E36 kysymyksiä ja vastauksia XIII
This is a sticky topic.
  • aae30
    • May 2010
    • 2751
    • .fi
    #451
    Originally posted by asis View Post
    Alunperin siis hävitin ainokaisen avaimen, jossa ajoneston siru oli. Auto siis pelasi loistavasti tätä ennen. Tilasin marmorilta autoon uuden avaimen rekkarilla/runkonumerolla ja startti ei inahdakkaan tällä. Virrat tulee päälle normaalisti. Ilmeisesti nyt ajonesto ei juttele tämän uuden avaimen kanssa, vaikka ilmeisesti pitäisi toimia suoraan.
    muistaakseni/mielestäni se voi sen perus inpallakin tehtävissä olevan syncin ews kanssa vaatia?
    edit: nvm., ollaankin e36 osios, en tiedä päteekö alkuunkaan.
    edit2: tämmöne löyty, eli vahvasti ehkä?
    https://www.turnermotorsport.com/t-faq-ews
    EWS, E36 9/93-12/93 = links the door lock switch to the DME and OBC. If the door was locked with the key (or factory alarm) the car will not start without the doors unlocked with the factory key or entering the code into the OBC. In other words, you can’t smash the window and hot wire the car because the DME has killed the ignition and fuel systems.
    EWS-I, E36 1/94-12/94 = same as above but added a starter immobilization relay and transmission position switch.
    In either of the above systems the DME is passive. It only receives signals from sensors and modules. So the DME is not as tied into the body electronics as much as EWS-II.
    EWS-II, E36 1/95-8/96 = similar to the above but with an electronic key, EWS module (“brain”), and the DME all linked together. The same door lock logic remains. All systems for starting the engine are run through the EWS module (starter relay, starter power, fuel, ignition). The key sends a signal to the EWS module and the module asks for a matching signal from the DME. If the two signals don’t match the EWS module will not start the car. The EWS module also checks for OBC function and transmission park/neutral position.
    EWS-III, E36 9/96-8/99 = revised EWS-II system with added clutch position sensor and revised module and wiring.
    Sorry I'm Not Sorry
    E34 540iA 93 sedan
    E34 540iA 93 sedan
    E39 530iA 00 touring
    • 330Driver
      • Feb 2015
      • 462
      • Pori
      #452
      Jos siellä se stratti ei inahdakkaan nii tarkistasin kyllä startin releen ensin. Itellä ennen ewssän poistoa startti kyllä pyöri mutta ews en amtanut auton käynnistyä. Jos kuitenkin luulet että se ews tökkii niin saan sulta kyllä vaikka etänä sen ews:sän siitä ms41sestä pois. Jos ecu vaan on idexi mallinen
      E36 ///M3 evolution cabriolet
      E36 316i Sedan -95 (m52b28 swap)
      E91 330D Käyttis
      Vuokrataan S14/S38/S50 venttiilivälys säätötyökalut
      Koodit/koodaukset PORI
      ___________________________
      EX E92 335D LCI 405hp/801nm
      EX E46 330D Touring
      EX 4x E36, 1x E34, 1x E30
      • asis
        • Mar 2009
        • 1156
        No nyt kun muistelee, niin joskus kun yritin käynnistää tota kolmekutosta avaimella mistä puuttui koko ajoneston siru, niin startti kyllä taisi pyörittää :think Pitääkö paikkaansa että kolmekutosessa startti pyörittää, vaikka ajonesto ei anna käynnistää? Kyllä jos vika on tosissaan jossain muualla kun uudessa avaimessa, niin on kyllä melkoinen sattuma
        E39 540iA M-Sport Imolarot II
        E36 323i touring
        Volvo V70 2.4D mk3
        Honda Accord 2.4 i-VTEC CL9
        Honda Civic 1.4 4d ES
        Chevy Caprice Classic
        E32 730iA
        E39 528i Calypsorot metallic
        E36 325i x2
        • evilracer
          • Nov 2015
          • 237
          Kyllä mä muistelisin että kaverin autossa EWS kenkkuili just siten että startti pyöritti mutta ei käynnistynyt (ja se korjattiin poistamalla EWS), eli jos ei startti inahdakaan niin vika on jossain muualla. Virtalukon pohja, sulakkeet, startin rele :think
          Nelikuutio 328i, tölkki ja monta merssua
            #455
            Ecu maadoittaa pa-pumpun releen ohjauksen miinuspuolen eli nastan 86, ews päällä näin ei tapahdu eli pumppu ei pyöri.
            • Vicious_e36
              • Apr 2015
              • 850
              • Hämeenlinna
              #456
              Keskustelua lainaten, niin tästä päätellen kaverin e36 joka oireilee juuri niin, että startti pyörii, mutta poltto-ainetta ei tule ja EWS on poistettu käytöstä, niin vika olisi ecussa?:think
              Antaa vikakoodia 148 Leitungsfehler DWA/EWS eingang
              Autosta sulakkeet katottu, pa-suodatin ja pumppu vaihdettu, kampuran ja nokan anturi vaihdettu ja tarkastettu että EWS tosiaan poistettu. Käynnissä ollessaan sammu ja sit ei oo lähteny enään käyntiin, muuten kuin bräkleenin avulla.
              e36 325 ’92 (HöntsäDee) Coupe
              e36 328i ’95 Touring,
              e91 330d ’06 Touring, e91 330d '06 Touring,
              e36 328i ’95 Coupe, e90 330i ’06 Sedan,
              e46 320d ’03 Touring, e60 530d ’04 Sedan,
              e36 323i '98 Sedan, e36 318iS '95 Coupe,
              e36 316i '96 Sedan, e46 330d '04 Touring,
              e46 316i '03 Sedan, e36 320i '95 Touring,
              e36 320i '95 Coupe, e36 325i '92 Sedan,
              e36 316i '97 Touring, e30 316i '89 2d Sedan.
