BMW i4
  • VilleP
    • 2706
    Ei kait rengaspaineenvalvonta ole enää kymmeneen vuoteen ollut sidoksissa ABS:ään millään tavalla?
    NewTis:ssä ei ole i4:sta, mutta iX:n sivuilta:
    36 12 ...Notes and specifications for tyre / wheel exchange
    General:
    • The tyre size, manufacturer and tyre tread must be the same on one axle
    • To meet the BMW standards, the vehicle should be equipped with tyres from the same manufacturer and with the same tyre tread (tyres approved by BMW) on all 4 wheels
    • The difference in tyre tread depth on one axle must not exceed 2 mm (control quality of suspension control systems and wheel alignment requirement)
    • The tyres with the higher tread depths must be mounted on the rear axle
    • The DOT age difference must not exceed 4 years
    • The tyre pressure must be adjusted when the tyres are exchanged
    • Wheel exchange between the axles
      The wheels may be exchanged between axles to achieve even abrasion. However, BMW does not recommend switching the front wheels to the rear or vice-versa.
      The wheel exchange may lead to the following customer complaints:
      • complaints regarding acoustics
      • Risk of increased lane groove sensitivity
      Compliance with the following requirements is required when exchanging wheels between the axles:
      • Tyre size and rim size identical on front and rear axle
      • Assess the wear pattern
      • The tread difference between the front and rear wheels must not exceed a maximum of 2-3 mm
      • Exchange the wheels between the axles every 5000 Km
    F11 530xd LCI
    S2 Avant
    • JakPauer
      • Dec 2017
      • 39
      • Lahti
      #497
      ”Tyre size and rim size identical on front and rear axle”. Tämä ei ainakaan päde I4:n kohdalla kun jo vakio rengastus on eri kokoinen akseleiden välillä (245/40 & 255/40).
        • 7583
        #498
        Se että renkaan tyhjenemistä seurataan paineanturein ei tarkoita sitä etteikö auto kalibroisi ABS antureita aina kun renkaat kuitataan vaihdetuksi / rengaspaineet kuitataan...
        Jo polttomoottoriaikaan pyörimisero etu- ja taka-akseleiden välillä sai olla aika iso ilman että auto mitenkään siihen reagoi muuten kuin nykivällä jakolaatikolla. Jos nelikossa
        olisi todella isot kehäerot niin polttiksessa se herjaisi jakolaatikon kuumenemisesta (vaikka ei siellä anturia lämpötilalle ole), kokemusta on kun erääsee F11n oli päätynyt
        väärä etuperä...
        • PNM2
          • Mar 2015
          • 1327
          Tämä oli siis kohdassa, jos vaihdat renkaat edestä taakse eli eteen ei tietenkään leveämpää rengasta kuin taakse.
          Vakiona on talvirenkaita ja 17-tuumaisia lukuunottamatta erikokoista eli 245/45R18 & 255/45R18, 245/40R19 & 255/40R19 sekä 245/35R20 & 255/35R20.
          NA5 iX3 50 xDrive​
          ex: G26 i4 M50
          ex: G30 530e xDrive M-Sport
          ex: F11 525d xDrive
          ex: F11 520d
          ex: E91 318i
          • JakPauer
            • Dec 2017
            • 39
            • Lahti
            #500
            Juuri näin, ja tuossa ohjeistetaan pitämään vanne ja rengaskoko samana molemmilla akseleilla. Anyways, kysymys oli siis että voiko laittaa 245/35R20 & 265/35R20 pyöriä kyseiseen autoon. Alkuperäiset rengaskoot on kyllä tiedossa.
            • PNM2
              • Mar 2015
              • 1327
              En nyt siis tiedä, miten sulle englanti taipuu, mutta tuossa sanotaan vain ja ainoastaan, että jos vaihdat renkaan edestä taakse tai takaa eteen eli eri akselilta toiselle, pitää renkaan ja vanteen koon olla sama. Ei mitään muuta.
              Siinä ei sanota, ettei renkaat voisi yleisesti olla eri kokoisia edessä ja takana.
              NA5 iX3 50 xDrive​
              ex: G26 i4 M50
              ex: F11 525d xDrive
              ex: F11 520d
              ex: E91 318i
              • VilleP
                • 2706
                Ei täällä varmaan kukaan osaa absoluuttsta totuutta sanoa voiko laittaa. Varmaan turha kysymys mutta miksi sinne pitää 265 laittaa? 255 huomattavasti halvempi kumi.
