E61 535d jätti tielle RATKAISTU
  • jonttt
    • Feb 2012
    • 71
    • Lempäälä
    #31
    Noniin, auto nipussa korjatuilla suuttimilla. Kas kummaa eipähän lähde käymään. Railipaineet hukassa.. oleellisia pysyviä vikakoodeja tulee ahtopaineanturilta ja joku power module missing code bmwhatin mukaan??
    Nykyiset:
    BMW E91LCI 320D http://www.btcf.fi/forum/showthread.php?t=324291
    Nissan 200SX S13 SR20DET
    • jonttt
      • Feb 2012
      • 71
      • Lempäälä
      #32
      Eli tollaset koodit oli ennenku nollailtiin. Ja nollauksen lähti kaikki ajoneston koodit kyllä pois. Mutta se power module mietityttää..
      Faults: 31
      ECUs: 34
      Model: 535 d alle/all (MotorID=40, Parameter=150)
      Battery: 12.1V
      Normal communication
      Normal connection
      normal
      B 1
      Date: 2015-08-08 23:58:36
      OBDII
      Version: 21
      Device: >HTC< >himauhl_htc_europe< >HTC One M9<
      Motor Control:
      Engine / Motor
      Fault: Battery Power Management Layer
      Code: 4A56
      Fault: electr. Fans
      Code: 41F2
      ABS / DSC / Brake:
      Dynamische Stabilitaets Kontrolle / DSC
      Fault: Brake pad wear Error: Front
      Code: 5F12
      Fault: Combi failure
      Code: 5F48
      Airbag:
      Advanced Crash and Safety Management (ACSM)
      Fault: B + line
      Code: 93FC
      Satellite front left door / Tuer vorne links
      Fault: sorry, unknown fault
      Code: 9B4B
      Satellite front right door / Tuer vorne rechts
      ECU OK, no Fault Code
      Satellite center / Mitte
      Airbag B-pillar left/ B-Saeule links
      Airbag B-pillar right/ B-Saeule rechts
      Transmission Control:
      Transmission / Getriebe GS 19
      Code: 51AD
      Fault: High speed
      Code: 4F6F
      Code: 51B0
      Instrument cluster:
      Instrument cluster / Kombiinstrument
      Fault: supply voltage failure
      Code: 931D
      Fault: Air suspension failure
      Code: A3C7
      Fault: Debug Info Combi
      Code: A557
      Fault: level actuator
      Code: 931A
      Code: 9319
      Fault: Outside temperature sensor
      Code: 931B
      Central info display / Zentrales Display
      Light/Rain Control:
      Rain/light sensor / Regen-Lichtsensor RLS
      Light / Licht
      Fault: right headlight
      Code: 9CBF
      Heating / AC:
      Air conditioning / Klimaanlage
      Fault: Heating nozzle
      Code: 9C78
      Fault: Short circuit to positive or open circuit (AUC)
      Code: 9C54
      Immobilizer System:
      CAS
      Park distance control:
      Park Distance Control / PDC
      Fault: Inverter HL
      Code: 9E33
      Fault: Inverter HML
      Code: 9E35
      Fault: Inverter VL
      Code: 9E37
      Fault: Inverter VML
      Code: 9E39
      Fault: Inverter VMR
      Code: 9E3A
      Fault: Inverter Board
      Code: 9E38
      Cruise Control:
      Sunroof / Roof:
      Sunroof / Schiebedach
      Audio/Navi/Communication:
      Tuner Antenna / Antenne
      CD-Changer / Wechsler
      Audio-System
      Seats:
      Seats / Sitze
      Seats / Sitze
      Systems:
      Gateway
      Steering column switch / Lenkstockschalter
      Fuel pump / Kraftstoffpumpe
      Power Module
      Fault: missing coding
      Code: A6A6
      Car Communication Computer CCC
      Fault: Over-/undervolt- internal voltage
      Code: A179
      MASK
      Center-Konsole
      Car Communication
      Anti-theft alarm system:
      Chassis:
      Air suspension / Luftfederung
      Central Control / Zentrale Bedieneinheit
      Body:
      Trailer / Anhaenger
      Car Body Module
      Fault: KBM under voltage
      Code: A409
      Fault: Missing hall signal
      Code: A418
      Code: A419
      Fault: NO HALL PULSE FH FTH
      Code: A448
      Code: A449
      Other:
      Nykyiset:
      • jonttt
        • Feb 2012
        • 71
        • Lempäälä
        #33
        Ja eteenpäin sen verran, että polttoainelinjoissa oli käyny asentajamla moka, letkut väärinpäin..
        Nyt railipaineet bousee, mutta vain 120 baariin.. Alkuperäisestä kokoonpanosta poikkeaa huolletut suuttimet ja railipumppu. Voisikohan se olla jollakinlailla jumittunut?
        Nykyiset:
        • zordiack
          • Aug 2011
          • 73
          • Nokia
          #34
          Tarjotaanpa tännekin testattavaks tankin sisällä olevaa ensimmäistä polttoainepumppua. Helppo testata, joku vaihtoehtoletku kiinni lähtöön ja virrat kakkoselle että tuleeko ainetta. Itellä oli korkannu e38:sta se ja ei kans pysy railissa paineet. Siirtopumppu jaksaa vissiin sen verran puskea että hörisee mutta muuten ei oikeen toimi.
          EDIT Sehän on paluulinja siinä päällä, ei sieltä mitään kuulukaan tulla. Eli ihan niin helppo ei oo testata.
