E46 kysymyksiä ja vastauksia XII
This is a sticky topic.
  • Flamen
    • Sep 2011
    • 605
    Originally posted by Tudmas View Post
    Potilaana 330 bensa cabrio ja imusarjan purkaessa huomasin että imusarjasta puuttuu yksi tuommoinen muovinen suutin/tai mikälie onkaan. Ovat siis irtonaiset. Mahtaisko joku tietää sille osanumeron? Tai edes nimen. Ei ainakaan realoem näyttänyt kyseistä osaa...
    Lainaus: https://www.bimmerfest.com/threads/m...stion.1304715/
    Those sleeves don't even show up on real OEM. They are not sold separately, no part number can be found or associated with them.
    They are what I would call Turbulence Bore Sleeves, I don't know if they are pressed in or what but you are not the only one that has lost 1 or more.
    You might have to buy a used intake manifold to get replacements, but again, I don't know how they are attached or do they just break off after many heat cycles. Not much info on the interweb about these other than one or more came off when removing the intake manifold gasket (stuck to it) and got unknowingly thrown away.
    They are 5.5mm in size and have to do with what is described below.
    The M52 TU / M54 intake manifold is known as the resonance / turbulence intake system. The molded plastic intake manifold consists of two sets of three intake runners. Resonance valves are used to vary the length of the runners in order to enhance low end torque at low engine speeds or allow high volume air flow at medium or high engine speeds. The intake manifold is also equipped with a 5.5 mm turbulence port for each cylinder. These ports channel idle and low speed air from the idle speed control regulator to one intake valve in each cylinder. (There are 2 intake valves per cylinder.) Air rushing through one valve causes air swirl and more efficient fuel atomization in the cylinder.
    Mulla on yks moottori purettavana, josta tuommoset napukat vois löytyä ylimääräsenä
    Ruosteeton Karmann
    • Tudmas
      • Feb 2007
      • 295
      • Tornio
      #512
      Oispa hyvä homma jos sellaiset löytyy. Tulin omalla tutkimuksella samaan johtopäätökseen kuin yllä.
      Laita mulle vaikka privana viestiä jos löytyy osat. Vielä jos aika pikana sais niin olisi huippua. Tiet sulaa jo kovaa vauhtia ja avo alkaa poltteleen.
      Nyt: E61 530d, E46 330i cabrio.
      ex:e87 130i e46 330i, e36 320i, E38 730i, E36 323i, e39 530d
      • Georgios Terziakis
        • Sep 2010
        • 396
        • Imatra
        #513
        Ajoin tallille, olikin tie vähän epätasanen ja repsahti oikean puoleinen etusisälokari helvettihin, siinä samalla sitten katkesi, käsittääkseni, ulkolämpömittarin anturin johto. Totta helvetissä tallissa nosturilla toinen rojekti mikä ei liiku mihinkään.
        Tunkkasin keulan ylös ja yritin arvailla että mistä tuo johto on lähtösin, mut ei..
        Eli olisko jollain tietoa mistä johtokimpusta tuo tulee? Potilas 330ci vm 2000
        BMW 335i coupe -06
        BMW 330i coupe -00
        Ja pari vanhempaa menOpeliä
          • Sep 2010
          • 396
          • Imatra
          #514
          Itselleni vastaten, lämpötilan anturi lämmitettäville tuulilasinpesurin suuttimille, ja johto menee töötin/sumuvalon johtokimppuun.
          BMW 335i coupe -06
          BMW 330i coupe -00
          • Topi08
            • May 2008
            • 4479
            #515
            M47TUD20
            Missä malleissa olisi samoja suuttimia?, m57?
              #516
              • Topi08
                • May 2008
                • 4479
                #517
                Kiitos
                • Tatu6o
                  • Sep 2021
                  • 96
                  • Uusimaa
                  #518
                  Tarvitseeko pdc moduulia ohjelmoida tutkien vaihtamisen jälkeen?
                  Tutkat eivät toimineet aiemmin ja pakille laittaessa antoi yhden pitkän piippauksen. Inpalla tarkistettuna yksikään tutkista ei toiminut.
                  Ostin uudet hellan tutkat 4kpl ja vaihdoin paikalleen. Nyt inpa näyttää etäisyydet oikein eikä pitkää piippausta kuulu pakille laittaessa, mutta nyt ongelmana on ettei tutkat piippaa lainkaan pakittaessa. Onko jollain tullut vastaan samanlaista ongelmaa?
                  • jouni.325
                    • 2861
                    #519
                    Mikähän mahtaa olla vikana? Potilas m52b28 tu johon vaihdettu m54b30 imupuoli kokonaisuudessaan, sähkökaasulla. m54b30 ohjelma ms43
                    Käynti vika ei käy kaikilla. Vanhalla omistajalla ollut viinalla ja toiminut aivan hyvin, ainut et kylmäkäynnistys ollut huono. Viinalla ollut viina suuttimet.
                    osat pitkä nyt vaihdettu
                    -tulpat
                    -puolat
                    -suuttimet
                    -nokan asentotunnistin
                    -ilmamäärämittari
                    -veten/öljyn lämpömittari eculle
                    -ecusta katottiin ohjelma oli heittänyt bensa kartat sekaisin oli miinuksel 300
                    Vikakoodia antaa 2&5 puolasta kun vaihtaa puolan paikkaa vika ei siirry:think ja jokaisella vikakoodin nollauksella herjaa sytytyshäiriöö jokakerta eri pytylle
                    Täällä löytyy kiilloitus harrastukseni http://www.aijaa.com/folders.php?act=subfolder&i=28873
                    Autokerhon Facebook sivu tykkää tökkää jaa
                    https://www.facebook.com/xtremecustomcars/
                    Myös projekti kertomus fasessa
                    • lesentso
                      • Apr 2011
                      • 300
                      • Iisalmi
                      #520
                      Pystyykö M54B25:ssa käyttämään 95-oktaanista bensiiniä? :think
                      • Tatu6o
                        • Sep 2021
                        • 96
                        • Uusimaa
                        #521
                        Pystyy. Suositus taitaa olla 98, mutta auton pitäisi toimia 95:lla ja tunnistaa jos alkaa nakuttamaan ja siirtää ajoitusta myöhemmäksi. Itse en ajaisi koska 98:lla saa maksimi tehot ja pienentää sen verran polttoaineen kulutusta että hinna puolesta pääsee tasoihin. Suurempi etanoli määrä saattaa myös syödä bensaletkuja.
                        • Wespa
                          • Jan 2016
                          • 2015
                          • Karjaa
                          #522
                          Tuo nyt on aika teoreettinen ongelma, ero 5% --> 10% on mitätön semminkin kun näillä kuitenkin ajetaan ilman ongelmia bensaletkujen kanssa myös E85:sella.
                          Porsche 944 -86 (DE)
                            #523
                            :think
                            • MPV
                              • 1207
                              • Muhos
                              #524
                              :think
                              Ei nyt E46 käyttöopas ollut käsillä, mutta E39:n käyttöoppaassa sanotaan, jotta vähintää 91 oktaanista, luvatut arvot kuitenkin saavutetaan 95:lla ja 98:lla saavutetaan parhaat suoritusarvot ja pienempi kulutus. Samaan tyyliin se on kerrottu myös E46:sen kirjassa.
                              • Pazi88
                                • 11374
                                En kai tuota oo millään muulla ajanukkaan kuin 95:lla
                                Instagram, YouTube kanava