                F11 530xd LCI
                S2 Avant
                • JakPauer
                  • Dec 2017
                  • 39
                  • Lahti
                  #503
                  Noo tuossa olisi nurkissa sopivasti 265 kumit mutta jääköön nurkkiin jos tulee ehdoton tuomio..
                  • Hobbes
                    • Oct 2024
                    • 21
                    Puhumattakaan 285/30 mitkä itellä takana. 2,5 kesää niillä ajeli ja nyt syksyllä pintaa oli 1,5mm. Maksaa mitä maksaa, mutta jos tähän malliin kuluu, niin kyllä lompsa sen kestää. Ja onhan ne aika makeen näköiset, joten jostain sitä pitää maksaa.
                    i4 M50 -23
                    • Mikey?
                      • Nov 2025
                      • 17
                      • Lappeenranta
                      #505
                      Originally posted by Mikey? View Post
                      Mulla on Nettiautossa tallennettu haku (M50, 2023-, 60tkm).
                      Joulukuun viimeisen n. 10 päivän aikana haun tuomista autoista poistui ainakin tusinan verran. Ilmeisesti kauppiaat halusivat tehdä kauppaa ennen vuodenvaihdetta?
                      Nyt tammikuun aikana kauppa on käynyt todella vilkkaasti - tai ainakin autot ovat 'hävinneet' haustani. Myös pyyntihinnat näyttävät lerpahtaneen parilla-kolmella tonnilla vrt joulukuun puolivälin hintoihin. Ehkä ostajat ja myyjät kokevat samoin kuin minä: vuodenvaihteen jälkeen auto on taas 'yhtä vuotta vanhempi'.
                      • itl
                        • Dec 2025
                        • 29
                        Minullakin päättyi arpajaiset auton valinnan suhteen. Tilasin lauantaina M60 auton fully charged paketilla ja muutamalla lisäoptiolla. Enpä malta odottaa kevättä. Kysymys noista ikkunoista. Miten estätte lasien jäätymisen ja ovien avaamisen vaikeuden talvella? Lasiin kannattanee laittaa vaha tai keraaminen pinnoite ja ikkunan tiivisteeseen vaikka silikonia tai jotain vastaavaa.
                        • PNM2
                          • Mar 2015
                          • 1327
                          Mä en ole tehnyt mitään eikä ole ollut ongelmia. Auto on pihalla ilman katosta aina. Ainoa kylmästä johtuva ongelma on jokaisessa Bemarissani ollut vaiva eli ulkokahvan vaijeri jäätyy eikä avaa ovea. Nyt mulla vasen takaovi uhrina kahden ja puolen vuoden ikäisenä.
                          NA5 iX3 50 xDrive​
                          ex: G26 i4 M50
                          ex: F11 525d xDrive
                          ex: F11 520d
                          ex: E91 318i
                          • 314da
                            • May 2015
                            • 445
                            • J
                            #508
                            Ei sitten silikonia noihin tiivisteisiin vaan marmoritiskiltä löytyvää rubbercarea.
                            • E39-530A
                              • Feb 2007
                              • 999
                              Miten asennatte päivitykset autoon pakkasella, jos autoa ei saa minnekään lämpiämään tarpeeksi? Oma remote software upgrade vain odottelee ikuisesti akun lämpötilan tasaantumista. Edellinen onnistui pienemmillä pakkasilla, kun ensin esilämmitti akun, mutta nyt sekään ei riitä. Vai pitääkö odotella kevättä?
                              i4
                              ex E92 335iA -08
                              ex E34 540iA -93
                              ex E90 325iA -05
                              ex E39 530iA -00
                              ex Toyota Avensis
                              ex 4x Toyota Corolla (-83 -> -03)
                              • ekaBMW
                                • Feb 2010
                                • 513
                                En ole i5:ssä moiseen törmännyt.
                                F11 530d xDrive 09/16
                                Ex E60 530d xDrive A 10/08
                                Ex E60 520dA 09/08 liisari
                                Ex Opel Vectra 2.0i 8v -93
                                Ex Opel Kadett 1.6 -89
