BMW i4
  • jani
    • 5251
    Originally posted by tiko4tiko View Post
    Sähkömoottorilla voidaan säätö tehdä sitten että haistellaan -renkaan pyörinopeus vs. vääntomomentti, kuinka paljon vääntöä voidaan tarjoilla ennenkuin pito häviää.
    Ei kait se sähkömoottori niin ”viisas” ole että se tietää mikä kitka on renkaan ja tien välissä?
    Onko jossain tietoa toimiiko näissä sutimisenhallinta jarrua käyttäen vai jotenkin muuten?
    K40 K1200s sondermodell
    • lnaukkar
      • Sep 2015
      • 189
      Kyllä se noin menee että haistelee pitoa suoraan sähkömoottorilta, ei renkaalta. Ja samaten käyttää luistonestoon ensisijaisesti sähkömoottorin ohjausta (nopea) ja toissijaisesti jarruja (hitaammat).
      From the data supplied by DSC and the drive torque requested by the driver, the
      CCU calculates the ideal distribution between front and rear-wheel drive. The fully
      electric xDrive system can react noticeably faster and with significantly higher
      control quality to any change in driving situation than would be possible with a
      transfer box between the axles familiar from BMW models with combustion
      engines.
      The drive control of the CCU, actuator contiguous wheel slip limitation and the
      driving stability control system interact flexibly and precisely. If required, the data
      supplied by DSC about the driving situation can already proactively include an allwheel
      drive request. In many driving situations, a change in the distribution of drive
      torque between the front and rear engines alone can increase driving stability
      without requiring any further intervention. If one wheel threatens to lose grip with
      the road surface, actuator contiguous wheel slip limitation with its particularly fast
      and precise reactions comes into play first. Only in critical situations does DSC also
      assist with wheel-specific braking interventions.
      Due to the direct
      integration of actuator contiguous wheel slip limitation into the drive torque control
      system of the CCU, long signal paths to the driving stability control system are
      eliminated, meaning that interventions can be performed at a speed that is up to 10
      times higher and in a particularly precise dosage.
      2023 G26 i4 M50
      2023 U11 iX1 xDrive30
      • jani
        • 5251
        Okei täällähän on siis kokonaan uusittu asioita polttomoottorisista, vaikuttaa hyvälle ja fiksulle.
        Ei ihme jos auto tuntuu erilaiselle ajaa kuin polttomoottorinen auto.
        • IKa
          • 879
          • Klaukkala
          #34
          Tuo LSD:n toteutus suoraan sähkömoottorilla on varmasti parempi kuin jarruilla tehty. Mutta kun vertaillaan i4:sen polttomoottori-verrokkiin eli M440 malliin, niin silloin on syytä huomioida M440:sen vakiovarusteena oleva mekaaninen LSD taka-akselilla (ainakin G22 mallissa lukkoperä on vakiona). Jos vertailua tehdään esim. neliveto M4:een, niin siinä mekaaninen lukkoperä löytyy molemmilta akseleilta.
          Mielenkiintoista olisi testa, kuinka hyvin sähkömoottoreilla toteutettu LSD pärjää kitkalevyillä toteutetulle mekaaniselle LSD:lle…
          G22 coupe M440i A xDrive MHEV -22
          • ritariässä
            • 4150
            • Raisio
            #35
            Delete
            • tiko4tiko
              • Mar 2020
              • 961
              • Lappeenranta
              #36
              Eihän tämä tähän jää sähköautopuolella. Seuraava steppi on kaksi moottoria samalla akselilla. Käsitääkseni BMW Neue Klassessa varaudutaan 4 moottoriin joiden yhteisteho on max megawatin luokkaa. Jatkossa nelivetoiselle voidaan antaa voimaa erikseen per pyörä (tai takavetoiselle per puoli). Suomessahan on tehty tälläinen nelivetoinen sähköauto jo vuosia sitten, E-RA. Siitä on Nyrreltä hyviä videota (esim 2015 https://www.youtube.com/watch?v=BmAXEwoNq0U Palttala, kierrosaika 7:44min, sähköä 25kWh/kierros). Videolla näkyy dashboardissa etuakselilla tuota voiman muuttumista. Toki pitoa ja vauhtia on, niin kauaa ei kestä, että auto on suorassa ja joka renkaalle menee maksimit.
              Mini, E24, E60, F30, G70
              exät: E23, 2x E34, E39, 2x E83, E61, 2x E70, F15, G05, E90
              • Hexa1983
                • Aug 2016
                • 8
                Osui tänään Car Wow:in testi, missä testaavat Audin eri nelivetoja liukkaalla. Näyttäisi tuo patteriauto pärjäävän vallan mainiosti.
                • bemanderi
                  • 191
                  • Capital West
                  #38
                  Ja näitähän on jo. Mulla on tossa Audissa kolme moottoria, kaksi takana ja yksi edessä. Verrattuna m50d:hen liukkaalla on eroa kuin yöllä ja päivällä kun tänään kävin ajamassa molempia.
                  BMW X5 xdrive35 E70 Navetta
                  Audi a5 3.2fsi Quattro Coupe
                  .. plus sitten kaikkea muuta romua.
                  • lnaukkar
                    • Sep 2015
                    • 189
                    https://www.youtube.com/watch?v=HJRRvHlvhAI
                    Joo tää video summaa koko homman
                    Siinä on täyssähkö e-tron GT (eli halvennettu porsche taycan)
                    sitten on RS3 haldex
                    ja RS6 eli klassinen quattro jossa takana LSD
                    Kaikissa samat renkaat: pirelli Pzero Winter
                    Videon kelaa kohtaan 4:08 niin pääee suoraan asiaan
                    Sähköauto nousee ja muut jää jonnekin taakse.
                    2023 G26 i4 M50
                    • larsen
                      • Jul 2020
                      • 82
                      Taycanin hinnat alkaen mallin saa kyllä halvemmalla kuin Audin. Varusteissa voi toki olla eroja.
                      F36 420ix
                      Ex. E39
                      -- menneiltä vuosilta --
                      Porsche Boxster, Mazda MX-5, Cadillac Seville STS, Chrysler Vision, Mitsubishi Eclipse, Pontiac Trans Am, Ford Thunderbird, Subaru XT, Toyota Celica Supra, Ford Capri
                      pari mannelavettia ja muita bulkkikulkineita
                      • BFI18
                        • Aug 2012
                        • 1459
                        Tämä Taycanin hinnat alkaen malli taitaa olla takavetoinen ja GT aina quattro.
                        G26 i4 M50 Black Sapphire
                        • tiko4tiko
                          • Mar 2020
                          • 961
                          • Lappeenranta
                          #42
                          Niin tai oikeasti..... Audi GT:n neliveto yhtä paljon quattro kuin Taycan Turbo on turbo-moottorinen
                          • BFI18
                            • Aug 2012
                            • 1459
                            Tuon edellä linkatun videon perusteella aika toimivan oloinen 'quattro'
                            • jani
                              • 5251
                              Enemmän kiinnostais nähdä i4M50 vs. Audi e-jotain video.
                              • BFI18
                                • Aug 2012
                                • 1459
                                Kyllä!