              • Maili
                • Aug 2011
                • 463
                • E-pohjanmaa
                #457
                Alkoi e36 328 kytkin luistaa ja ajattelin samalla päivittää kaksoismassan kiinteään vauhtipyörään. Tuosta kaksoismassasta kai hitaasti laskevat kierrokset johtuu, muutoin tuo oma vauhtipyörä on kait kunnossa.Onko näihin jotain kohtuu hintaista bolt on settiä saatavilla?
                E61 523lci -08, E36 328i touring-97, X3 E83 2.0D -07, Fiat 100-90 Turbo
                Ex kalustoa: E39 520ia touring, E36 323 touring, E36 316, E30 316 , E30 318, E21 316 , E21 323 , Nissan 200SX S14A ym.
                • asis
                  • Mar 2009
                  • 1156
                  Tilasin avaimen tehtaalta, auto ei starttaa. Mikähän mahtaa olla syynä?:think
                  Selvis. Autoon on joskus joku vaihtanut ecun ja ews boksin, niin eihän se tehtaalta tilattu avain niiden kanssa pelaa.
                  Ja tossa kun aiemmin pohdin että pyöriikö startti, jos ajonesto ei anna käynnistää, niin ei ainakaan tässä pyöri.
                  E36 323i touring
                  Volvo V70 2.4D mk3
                  E32 730iA
                  E36 325i x2
                  • asis
                    • Mar 2009
                    • 1156
                    Kiitos, mutta ecusta on nyt ews poistettu. Ihan mielenkiinnosta, niin mitenkä se tosta etänä poistetaan?
                    E36 323i touring
                    Volvo V70 2.4D mk3
                    E32 730iA
                    E36 325i x2
                    • Pazi88
                      • 11366
                      Jos avain ei tunnistu, ei pyöri edes startti. Jos taas vain moottorinohjauksen ajonestossa/moottorinohjauksen ja ews purkin keskustelussa on ongelmaa, niin kone pyörii, mutta ei starttaa.
                      Instagram, YouTube kanava
                      • alppiE39
                        • Jun 2019
                        • 106
                        • RIIHIMÄKI
                        #461
                        Nonnii morjesta!
                        Elikkä semmosta vähän erikoisempaa vikaa 36:sessa:
                        Keskikonsolin lämpö/puhallin säätö moduulista kun säätää kaikki lämmöt 16 asteiseksi, puhallin puhaltaa todella lämmintä ilmaa, yli 20 asteista. Myöskin jos puhalluksen ottaa kokonaan pois eli moduuli sammuu niin tulee silti jaloille tätä lämmintä ilmaa. Elikkä puhallusta ei saa ollenkaan edes viileälle.
                        Ilmastointi on mutta ei käytössä. Puhallin moottori tuntuu käyvän vähän hitaalla mutta silläkään tuskin merkitystä tähän.
                        • Haju69
                          Administrator
                          • 16543
                          • Leppävirta
                          #462
                          En tiedä ymmärsinkö oikein mutta jos sinulla on ilmastointi pois päältä niin eihän se kovinkaan kylmää näillä keleillä puhalla.
                          LMC 630 R Liberty 2,8tdi '99
                          E32 Diamantschwarz 750iL '94
                          E36 Hellrot 328i M-Sport ´96
                            #463
                            Niinpä, mieti tätä "Ilmastointi on mutta ei käytössä" Kuten todettu, kun ulkona on mitä on päivisin niin mistä sitä viileää tulisi ?
                            Eli ei erikoisempaa eikä edes tavallista vikaa.
                            • MikkoJII
                              • 1811
                              • Lapua
                              #464
                              Ostin joskus m52b25 toukkaan Valeo 4p merkkisen kovalla vauhtipyörällä olevan bolt on -setin Se maksoi jotain 400€ Saksasta kotia. En tykännyt siitä poljintuntumasta. mutta auto oli käyttöauto. Vaihdoin sitten takaisin kaksoismassalliseen. Sachsin kaksoismassasetti uudella vauhtipyörällä maksoi muistaakseni jotain 700€ kaikkineen.
                              E32 750i 11/89
                              • Vicious_e36
                                • Apr 2015
                                • 850
                                • Hämeenlinna
                                #465
                                Vaihtelin tossa e46 tukivarret ja e9x rt sisäpäät jota lyhensin vähän, niin tuntuu olevan liian pitkät vaikka säädöt minimissä (kierteitä ei näy ollenkaan) niin silti aurauskulmat viturallaan, et pitäis saada lisää sisäänpäin säädettyä.
                                Mietin et pitäiskö vaihtaa suosiolla e36 sisäpäät takas? Ulommat myös e36 omat eikä ole kääntyvyys adaptereota