          • jpeltoma
            • 600
            • pirkanmaa
            #35
            Ilmaaminen on joskus työlästä. Olen Inpalla pyöritelly tankin pumppua. DIS:ssä on myös ohjelma ilmaukseen.
            __________________________________________________ ________________________
            Vikakoodit Tampere (Pirkanmaa & Satakunta). Läppien poistot.
            • böntti
              • Apr 2011
              • 2866
              Pumppua on kyllä pyöritelty, siitä tuskin on kiinni. Korkeapainepumppu antaa sen verran painetta että suoraan pumpun lähtöön kytketty 600bar mittari pyörähtää ympäri, lisäksi näkyviä vuotoja ei ole. Suuttimet tai paineensäädin ehkäpä, railiin tulee tuo 120bar ja se on katsottu sekä livedatasta että mittarilla. Kolme suutinta on korjattu ja kolme ainoastaan mitattu penkissä. Korjatut suuttimet on sylintereissä 3, 5 ja 6. Yksittäisestä suuttimesta homma ei ole kiinni, pojat olivat suutin kerrallan korvanneet suuttimen painemittarilla, aina sama 120bar.
              • walde
                • Dec 2008
                • 947
                • Melkein Espoo
                #37
                DRV (putkessa oleva paineensäädin) rajaa nimenomaan mekaanisesti virrattomana paineen 120bar. Avoin virtapiiri jättäisi kyllä vikakoodin, joten sen voi melko varmasti jättää laskuista. Joka tapauksessa DRV:n toimintaa lähtisin tässä tapauksessa tarkkailemaan.
                E46 330ti M-Sport II '02 6-gang Supercharged
                F20 LCI2 118dA M-Sport '19
                • böntti
                  • Apr 2011
                  • 2866
                  Lisätään vielä se että ennen koneen vaihtoa ja suuttimien korjausta kone yritti käynnistyä kun 5. suuttimen korvasi painemittarilla. Vikakoodia ei tule. Paineensäädin on vanhasta moottorista.
                    • 9231
                    Lähtökohtaisesti painesäätö on käytössä aina startissa ja käydessä, kun jäähdytysnesteen lämpötila >19 C (määräsäädin täysin auki). Jos painesäätimestä on aktiivinen vika päällä (johto irrotettu), järjestelmän pitäisi mennä puhtaasti tulopuolen määräsäädölle. Mutta, onko tosiaan noin, että painesäädin ei virrattomana olisikaan täysin suljettu? No joka tapauksessa johdon voi kokeeksi napata irti ja tarkistaa, nouseeko paineet yhtään paremmin. Muuten varmaankin seuraava liike olisi päästä kokeilemaan toisella painesäätimellä. Onko kokeiltu käynnistää suhauttamalla hieman jarrukliineriä imusarjaan?
                    • walde
                      • Dec 2008
                      • 947
                      • Melkein Espoo
                      #40
                      Paineensäädin (DRV) on virrattomana auki, jolloin se rajaa max. railpaineen 120bar. Liitin irrotettuna ajoneuvolla ei ole siis minkäänlaisia edellytyksiä käynnistyä.
                        • 9231
                        Mielenkiintoista, kun WDS:ssä painesäätimen vikatilan seurauksena mainittu ainoastaan siirtyminen määräsäätöön ja ruiskutusmäärän rajoitus.
                        • walde
                          • Dec 2008
                          • 947
                          • Melkein Espoo
                          #42
                          Tiedän kyllä. Toisaalta WDS kertoo taas täytössäätöventtiilin ja DRV:n taulukot (PWM, tehollinen virrankulutus, railpaine, ja paluumäärä) taas ovat aivan oikein, kuten pitääkin. No, WDS nyt sisältää aika paljon ristiriitaista tietoa ja hyvin ohuesti selitettyjä järjestelmien / komponenttien toimintoja.
                          • jonttt
                            • Feb 2012
                            • 71
                            • Lempäälä
                            #43
                            Toisella paineensäätimellä koitetaan huomenna. Kaikki oireet viittavat nyt juurikin siihen paineensäätimeen. Tulppasin tänään kaikki suuttimet pois pelistä ja paine edelleenkin 120 baaria. Koputtelemmalla paineensäädintä lukema tippui hieman alaspäin.
                            Tuli myös tarkistettua mittaamalla ECUn ja säätimen väliset johdot, kaikki ok. Liittimestä tuli jännitteitäkin mittailtua ja ne tuntuu olevan järkevissä lukemissa.
                            Ja kun paineensäätimen liittimen irroittaa, niin siirtopumppu lakkaa pyörimästä, eli ei ole juu mahdollista senkään puolesta käynnistyä.
                            Tuli mieleen jos tuo paineensäädin on ollut osasyyllisenä koko moottorin hajoamiseen? Railipaineet nousseet kohtuuttomiksi jos tuo säädin alkanut jumittaa. Saattaa kyllä olla kaukaa haettua, ihmetyttää vaan miksei tuo enään toimi..
                            Nykyiset:
                            • suppari
                              • 4048
                              Eikä oo paineensäätimen johto rempan jäljiltä missään imusarjan välissä poikki?
                              P:0409699000
                              huollot/korjaukset!
                              BMW E&F sarjaan.
                              • jonttt
                                • Feb 2012
                                • 71
                                • Lempäälä
                                #45
                                Ei, koska mittasin eilen paineensäätimen ja ecun välisen johdon vastuksen.
                                Nykyiset:
