Löysin mielenkiintoisen tekstin mailmalta.
Sillä taitaa tosiaan hieman olla merkitystä mistä tiivisteet ostaa.
Toki Beisan haluaa omiansa mainostaa, mutta kannattaa lukea.
You need to be careful of what seals material you are getting. There are many variations of Teflon and to some extent Viton.
Teflon isn't usually used in it's virgin (white) form because it's susceptible to wear and deformation. So normally fillers are added to improve this. Choosing the correct type and grade of the filler is very important. In this vanos application BMW chose a very high grade carbon as the filler. This is correct for several reasons. The vanos has soft non-anodized aluminum cylinder walls and the engine oil pressure is very low, 7.5-60 PSI, compared to the normal hydraulic applications 1,500 PSI. So you need a material that doesn't eat the cylinder walls as the Teflon slides against it, and that allows low enough friction to provide good performance (speed). Graphite would not damage the cylinder walls and has very low friction, but it is fairly susceptible to wear and wouldn't last long. Bronze and glass-moly are too harsh and would damage the cylinder walls and provide poor performance.
When I (Beisan) first looked into this I connected with the largest seals company in the world. They recommended a turquoise Teflon that was essentially virgin Teflon colored green. Once I understood what they were recommending I objected. They said they were right and I needed to follow their advise. I said it would wear quickly. They said that was no problem because you could just replace it when it wears. That was the end of the relationship. I connected with another world class seals company. They agreed carbon was the correct filler. But I was not happy because their carbon wasn't as fine and slick as the OEM. I had them assess the OEM and they found it was carbon but couldn't identify a grade. We launched the seals kit with the standard carbon and ran into issues. It would take 500 city miles for the seals to break in before achieving the performance benefits. Some people had codes during this period. I complained to the seals company. Then I connected with a world class seals materials company. They assess the OEM Teflon and told me that it had a very special very expensive high grade carbon filler that had a single source in the world. This filler had the wear longevity of carbon but was almost as low in friction as virgin Teflon. They recommended it for this vanos application. I switched to this material and the issues significantly resolved. The seals were breaking in in 200 miles. Most of the code issues were gone. We would infrequently see a code just after install before the seals broke in. I found out new vanos units can also experience this. I then had the Teflon rings polished when manufactured. This resolved all the issues and even further reduced the break in period. I had to switch to a smaller seals company to use this material. Essentially no large seals company will offer or use this material because it's too expensive and they are all about reducing costs and increasing profits. With the new seals company we had custom molds made for the seals, $3k each. This allowed creating Teflon billets close to the final dimensions of the seals before sintering and then machining. This notably reduced material loss from machining and facilitated using this very high grade very expensive material.
There are also many variations of Viton rubber. One big issue in the vanos application is compression set. This the flattening of the O-ring. This happens over time due to the compression of the O-ring. There are variations of Viton that facilitate better compression set. We were fortunate to connect with a manufacturer who's O-rings do well with compression set. I have seen many results of compression set over the years and this material does well.
If you look at the ebay listing for i6 Automotive for the double seals kits they specify "Bronze impregnated Teflon". As explained this is too harsh and could damage the vanos soft aluminum cylinder wall and would provide poor performance. Bronze also comes in grades. The standard bronze grade, which is likely what's used, is very course and harsh. We (Beisan) use bronze filler on the S54/S62 Teflon seals. This is appropriate for this application because the cylinder walls are hardened steel and the oil pressure is 1,500 PSI. But we use a very high grade fine bronze filler. This is the same as the OEM.
Another ebay offering by i6 Automotive for the double seals kit has light gray Teflon rings. This is indicative of glass-moly filler. This is the cheapest and harshest material available.
Although the Beisan seals kit is expensive, you do get a lot of value with it. It provides very high grade materials that have been proven with years of install and use. You get a very good procedure to guide you through the repair. I am available continuously by phone and email for support. There is a vanos forum on Bimmerboard where I moderate and answer questions. If you damage any of the seals during the install Beisan will send you replacements at no charge. If you have performance issues or the install doesn't resolve your problem I am always ready to help. I have helped thousands of owners with these issue.
On another note, always use OEM valve cover gaskets. I have recently checked them and BMW has switched to Viton. These new gaskets will last a very long time. All the aftermarket valve cover gaskets I'm aware of are Buna and harden and fail.
I will write a separate post about this to let everyone know.
M54 vanos remontti
Ajattelin hieman kirjoittaa tähän topicciin tietoa kun minulle osui 135tkm ajettu 330ci kohdalle.
Tässä yksilössä vanos piti melko pahaa ääntä.
Kyseessähän siis on vanoksen mäntien laakeroinnin liiallinen välys.
Ennen anti-rattle kitin asennusta
Beisanin "anti-rattle" kit laitettuna
Tämä korjaus on sinänsä aika simppeli tehdä.
Suosittelen laittamaan nämä Beisanin rinkulat sinne jos videon kaltaista ääntä n. 2500rpm kohdalla kuuluu.
Pulttipyssy on hyvä olla, sekä kannattaa ostaa nuo muoviset ruuvipenkin suojat että mäntää saa pidettyä paikallaan ruuvipenkissä kun avaa niitä muttereita.Last edited by Antti O; 24-04-2019, 07:26.
Eipä niihin kanaviin oikeen näe sisälle ja en kyllä ole yhtäkään oikeasti puhdasta tuplavanosta irottanut. Kaikki ovat olleet enemmän tai vähemmän palaneen öljykarstan peitossa.Originally posted by Smack View PostKorjaamon mukaan vanos oli ollut puhdas sisältä joten arvelivat että puhdistukselle tuskin olisi tarvetta. Solenoidien vikaa eivät poissulkeneet täysin. Voisikohan niissä sitten olla vikaa?
Onkohan noiden solenoidien vaihto miten pitkä työ, ja teettääkö noiden rattaiden vaihto paljon töitä?
Ihan perus toiminnan voi testata esim. näin paineilmalla: https://www.youtube.com/watch?v=MVPWL-tQG2s&t=1s
Tuon pitäsi paljastaa mekaaniset ongelmat ja solenoidien mahdollisen toimimattomuuden. Solenoidi on helppo vaihtaa vaikka itse, kun se on vaan kierrettynä siinä ulkopuolella. Rattaiden vaihto on vähän monimutkaisempi, kun se vaatii vanoksen irrotuksen. Mikä ei nyt tuplavanos koneessa ole kovin hankalaa, mut kyllähän siihen aikaa menee.
Korjaamon mukaan vanos oli ollut puhdas sisältä joten arvelivat että puhdistukselle tuskin olisi tarvetta. Solenoidien vikaa eivät poissulkeneet täysin. Voisikohan niissä sitten olla vikaa?Originally posted by Pazi88 View PostJoo kyl eli pakopuolella ongelmaa. Ilmeisesti vanos ei siis seuraa pyydettyjä asteita tarpeeksi nopeasti, mikä on yleensä oire vuotavista vanoksen tiivisteistä. Mut jos ne kerta on vaihdettu, niin melkeen tekisin vanoksen öljykanavien putsauksen jos siellä on vaikka jotain öljytöhkää jämähtänyt kanavien tukkeeksi. Ne rattaat toki voi olla kans kuluneet ja jumittaa, mut semmosta vanosyksikköä taida ollakkaan missä ne tulee mukana. Ne toki voi ostaa erikseen eli osat 6 ja 4: http://www.realoem.com/bmw/enUS/show...diagId=11_2182
Nuo kaksi on ne eniten kuluvat osat koko systeemissä. Sinkkuvanoksessa osa 6 on aina kiinteästi vanoksessa, jolloin joutuu ostamaan koko vanosyksikön uuden, mut tuplavanoksessa bmw on viisastunut ja sen saa erikseenkin ostettua. Ei tarvi turhaan koko vanosyksikköä vaihtaa.
Joo kyl eli pakopuolella ongelmaa. Ilmeisesti vanos ei siis seuraa pyydettyjä asteita tarpeeksi nopeasti, mikä on yleensä oire vuotavista vanoksen tiivisteistä. Mut jos ne kerta on vaihdettu, niin melkeen tekisin vanoksen öljykanavien putsauksen jos siellä on vaikka jotain öljytöhkää jämähtänyt kanavien tukkeeksi. Ne rattaat toki voi olla kans kuluneet ja jumittaa, mut semmosta vanosyksikköä taida ollakkaan missä ne tulee mukana. Ne toki voi ostaa erikseen eli osat 6 ja 4: http://www.realoem.com/bmw/enUS/show...diagId=11_2182Originally posted by Smack View PostPakonokan anturin osalta ei ole tiedossa tehtyjä toimenpiteitä. Ei tiedossa onko korjaamo lukenut livedataa.
Korjaamon kuitin kommenteissa lukee että: "Vanostestien aikana pako vanospyörän säätöalue ei ole säädöissä vaan heittää liikaa: 370ms yli maksimiarvon (maksimi 1000ms). Tarkistettava ajoitus ja vanos solenoidien säädöt". Nämä oli eka korjaamokeikalta ja seuraavalla keikalla vaihdettiin vanoksen tiivisteet mutta "pakopuolella vanoksen säätely on edelleen riittämätön". Joten ymmärtääkseni ovat nuo mainitsemansa jutut sitten tsekanneet toisella keikalla. Liittyykö tuo sinun pakonokka-kommentti tuohon vanoksen pakopuoleen = sama asia?
Onko nokan rattaat samat kuin vanoksen "gears"? Korjaamo suositteli semmoisen vanospaketin hommaamista missä ne tulisi mukana.
Pakonokan anturin osalta ei ole tiedossa tehtyjä toimenpiteitä. Ei tiedossa onko korjaamo lukenut livedataa.Originally posted by Pazi88 View Post106 VANOS Error -Position Exhaust Camshaft
Pakonokan asteet ei siis oo kohdillaan. Onko pakonokan anturia vaihdeltu? Tai luettu ajossa livedataa miten nokan adennon pyynti toteutuu?
Itse en vielää tuolla diagnoosilla vanosyksikköä vaihtas. Kattosin livedatasta että kääntyykö se nokks ollankaan ja jos ei, niin venakoppa auki ja paineilmalla ajaa edes takas. Näkee helposti onko solenoidi rikki vai mekaanista vikaa. Jos mekaanista, niin sit vanosyksikkö irti ja koittaa irrallaan liikkuuko mäntä. Jos liikkuu, niin sit nokan rattaissa on ongelmaa jne.
106 VANOS Error -Position Exhaust CamshaftOriginally posted by Smack View PostKyllä autoa on tutkittu ja koodeja luettu myös vekkulin ja kissvesalan toimesta, joten ei ole helppo pähkinä. Siksi juuri menin lopulta wetterille. Hieman vaan yllättää itseä tuo epäilty vika, niin silläpä vielä pähkäilyä täällä.
Ainut vikakoodi mitä wetterillä on jäänyt ylös on tämä: 00006A. Testeri diagnosoi sen vanos yksikön sisäiseksi viaksi.
Itse en vielää tuolla diagnoosilla vanosyksikköä vaihtas. Kattosin livedatasta että kääntyykö se nokks ollankaan ja jos ei, niin venakoppa auki ja paineilmalla ajaa edes takas. Näkee helposti onko solenoidi rikki vai mekaanista vikaa. Jos mekaanista, niin sit vanosyksikkö irti ja koittaa irrallaan liikkuuko mäntä. Jos liikkuu, niin sit nokan rattaissa on ongelmaa jne.Last edited by Pazi88; 24-08-2017, 20:28.
Vikahan on tosiaan mahdollisesti selvinnyt marmorin toimesta, mutta vain koko vanoksen vaihtamalla selviää ovatko he oikeassa vai väärässä
Jos Linnanmaalla joku ilta käytät autoa niin voidaan lukasta vikakoodit.Originally posted by Antti O View PostPyydä ihmeessä jotain Oulun harrastajaa lukemaan inpalla tai dissillä vikakoodit, ja sitten screenshotti niistä tänne. Pääset halvemmalla, ja saat ihan oikeat vikakoodit. Kun nyt ilmeisesti olet jo sinne marmorille rahaa käyttänyt eikä vika ole selvinnyt.
e: Tosiaan mulla on vain OBD-2 piuha.Last edited by lihakimpale; 22-08-2017, 11:12.
Autoa ei ole muutettu manuaalista automaatiksi. Auto on ollut wetterillä savukoneessa ja imuvuodoksi nekin epäili aluksi oireiden perusteella.
Tietenkään en mitään tarkkaa vikakoodilistaa ole saanut. Tarkemmin kuin muistelee niin tuo öljynpainehomma saattoi olla myös niin että se oli joku viantutkintapolku, että jos öljynpaineessa olisi vikaa niin sitten olisi epäilty jakopäätä. Mutta öljynpaine oli ok. Vanoksessa oli nimenomaan pakopuolella jotakin ajoitusongelmaa ainakin ennen tiivisteiden vaihtoa ja sen jälkeen vielä tuli jotakin vanoksen sisäistä vikakoodia. Pitänee kysyä voisiko vikakoodeista saada tarkkaa listaa kun muuten jää hieman epämääräiseksi.
Mitä muuten katoin noita uudelleen rakennettuja vanospaketteja niin niissä ei tule solenoideja. Ilmeisesti minun vika ei kuitenkaan viittaa ainakaan niihin?
http://www.ebay.com/itm/BMW-E46-E39-...-/181145059213
Ostin talvella oem ilmamassamittarin ja se ei muuttanut mitään. Myöskin sen perässä oleva haitariputki on vaihettu kun siitä oli revenny se sivusta lähtevän letkun haarotus.
Kiitoksia kaikille todella hyvistä vastauksista.
Juu kyllä oikein olet ymmärtänyt. Riippuu vähän loggerista näyttääkö se rikastus prosentin (+/- 28%) vai prosentin verrattuna peruskarttaan (tuo mitä loggasit). Jotku näyttää kertoimella esim. 1,1. Mut joo jos loggaat esim. testolla tyhjäkäynnillä lamdaintegraattoria jonkin aikaa ja avaat login megalogviewerissä ja katsot sillä keskiarvon, sen pitäisi olla aika lähellä nollaa. Käytännössä prosentin sisässä. Jos heittää, niin se kielii imuvuodosta tai kuluneesta maffista. Toki muut harvinaisemmat viat myös vaikuttaa, kuten bensanpaine.Originally posted by Antti O View PostOlenko mä nyt ihan hakoteillä, mutta olen ymmärtänyt että lambda integrator jos on vaikka 110% se rikastaa 10% seosta. Jos vuotaa välistä eikö se joudu silloinkin sitä korjaamaan.
Muistakseni integratorin raja-arvo oli 128% jolloin syttyy moottorin vikavalo ja koodi oli lambda control tolerance out of range.
Tossa vaan oli yksi 330ci mitä tutkin ja siinä oli integratori 120 luokkaa, korjasin disan imuvuodon siitä vaihtamalla uuden o-renkaan, se putosi 110% mitä seurattiin sitä. Jotain se siihen vaikutti.
Myös suoraan loggeri softasta voi katsella keskiarvoa, mut se voi olla vähän hankala keskiarvoistaa "silmällä" et missä se pyörii. Mut toki jos se heittää paljon, kuten tuo 10-20% niin sen näkee selvästikkin.
Tossa vaan oli yksi 330ci mitä tutkin ja siinä oli integratori 120 luokkaa, korjasin disan imuvuodon siitä vaihtamalla uuden o-renkaan, se putosi 110% mitä seurattiin sitä. Jotain se siihen vaikutti.Last edited by Antti O; 21-08-2017, 13:29.
Sekin toki voi olla että maf mittaa vaan väärää ilmamäärää. Mut maf aika harvoin menee niin huonoksi. Tämän toki selvittää helposti livedataa ja adaptaatiota katsomalla. Bensa-adaptaatiot ja lamda integraattorin keskiarvo prosentteina pitäs olla kaikki nollan tuntumassa ehjällä maffilla. Mitä enemmän poikkeaa, sitä kuluneempi maf.Originally posted by Jesse93 View PostItellä kokemusta m54 teki samaa kierrokset humppasi aika rajustikkin laittaessa vapaalle tai kytkin pohjaan ja välillä sammui, korjaantui uudella oem ilmamassamittarilla
Itellä kokemusta m54 teki samaa kierrokset humppasi aika rajustikkin laittaessa vapaalle tai kytkin pohjaan ja välillä sammui, korjaantui uudella oem ilmamassamittarillaOriginally posted by Smack View PostItellä vaikuttas olevan suurempi vanosremontti tulossa. Tyhjäkäynti siis hyppii 400-1300rpm väliä kun painaa kytkiminen pohjaan ja auto vielä liikkuu / kun pysähtyy, kunnes tasoittuu. Auto sammunut pari kertaa risteykseen pysähdyttäessä. Joskus jää tyhjäkäyntikierrokset korkeelle kun auto liikkuu. Joskus toimii oikeinkin.
Oikeen merkkiliikkeessä käytin kun ei ole vikaa löytynyt. Vaihtovat vanokseen tiivistesarjan vaikka se oli kerran tehty jo, ei ole imuvuotoja, bensapaineet kunnossa, lambdatestit kunnossa, imukammion säätömoottori ja tyhjäkäyntimoottori tarkistettu, öljynpaineet mitattu. Testeri antaa vissii jotai hälyä riittämättömästä öljynpaineesta/vanokseen sisäistä vikakoodia. Wetterillä meinasivat ettei auta kun koko vanos-paketti uusia.
Oisko guruilla tähän mitään edullisempaa korjausta kun ei vanoksen tiivistesarjalle korjaantunu, tai oisko tiedossa paikkoja mistä sais inhimilliseen hintaan koko vanos paketin?
