
              #306
              AKL (autoalan keskusliitto) Autotuojat ry, Autoalan tiedotuskeskus, Ajoneuvohallintokeskus, Autokierrätys Oy, Grey-Hen, Netwheels jne. Samat firmat, samat tyypit, malliesimerkkinä "paskaiset housut pessyt puhdasta päälle pukenut" ja Suomen autoverouudistusta "maailman kehittyneimmäksi autoverotusjärjestelmäksi" kehunut juristi Pekka Puputti. Heebo ihan pokkana istuu AKEn johtokunnan puheenjohtajana (arvatkaas kuka on Puputtin seuraaja? Juu-u, joku Rantala ) , Autotuojat ry:n puheenjohtajana, Autokierrätys oy:n toimarina, toimii aivan taatusti Autoalan keskusliitossa, Autoalan tiedotuskeskuksessa ja väliajalla käy antamassa "hyviä verotuksellisia vinkkejä" valtiovarainministeriön lakeja vääntäville virkamiehille, antaa Eduskunnan verovaliokunnissa auto- ja ajoneuvolakiasiain asiantuntijalausuntoja ja ohessa ylläpitää hyviä suhteita tulliin sekä Liikenne- ja Viestintäministeriöön. Näin ollen uusi laki on sorvattu täysin sen mukaan, miten Puputtin edustamat tahot tahtoivat.
              Tuo Pekka Puputti on kyllä malliesimerkki häikäilemättömästä toiminnasta Suomen autoverotuksen suhteen. Miten voi olla mahdollista, että sama henkilö on edustamassa sekä virallisia autontuojia eli lasipalatsien jengiä, AKE:n johtokunnan puheenjohtajana ja vielä Autonkierrätys Oy:ssa?! Ei ole ainakaan minun oikeustajuni mukaista. Only in Finland..
              Sound Factory Bar & Nightclub
              • NokiLeka
                • 2341
                • Eurajoki
                #307
                Originally posted by Juhis View Post
                Only in Finland..
                Väärin.. Kyllähän näin toimivat monet muutkin sivistysvaltiot, kuten Pohjois-Korea, Pakistan jne.
                • nut
                  • 1613
                  • Vaasa/Kauhajoki
                  #308
                  Noniin, takaisin sorvin ääreen. Väittäisin että homma menee kuitenkin seuraavasti. Otetaan nyt tuo 100 000 eur tax-free hinta saksassa ja vastaavalle hintaa 150 000 suomessa. Tästä lasketaan:
                  Uuden auton ALV hankintahinnasta:
                  100 000 * 0,22 = 22 000 eur
                  Tämän pykälän jälkeen kyseessä on tax-free auto josta ALV maksettu ensirekisteröintimaahan. Sitten:
                  Uuden auton autovero ja autoverosta ALV vastaavan yleisestä myyntihinnasta suomessa:
                  150 000 * 0,2 *1,22 = 36 600 eur
                  Saadaan:
                  100 000 + 22 000 + 36 600 = 158 600 eur?
                  Näin ainakin itse tuon kuvion tämän perusteella ymmärsin. Tuossa esimerkissä vääristää lukemia hieman se, että tuo 100 keur on ALViton hinta, kun taas suomen hinta ALVillinen kaiketi
                  BMW-ALPINA E46 B3 3.3 #527
                  • nullzwei
                    • 11076
                    #309
                    Noin se suurin piirtein menee. Ainakin niin kauan, kunnes "uudesta laista" valitetaan ja todetaan laki vääräksi. Sitä ennen voi Euroopan Yhteisöjen Tuomioistuin ehtiä pudottamaan pari kolme pommia, joitten perusteella "uusi laki" on kuolleena syntynyt. Kuten valmisteverolaki, jonka eräs tavja kesällä allekirjoitti ja syksyllä laki oli vainaja. (vrt alkoholin tuonti tilaamalla nettikaupasta)
                    • Zoui
                      • 6350
                      Ja luonnollisesti tuo kuvitteellinen summa ei olisi 150 000, vaan jostain generaattorista tai MARVO nimisen taikurin hatusta kietaistu 168 000eur:n yleinen myyntihinta...
                      Elämä on pihakivestä.
                      • NokiLeka
                        • 2341
                        • Eurajoki
                        #311
                        Saadaan:
                        Niin, kumpi näistä nyt on se Suomen tapa? Tuo nut:n esimerkki nostaa hintaa vielä törkeämmin ja omasta vinkkelistä se kyllä näyttää oikeammalta kuin tuo minun, ainakin kun lukee tuota Tullin ohjetta.
                        Mutta kummallakin laskukaavalla hinta on korkeampi itse tuotaessa kuin autoliikkeestä ostettaessa ja sehän sotii tavaran vapaata liikkumista vastaan.
                        • nut
                          • 1613
                          • Vaasa/Kauhajoki
                          #312
                          Toki, toki. Kyllähän tulliherra aina paremmin tietää kun tavallinen kansa. Eikö tuo periaatteessa ole sama homma kuin käytetyn verotuksen kanssa. Loihditaan jostain vastaavan markkinahinta ja tästä lasketaan autovero ja siihen päälle tuikataan ALV.
                          Tuo uuden auton ALV sitten tavallaan juttu erikseen. Käytetyssä se on jo maksettu ensirekisteröintimaahan, mutta uudessa maksetaan suomeen (eli ensirekisteröintimaahan) ja sen jälkeen aletaan ihmetellä autoveroa?
                          • NokiLeka
                            • 2341
                            • Eurajoki
                            #313
                            Otetaanpas nyt ihan oikeilla hinnoilla, eli hinnat Saksan ja Suomen BMW:n hinnastoista ja Saksan hinta on veroton. Autona e90 330d sedan.
                            Hinta Saksassa: 33 319,33€
                            Hinta Suomessa: 57 500€
                            Uuden auton ALV hankintahinnasta: 33 319,33 x 0,1803 = 6007,48€
                            Autovero (20%) + ALV myyntihinnasta: 57 500 x 0,2 x 1,22 = 14 030€
                            Yhteensä: 33 319,33€ + 6007,48€ + 14 030€ = 53 356,81€
                            Eli tuon mukaan itse tuotuna auton hinta olisi sen 4000€ halvempi kuin maahantuojalta ostettuna? Miten sitten varusteet hintaan vaikuttavat, niin onkin taas toinen juttu, mutta nuo hinnat ovat suoraan lähtöhintoja.
                            • Stone
                              • 4074
                              Sisältääkö tuo saksan hinta myös saksan alvin? Ilmeisesti kyllä..
                              VW Pornstarter (työjuhta)
                              Dodge RAM Cummins (venejuhta)
                              Finnmaster T8
                              • 10+
                                • Aug 2006
                                • 2084
                                • Nivala
                                #315
                                Joo mutta se vero isompi jos auto ei ole ollut käytössä yli 6kk saksassa
                                E39 M5 -00
                                Ex E60 530Da M-Sport -04
                                Ex E39 M5 -00
                                Ex E39 M5 -00 Individual
                                Ex E36 3.0 M3 Cabrio -94
                                Ex E36 3.0 M3 -93
                                Ex E36 2.5 Cabrio -94
                                Ex E36 3.2 M3 -97
                                Ex E36 2.5 Coupe -93
